1. add the address mapping related properties;
2. make "ref" clock optional, and add optional clock "da_ref";
3. add the banks layout of TPHY V1 and V2;
Signed-off-by: Chunfeng Yun <chunfeng.yun@mediatek.com>
Signed-off-by: Frank Wunderlich <frank-w@public-files.de>
Reviewed-by: Weijie Gao <weijie.gao@mediatek.com>
Devices need to report various identifiers in the ACPI tables. Rather than
hard-coding these in drivers it is typically better to put them in the
device tree.
Add a binding file to describe this.
Update reference in files detected by
scripts/documentation-file-ref-check
doc/devicetree/device-tree-bindings/ => doc/device-tree-bindings/
Update the binding file for gpio, it is just an alignment
with kernel v5.3.
The U-Boot code example for gpio-hog (not directly linked
to binding) is moved in a new file doc/README.gpio.
[commit 21676b706e99 ("gpio: fixes for gpio-hog support")
& 'commit 4762a9988ede ("gpio: add gpio-hog support")']
This commit extends the flags that can be used in GPIO specifiers to
indicate if a pull-up resistor or pull-down resistor should be
enabled.
It is the backport of linux commit ede033e1e863c ('dt-bindings:
gpio: document the new pull-up/pull-down flags')
from Thomas Petazzoni <thomas.petazzoni@bootlin.com>
and integrated in v5.1-rc1
https://github.com/torvalds/linux/commit/ede033e1e863c
Add this binding from Linux v5.4.
Add a means to avoid configuring a device when needed. Add an explanation
of why this is useful to the binding file.
This device should use ready-gpios rather than ready-gpio. Fix it.
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze into next
Xilinx changes for v2020.07
common:
- Align ENV_FAT_INTERFACE
- Fix MAC address source print log
- Improve based autodetection code
xilinx:
- Enable netconsole
Microblaze:
- Setup default ENV_OFFSET/ENV_SECT_SIZE
Zynq:
- Multiple DT updates/fixes
- Use DEVICE_TREE environment variable for DTB selection
- Switch to single zynq configuration
- Enable NOR flash via DM
- Minor SPL print removal
- Enable i2c mux driver
ZynqMP:
- Print multiboot register
- Enable cache commands in mini mtest
- Fix firmware probing when driver is not enabled
- Specify 3rd backup RAM boot mode in SPL
- Add SPL support for zcu102 v1.1 and zcu111 revA
- Redesign debug uart enabling and psu_init delay
- Enable full u-boot run from EL3
- Enable u-boot.itb generation without ATF with U-Boot in EL3
Versal:
- Enable distro default
- Enable others SPI flashes
- Enable systems without DDR
Drivers:
- Gem:
- Flush memory after freeing
- Handle mdio bus separately
- Watchdog:
- Get rid of unused global data pointer
- Enable window watchdog timer
- Serial:
- Change reinitialization logic in zynq serial driver
Some SoCs in the mpc83xx family, e.g. mpc8309, have a dedicated spi
chip select, SPISEL_BOOT, that is used by the boot code to boot from
flash.
This chip select will typically be used to select a SPI boot
flash. The SPISEL_BOOT signal is controlled by a single bit in the
SPI_CS register.
Implement a gpio driver for the spi chip select register. This allows a
spi driver capable of using gpios as chip select, to bind a chip select
to SPISEL_BOOT.
It may be a little odd to do this as a GPIO driver, since the signal
is neither GP or I, but it is quite convenient to present it to the
spi driver that way. The alternative it to teach mpc8xxx_spi to handle
the SPISEL_BOOT signal itself (that is how it's done in the linux
kernel, see commit 69b921acae8a)
Signed-off-by: Klaus H. Sorensen <khso@prevas.dk>
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
This parameter "st,phy-cal" becomes optional and when it is
absent the built-in PHY calibration is done.
It is the case in the helper dtsi file "stm32mp15-ddr.dtsi"
except if DDR_PHY_CAL_SKIP is defined.
This patch also impact the ddr interactive mode
- the registers of the param 'phy.cal' are initialized to 0 when
"st,phy-cal" is not present in device tree (default behavior when
DDR_PHY_CAL_SKIP is not activated)
- the info 'cal' field can be use to change the calibration behavior
- cal=1 => use param phy.cal to initialize the PHY, built-in training
is skipped
- cal=0 => param phy.cal is absent, built-in training is used (default)
Acked-by: Patrice Chotard <patrice.chotard@st.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-ti into next
K3 J721E:
* OSPI boot support
* Support for loading remote cores in R5 SPL
* PMIC ESM Support
* Minor fixes for R5F and C7x remoteproc drivers
K3 AM654:
* Update AVS class 0 voltages.
* Add I2C nodes
DRA7xx/AM57xx:
* Fixed Android boot on AM57xx
AM33/AM43/Davinci:
* switch to driver model for the net and mdio driver for baltos
* Add DM/DTS support for omap video driver
* Enable fastboot on am335x-evm
add DM/DTS support for the memory based bootcounter
in drivers/bootcount/bootcount.c.
Let the old implementation in, so boards which have
not yet convert to DM/DTS do not break.
This adds support for clock stretching to the i2c-gpio driver. This is
accomplished by switching the GPIO used for the SCL line to an input
when it should be driven high, and polling on the SCL line value until
it goes high (indicating that the I2C slave is no longer pulling it
low).
This is enabled by default; for gpios which cannot be configured as
inputs, the i2c-gpio,scl-output-only property can be used to fall back
to the previous behavior.
Signed-off-by: Michael Auchter <michael.auchter@ni.com>
Document the gpio-i2c deblocking sequence binding.
U-Boot is having DT which doesn't cover all options currently supported by
driver. DT binding is aligned with Linux kernel version available here.
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/Documentation/devicetree/bindings/net/ti,dp83867.txt
Based on my talk with Grygorii Strashko better will be to remove it.
Also Linux kernel bindings are being converted to yaml that's another
reason to do it only at one place.
Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com>
Drop the Apollo Lake prefix 'apl' from the functions, types and
variables in the P2SB driver.
The P2SB is not Apollo Lake specific, and as such it was moved in
commit 2999846c1127 ("x86: Move P2SB from Apollo Lake to a more generic
location") from the Apollo Lake folder to the intel_common folder.
Signed-off-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
Add device-tree binding documentation for ti framebuffer and generic
panel output driver.
Signed-off-by: Dario Binacchi <dariobin@libero.it>
The ESM (Error Signal Monitor) is used on certain PMIC versions to
handle error signals propagating from rest of the system. If these
reach the PMIC, it is typically a last resort fatal error which
requires a system reset. The ESM driver does the proper configuration
for the ESM module to reach this end goal. Initially, only TPS65941
PMIC is supported for this.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
The ESM (Error Signaling Module) is used to route error signals within
the K3 SoCs somewhat similar to interrupts. The handling for these is
different though, and can be routed for hardware error handling, to
be handled by safety processor or just as error interrupts handled
by the main processor. The u-boot level ESM driver is just used to
configure the ESM signals so that they get routed to proper destination.
Fix the following DT dtc warnings for stm32mp1 boards:
Warning (unit_address_vs_reg): /soc/rcc@50000000/st,pll@0:
node has a unit name, but no reg property
Warning (unit_address_vs_reg): /soc/rcc@50000000/st,pll@1:
Warning (unit_address_vs_reg): /soc/rcc@50000000/st,pll@2:
Warning (unit_address_vs_reg): /soc/rcc@50000000/st,pll@3:
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
Device tree and binding alignment with kernel v5.4
sandbox conversion to SDL2
TPM TEE driver
Various minor sandbox video enhancements
New driver model core utility functions
ACPI GPEs are used to signal interrupts from peripherals that are accessed
via ACPI. In U-Boot these are modelled as interrupts using a separate
interrupt controller. Configuration is via the device tree.
Add a simple driver for this.
At present driver model supports the IRQ uclass but there is no way to
request a particular interrupt for a driver.
Add a mechanism, similar to clock and reset, to read the interrupts
required by a device from the device tree and to request those interrupts.
U-Boot itself does not have interrupt-driven handlers, so just provide a
means to read and clear an interrupt. This can be useful to handle
peripherals which must use an interrupt to determine when data is
available, for example.
Bring over the basic binding file as well, from Linux v5.4. Note that the
older binding is not supported in U-Boot; the newer 'special form' must be
used.
Add a simple test of the new functionality.
Add a new device-tree property to control the colour depth. At present we
support 16bpp and 32bpp.
While we are here, update the code to use livetree.
Reviewed-by: Anatolij Gustschin <agust@denx.de>
Bring in this file from Linux v5.4.
DS3232 is an i2c RTC with 236 bytes of battery-backed SRAM.
Add an RTC driver for DS3232 device, which provides time and
date support. Also read and write functions are provided,
which can be used to access the SRAM memory.
Signed-off-by: Nandor Han <nandor.han@vaisala.com>
Full conversion to dm for all boards, legacy code removed.
Signed-off-by: Angelo Durgehello <angelo.dureghello@timesys.com>
Bring in the following merges:
commit 8fbbec12f7d2c18f8883f3371cfca74a98b5dd87
Merge: 87f69f467a83 63618e71e89b
Author: Tom Rini <trini@konsulko.com>
Date: Fri Jan 3 09:48:47 2020 -0500
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-fsl-qoriq into next
- updates and fixes on ls1028a, lx2, ls1046a, MC-DPSPARSER support
commit 87f69f467a8335b171c71bf217d2625d515acd7c
Merge: c0912f9bbfb2 4466b9970319
Date: Tue Dec 24 08:18:19 2019 -0500
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-mpc85xx into next
- Enable DM driver on ppc/km boards
- Enable DM_USB for some of NXP powerpc platforms: P5040, T4240, T208x,
T104x, P4080, P2041, P2020, P1020, P3041
- Some updates in mpc85xx-ddr driver, km boards
commit c0912f9bbfb26dd03d189953678691b799d35b6e
Merge: 533c9f5714bd a1d6dc3f8407
Date: Wed Dec 18 07:20:19 2019 -0500
Merge branch 'next' of https://gitlab.denx.de/u-boot/custodians/u-boot-x86 into next
- Various x86 common codes updated for TPL/SPL
- I2C designware driver updated for PCI
- ICH SPI driver updated to support Apollo Lake
- Add Intel FSP2 base support
- Intel Apollo Lake platform specific drivers support
- Add a new board Google Chromebook Coral
commit 533c9f5714bdba79dc6f2629284d4c1a08a611d1
Merge: 553cb0688782 033e18b47bd0
Date: Tue Dec 17 07:53:08 2019 -0500
Merge tag '20191217-for-next' of https://gitlab.denx.de/u-boot/custodians/u-boot-i2c into next
i2c: for next
- misc: i2c_eeprom:
Add partition support and add ability to query size
of eeprom device and partitions
- i2c common:
add support for offset overflow in to address and add
sandbox tests for it.
commit 553cb06887825314e74a9bdac337467c77d1db88
Merge: f39abbbc531e b4f98b3b16ec
Date: Thu Dec 12 08:18:59 2019 -0500
Merge tag 'dm-next-13dec19' of https://gitlab.denx.de/u-boot/custodians/u-boot-dm into next
buildman improvements including toolchain environment feature
sandbox unicode support in serial
Add a GPIO driver which uses the pinctrl driver to access the pad
information. This driver relies on the GPIO nodes being subnodes to the
pinctrl device.
Recent Intel SoCs share a pinctrl mechanism with many common elements. Add
an implementation of this core functionality, allowing SoC-specific
drivers to avoid adding common code.
As well as a pinctrl driver this provides a GPIO driver based on the same
code.
Once other SoCs use this driver we may consider moving more properties to
the device tree (e.g. the community info and pad definitions).
At present PCI auto-configuration happens in U-Boot both before and after
relocation. This is a waste of time and may mess up static addresses used
in board_init_f(). Adjust the code to supporting doing auto-configuration
once, after relocation, under control of a device-tree property.
This is needed for Apollo Lake for debugging the silicon-init code. Once
the UART is moved to a different MMIO address the debug UART does not work
and any debug output in Apollo Lake's arch_fsp_init_r() causes a hang.
Commit 656d8da9d2 (doc: Remove duplicated documentation directory) got
rid of most of Documentation/. But there's still an obviously useless
.gitignore left behind.
Also, there's a copy of the linux kernel's net/ethernet.txt binding
imported from v5.0, while the existing one in doc/ is from 4.0-rc1. So
replace the latter by the former, and making Documentation/ finally
empty.
A couple of optional properties have been introduced for Aquantia PHY
allowing the driver to set up wiring related configuration points that
are otherwise driven by firmware.
Signed-off-by: Alex Marginean <alexandru.marginean@nxp.com>
It defines that PHY nodes must be children on MDIO bus nodes and defines
the only required property in U-Boot, reg. This property along with the
example provided are copied over from Linux.
Based on commit 980066e6d964 ("dt-bindings: phy: dp83867: Add documentation
for disabling clock output") of mainline linux kernel.
The clock output is generally only used for testing and development and not
used to daisy-chain PHYs. It's just a source of RF noise afterward.
Add a mux value for "off". I've added it as another enumeration to the
output property. In the actual PHY, the mux and the output enable are
independently controllable. However, it doesn't seem useful to be able
to describe the mux setting when the output is disabled.
Document that PHY's default setting will be left as is if the property
is omitted.
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
support parse regulator standard property:
regulator-off-in-suspend;
regulator-init-microvolt;
regulator-suspend-microvolt:
regulator_get_suspend_enable
regulator_set_suspend_enable
regulator_get_suspend_value
regulator_set_suspend_value
Signed-off-by: Joseph Chen <chenjh@rock-chips.com>
Signed-off-by: Elaine Zhang <zhangqing@rock-chips.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Add DT binding documentation for DDR sub system present on J721E device.
- Assorted cleanups
- FAT bugfixes
- mediatek platform updates
Add support for CDCE913/925/937/949 family of devices. These are modular
PLL-based low cost, high performance, programmable clock synthesizers,
multipliers and dividers. They generate up to 9 output clocks from a
single input frequency. The initial version of the driver does not
support programming of the PLLs, and thus they run in the bypass mode
only. The code is loosely based on the linux kernel cdce9xx driver.
This adds a document for tphy which supports physical layer
functionality for a number of controllers on MediaTek SoCs,
such as, USB2.0, USB3.0, PCIe, and SATA.
Signed-off-by: Ryder Lee <ryder.lee@mediatek.com>
This adds a document for MT7623 PCIe controller.
Some Texas Instruments K3 family of SoCs have one of more Digital Signal
Processor (DSP) subsystems that are comprised of either a TMS320C66x
CorePac and/or a next-generation TMS320C71x CorePac processor subsystem.
Add the device tree bindings document for the C66x DSP devices on these
SoCs. The added example illustrates the DT nodes for the first C66x DSP
device present on the K3 J721E family of SoCs.
Signed-off-by: Suman Anna <s-anna@ti.com>
The Texas Instruments K3 family of SoCs have one of more dual-core
Arm Cortex R5F processor subsystems/clusters (R5FSS). Add the device
tree bindings document for these R5F subsystem devices. These R5F
processors do not have an MMU, and so require fixed memory carveout
regions matching the firmware image addresses. The nodes require more
than one memory region, with the first memory region used for DMA
allocations at runtime. The remaining memory regions are reserved
and are used for the loading and running of the R5F remote processors.
The added example illustrates the DT nodes for the single R5FSS device
present on K3 AM65x family of SoCs.
This patch adds a separate driver for the MDIO interface of the
Marvell Ethernet controllers based on driver model. There are two
reasons to have a separate driver rather than including it inside
the MAC driver itself:
*) The MDIO interface is shared by all Ethernet ports, so a driver
must guarantee non-concurrent accesses to this MDIO interface. The
most logical way is to have a separate driver that handles this
single MDIO interface, used by all Ethernet ports.
*) The MDIO interface is the same between the existing mv643xx_eth
driver and the new mvneta/mvpp2 driver. Even though it is for now
only used by the mvneta/mvpp2 driver, it will in the future be
used by the mv643xx_eth driver as well.
This driver supports SMI IEEE for 802.3 Clause 22 and XSMI for IEEE
802.3 Clause 45.
This patch also adds device tree binding for marvell MDIO driver.
Signed-off-by: Ken Ma <make@marvell.com>
Signed-off-by: Alex Marginean <alexm.osslist@gmail.com>
Adds a binding document for mdio. A notable deviation from corresponding
Linux binding is the introduction of device-name optional property, which
can be used to name MDIO buses. Two reset optional properties described
by Linux binding are also not present as they don't seem to be used in
U-Boot at this time.
Add precision for disabled fixed clock in stm32mp1 binding.
