path: root/doc/chromium
2018-01-15doc: fix incorrect usage of DT node unit addressAndre Przywara
The DT spec demands a unit-address in a node name to match the "reg" property in that node. Newer dtc versions will throw warnings if this is not the case. Fix all occurences in various documentation files where this was not observed, to not give bad examples to the reader. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2017-06-09rockchip: jerry: Add a .its file for chromiumSimon Glass
Add a sample .its file for booting U-Boot on a jerry Chromebook. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-09README: Add instructions for chain-loading U-BootSimon Glass
Most Chromebooks support chain-loading U-Boot but instructions are somewhat scattered. Add a README to hold this information within the U-Boot tree. Also add the standard developer keys to simplify the instructions, since they are small. For now this only supports nyan-big. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-09tegra: nyan-big: Add a .its file for chromiumSimon Glass
Add a sample .its file for booting U-Boot on a nyan-big Chromebook. Signed-off-by: Simon Glass <sjg@chromium.org>
