path: root/doc/device-tree-bindings
2019-06-20doc: Remove duplicated documentation directoryBreno Matheus Lima
Commit ad7061ed742e ("doc: Move device tree bindings documentation to doc/device-tree-bindings") moved all device tree binding documentation to doc/device-tree-bindings directory. The current U-Boot project still have two documentation directories: - doc/ - Documentation/ Move all documentation and sphinx files to doc directory so all content can be in a common place. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2019-05-24Merge tag 'u-boot-stm32-20190523' of https://github.com/pchotard/u-bootTom Rini
- Add various STM32MP1 fixes for serial, env, clk, board, i2c ... - Add STM32MP1 DDR driver update: These update introduce the DDR interactive mode described in: https://wiki.st.com/stm32mpu/index.php/U-Boot_SPL:_DDR_interactive_mode This mode is used by the CubeMX: DDR tuning tool. https://wiki.st.com/stm32mpu/index.php/STM32CubeMX The DDR interactive mode is NOT activated by default because it increase the SPL size and slow down the boot time (200ms wait added).
2019-05-23m68k: add basic set of devicetreesAngelo Dureghello
This patch adds a basic group of devicetrees, one for each cpu family, including actually just uart and dspi devices, since these are the drivers supporting devicetree (support added in this patch-set). Acked-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Angelo Dureghello <angelo@sysam.it> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-05-23stm32mp1: ram: update parameter array initializationPatrick Delaunay
Force alignment of the size of parameters array with the expected value in the binding, that allows compilation error when the array size change. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-05-23stm32mp1: ram: change ddr speed to kHzPatrick Delaunay
Allow fractional support in DDR tools. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-05-23stm32mp1: update RCC binding after kernel realignmentPatrick Delaunay
RCC is no more a mfd and add a complete example and alignment with latest TF-A binding Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-05-10ARM: socfpga: Description on FPGA bitstream type and file name for Arria 10Tien Fong Chee
This patch adds description on properties about file name used for both peripheral bitstream and core bitstream. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
2019-05-08net: phy: micrel: Use correct skew values on KSZ9021James Byrne
Commit ff7bd212cb8a ("net: phy: micrel: fix divisor value for KSZ9031 phy skew") fixed the skew value divisor for the KSZ9031, but left the code using the same divisor for the KSZ9021, which is incorrect. The preceding commit c16e69f702b1 ("net: phy: micrel: add documentation for Micrel KSZ90x1 binding") added the DTS documentation for the KSZ90x1, changing it from the equivalent file in the Linux kernel to correctly state that for this part the skew value is set in 120ps steps, whereas the Linux documentation and driver continue to this day to use the incorrect value of 200 that came from the original KSZ9021 datasheet before it was corrected in revision 1.2 (Feb 2014). This commit sorts out the resulting confusion in a consistent way by making the following changes: - Update the documentation to be clear about what the skew values mean, in the same was as for the KSZ9031. - Update the Micrel PHY driver to select the appropriate divisor for both parts. - Adjust all the device trees that state skew values for KSZ9021 PHYs to use values based on 120ps steps instead of 200ps steps. This will result in the same values being programmed into the skew registers as the equivalent device trees in the Linux kernel do, where it incorrectly uses 200ps steps (since that's where all these device trees were copied from). Signed-off-by: James Byrne <james.byrne@origamienergy.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-04-22led: add initial support for bcm6858Philippe Reynes
The driver add the support of the led IP on bcm6858. This led IP can drive up to 32 leds, and can handle blinking. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2019-04-21stm32mp1: add stusb1600 support for DK1 and DK2 boardPatrick Delaunay
The DK1 and DK2 boards use the USB Type-C controller STUSB1600. This patch updates: - the device tree to add the I2C node in the DT - the board stm32mp1 to probe this I2C device and use this controller to check cable detection. - the DWC2 driver to support a new dt property "u-boot,force-b-session-valid" which forces B session and device mode; it is a workaround because the VBUS sensing and ID detection isn't available with stusb1600. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2019-04-21usb: dwc2: add support for STM32MP1Patrick Delaunay
Add compatible "st,stm32mp1-hsotg" and associated driver data to manage the usb33d-supply and the ST specific register for VBus sensing. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> # Conflicts: # drivers/usb/gadget/dwc2_udc_otg.c Reviewed-by: Lukasz Majewski <lukma@denx.de>
2019-04-21usb: dwc2: convert driver to DM_USB_GADGETPatrick Delaunay
Minimal conversion to driver model by using the uclass UCLASS_USB_GADGET_GENERIC based on: - reset uclass - clock uclass - generic uclass. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2019-04-21phy: usbphyc: Binding update of vdda supplyPatrick Delaunay
Move supply vdda1v1 and vdda1v8 in usbphyc node and no more in port Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-04-18ARC: dwmmc: Adding DesignWare MMC driver support for ARC devboardsEugeniy Paltsev
Add the DM_MMC-compatible DesignWare MMC driver support for Synopsys ARC devboards. It is created to switch ARC devboards to use DM_MMC. It required information such as clocks (Bus Interface Unit clock, Card Interface Unit clock) and SDIO bus width. Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2019-04-14Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
Conflicts: arch/arm/dts/armada-385-amc.dts arch/arm/dts/armada-xp-theadorable.dts arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-12Merge tag 'u-boot-stm32-20190412' of https://github.com/patrickdelaunay/u-bootTom Rini
stm32 patches for v2019.07-rc1 - Add trusted boot with TF-A for stm32mp1 - stm32mp1 dts files sync'ed with Linux version - add STM32MP1 Discovery boards (DK1 and DK2) - add STMFX gpio expander driver - misc improvement for stm3mp1 supports - rename stpmu1 to stpmic1 (official name) - stm32_qspi: move to exec_op (spi nor driver for stm32 mpu and mcu) - add STM32 FMC2 NAND flash controller driver
2019-04-12dt-bindings: mtd: stm32_fmc2: add STM32 FMC2 NAND controller documentationChristophe Kerello
This patch adds the documentation of the device tree bindings for the STM32 FMC2 NAND controller. Signed-off-by: Christophe Kerello <christophe.kerello@st.com> Reviewed-by: Patrick DELAUNAY <patrick.delaunay@st.com>
2019-04-12doc: device-tree-bindings: switch from spi-flash to jedec, spi-norNeil Armstrong
Since all DTS files has been switched to "jedec,spi-nor", remove the "spi-flash" compatible from the bindings examples. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Rick Chen <rick@andestech.com> Reviewed-by: Patrick Delaunay <Patrick.delaunay@st.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2019-04-11DM: I2C: Introduce 'u-boot, i2c-transaction-bytes' propertyLukasz Majewski
The 'u-boot,i2c-transaction-bytes' device tree property provides information regarding number of bytes transferred by a device in a single transaction. This change is necessary to avoid hanging devices after soft reset. One notable example is communication with MC34708 device: 1. Reset when communicating with MC34708 via I2C. 2. The u-boot (after reboot -f) tries to setup the I2C and then calls force_idle_bus. In the same time MC34708 still has some data to be sent (as it transfers data in 24 bits chunks). 3. The force_idle_bus() is not able to make the bus idle as 8 SCL clocks may be not enough to have the full transmission. 4. We end up with I2C inconsistency with MC34708. This PMIC device requires 24+ SCL cycles to make finish any pending I2C transmission. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-03-11regulator: Add support for ramp delayKrzysztof Kozlowski
Changing voltage and enabling regulator might require delays so the regulator stabilizes at expected level. Add support for "regulator-ramp-delay" binding which can introduce required time to both enabling the regulator and to changing the voltage. Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Tested-by: Anand Moon <linux.amoon@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2019-02-28doc: binding: rename directory ram to memory-controllerPatrick Delaunay
Alignment with kernel directory name as it have already bindings for DDR controllers in the directory: Documentation/devicetree/bindings/memory-controller PS: the drivers using RAM u-class should be associated with this binding directory Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-02-27clk: Add fixed-factor clock driverAnup Patel
This patch adds fixed-factor clock driver which derives clock rate by dividing (div) and multiplying (mult) fixed factors to a parent clock. Signed-off-by: Atish Patra <atish.patra@wdc.com> Signed-off-by: Anup Patel <anup.patel@wdc.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-02-20sound: Add support for Intel HDASimon Glass
The Intel High-definition Audio is a newer-generation audio system which provides for transfer of a large number of audio stream, each containing up to 16 channels. Add support for HDA as a library which can be used by other drivers. U-Boot currently uses only two channels (stereo). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-02-09clk: stm32mp1: correctly handle Clock Spreading GeneratorPatrick Delaunay
To activate the csg option, the driver need to set the bit2 of PLLNCR register = SSCG_CTRL: Spread Spectrum Clock Generator of PLLn enable. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-01-16mips: mscc_sgpio: Add DT bindings documentationLars Povlsen
This add device tree binding documentation for the MSCC serial GPIO driver. Signed-off-by: Lars Povlsen <lars.povlsen@microsemi.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2019-01-01w1: Add driver for i.MX bus master controllerMartin Fuzzey
Two variants of controllers are supported: V1 (bitwise only) found in i.MX21, i.MX27, i.MX31, i.MX51 V2 (byte operations) found in i.MX25, i.MX35, i.MX50, i.MX53 Only tested on i.MX53 hardware but in both modes (by modifying the device tree). Signed-off-by: Martin Fuzzey <martin.fuzzey@flowbird.group>
2018-12-10power: add FAN53555 family supportPhilipp Tomsich
This adds a driver for the FAN53555 family of regulators and wraps it in a PMIC implementation. While these devices support a 'normal' and 'suspend' mode (controlled via an external pin) to switch between two programmable voltages, this incarnation of the driver assumes that the device is always operating in 'normal' mode. Only setting/reading the programmed voltage is supported at this time and the following device functionality remains unsupported: - switching the selected voltage (via a GPIO) - disabling the voltage output via software-control This matches the functionality of the Linux driver. Tested on a RK3399-Q7 (with 'option 5' devices): setting voltages from the U-Boot shell and verifying output voltages on the board. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Tested-by: Klaus Goger <klaus.goger@theobroma-systems.com>
2018-12-10bootcount: add uclass for bootcountPhilipp Tomsich
The original bootcount methods do not provide an interface to DM and rely on a static configuration for I2C devices (e.g. bus, chip-addr, etc. are configured through defines statically). On a modern system that exposes multiple devices in a DTS-configurable way, this is less than optimal and a interface to DM-based devices will be desirable. This adds a simple driver that is DM-aware and configurable via DTS. If ambiguous (i.e. multiple bootcount-devices are present) the /chosen/u-boot,bootcount-device property can be used to select one bootcount device. Initially, this provides support for the following DM devices: * RTC devices Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Tested-by: Klaus Goger <klaus.goger@theobroma-systems.com>
2018-11-29spi: cadence_qspi: use "cdns,qspi-nor" as compatibleSimon Goldschmidt
Linux uses "cdns,qspi-nor" as compatible string for the cadence qspi driver, so change driver, docs and all device trees. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2018-11-16ram: Introduce K3 AM654 DDR Sub System driverLokesh Vutla
K3 based AM654 devices has DDR memory subsystem that comprises Synopys DDR controller, Synopsis DDR phy and wrapper logic to intergrate these blocks into the device. This DDR subsystem provides an interface to external SDRAM devices. Adding support for the initialization of the external SDRAM devices by configuring the DDRSS registers and using the buitin PHY routines. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Schuyler Patton <spatton@ti.com> Signed-off-by: James Doublesin <doublesin@ti.com>
2018-11-16w1-eeprom: Add support for Maxim DS2502 add only memoryMartin Fuzzey
2018-11-05net: Add MT7628 ethernet driverStefan Roese
This patch adds ethernet support for the MIPS based Mediatek MT76xx SoCs (e.g. MT7628 and MT7688), including a minimum setup of the integrated switch. This driver is loosly based on the driver version included in this MediaTek github repository: https://github.com/MediaTek-Labs/linkit-smart-uboot.git Tested on the MT7688 LinkIt smart-gateway and on the Gardena-smart-gateway. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Frank Wunderlich <frankwu@gmx.de> Cc: Weijie Gao <hackpascal@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-10-10net: phy: ti: Add binding for the CLK_OUT pin muxingJanine Hagemann
The DP83867 has a muxing option for the CLK_OUT pin. It is possible to set CLK_OUT for different channels. Create a binding to select a specific clock for CLK_OUT pin. Based on commit 9708fb630d19 ("net: phy: dp83867: Add binding for the CLK_OUT pin muxing option") of mainline linux kernel. Signed-off-by: Janine Hagemann <j.hagemann@phytec.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-10-10net: phy: ti: Add lane swapping support in the DP83867 TI's PHY driverJanine Hagemann
This patch adds support for enabling or disabling the lane swapping (called "port mirroring" in PHY's CFG4 register) feature of the DP83867 TI's PHY device. One use case is when bootstrap configuration enables this feature (because of e.g. LED_0 wrong wiring) so then one needs to disable it in software (at u-boot/Linux). Based on commit fc6d39c39581 ("net: phy: dp83867: Add lane swapping support in the DP83867 TI's PHY driver") of mainline linux kernel. Signed-off-by: Janine Hagemann <j.hagemann@phytec.de> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-10-07dt/bindings: add bindings for opteeJens Wiklander
Sync with c8bfafb15944 ("dt/bindings: add bindings for optee") from Linux kernel. Introduces linaro prefix and adds bindings for ARM TrustZone based OP-TEE implementation. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2018-10-02Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
This is the PR for SPI-NAND changes along with few spi changes. [trini: Re-sync changes for ls1012afrwy_qspi*_defconfig] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-09-29Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2018-09-28dt-bindings: w1-eeprom: eep_sandbox: create bindingsEugen Hristev
Bindings for sandbox onewire eeprom driver Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-09-28dt-bindings: w1-eeprom: ds24xxx: create bindingsEugen Hristev
Bindings for Maxim's ds24 onewire EEPROM families driver Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-09-28dt-bindings: W1: w1-gpio: added bindings for w1-gpioEugen Hristev
Added bindings specification for bitbanged gpio driver for Dallas one wire protocol Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-09-28doc: dtbinding: Add file system firmware loader binding documentTien Fong Chee
Add a document to describe file system firmware loader binding information. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-28video_osd: Add ihs_video_out driverMario Six
Add a driver for IHS OSDs on IHS FPGAs. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-22pinctrl: bcm6838: add pinctrl supportPhilippe Reynes
Add pinctrl support for broadcom bcm6838 SoC. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2018-09-20dt-bindings: Add bindings for SPI NAND devicesBoris Brezillon
Add bindings for SPI NAND chips. Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com> Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Acked-by: Jagan Teki <jagan@openedev.com>
2018-09-11remoteproc: Introduce K3 remoteproc driverLokesh Vutla
Add support for K3 based remoteproc driver that communicates with TISCI to start start a remote processor. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-11remoteproc: Introduce K3 system controllerLokesh Vutla
K3 specific SoCs have a dedicated microcontroller for doing resource management. Any HLOS/firmware on compute clusters should load a firmware to this microcontroller before accessing any resource. Adding support for loading this firmware. After the K3 system controller got loaded with firmware and started up it sends out a boot notification message through the secure proxy facility using the TI SCI protocol. Intercept and receive this message through the rproc start operation which will need to get invoked explicitly after the firmware got loaded. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-09-11mailbox: Introduce K3 Secure Proxy DriverLokesh Vutla
Secure Proxy module manages hardware threads that are meant for communication between the processor entities. Adding support for this driver. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
2018-09-11sysreset: Add TI System Control Interface (TI SCI) sysreset driverAndreas Dannenberg
Devices from the TI K3 family of SoCs like the AM654x contain a Device Management and Security Controller (SYSFW) that manages the low-level device control (like clocks, resets etc) for the various hardware modules present on the SoC. These device control operations are provided to the host processor OS through a communication protocol called the TI System Control Interface (TI SCI) protocol. This patch adds a system reset driver that communicates to the system controller over the TI SCI protocol for allowing to perform a system- wide SoC reset. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-11power domain: Introduce TI System Control Interface (TI SCI) power domain driverAndreas Dannenberg
Some TI Keystone 2 and K3 family of SoCs contain a system controller (like the Power Management Micro Controller (PMMC) on 66AK2G SoCs and the Device Management and Security Controller on AM65x SoCs) that manage the low-level device control (like clocks, resets etc) for the various hardware modules present on the SoC. These device control operations are provided to the host processor OS through a communication protocol called the TI System Control Interface (TI SCI) protocol. This patch adds a power domain driver that communicates to the system controller over the TI SCI protocol for performing power management of various devices present on the SoC. Various power domain functionalities are achieved by the means of different TI SCI device operations provided by the TI SCI framework. This code is loosely based on the drivers/soc/ti/ti_sci_pm_domains.c driver of the Linux kernel. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-11clk: Introduce TI System Control Interface (TI SCI) clock driverAndreas Dannenberg
Some TI Keystone 2 and K3 family of SoCs contain a system controller (like the Power Management Micro Controller (PMMC) on 66AK2G SoCs and the Device Management and Security Controller on AM65x SoCs) that manage the low-level device control (like clocks, resets etc) for the various hardware modules present on the SoC. These device control operations are provided to the host processor OS through a communication protocol called the TI System Control Interface (TI SCI) protocol. This patch adds a clock driver that communicates to the system controller over the TI SCI protocol for performing clock management of various devices present on the SoC. Various clock functionality is achieved by the means of different TI SCI device operations provided by the TI SCI framework. This code is loosely based on the drivers/clk/keystone/sci-clk.c driver of the Linux kernel. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Signed-off-by: Vignesh R <vigneshr@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
