Add example command how to compile U-Boot and add new documentation section
describing how to enable early debug UART and verbose log output for N900.
Signed-off-by: Pali Rohár <pali@kernel.org>
Switch to use binman pack images
Signed-off-by: Oliver Graute <oliver.graute@kococonnector.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Switch to use binman to pack images
Reviewed-by: Fabio Estevam <festevam@denx.de>
The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
This adds support for the Kontron Electronics SoM SL i.MX8MM OSM-S
and the matching baseboard BL i.MX8MM OSM-S.
The SoM hardware complies to the Open Standard Module (OSM) 1.0
specification, size S (https://sget.org/standards/osm).
The existing board configuration for the non-OSM SoM is reused and
allows to detect the SoM variant at runtime.
Signed-off-by: Frieder Schrempf <frieder.schrempf@kontron.de>
Initial commit of Librem5 u-boot and SPL
Signed-off-by: Angus Ainslie <angus@akkea.ca>
Co-developed-by: Sebastian Krzyszkowiak <sebastian.krzyszkowiak@puri.sm>
Signed-off-by: Sebastian Krzyszkowiak <sebastian.krzyszkowiak@puri.sm>
Disable UBI fastmap support which is not supported by original Maemo 5
kernel and explicitly set UBI BEB limit to 10%, which is the value used by
original Maemo 5 kernel. U-Boot default value is 20%.
The ELF U-Boot image produced by qemu-riscv64_smode_defconfig can be
used to boot with QEMU and KVM.
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
https://source.denx.de/u-boot/custodians/u-boot-amlogic
- fixup error on efuse commands return
- add documentation on boot flow
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
u-boot-imx-20220726
i.MX for 2022.10
- Added i.MX93 architecture
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/12891
Add support for Qualcomm QCS404 SoC based evaluation board.
Features:
- Qualcomm Snapdragon QCS404 SoC
- 1GiB RAM
- 8GiB eMMC, uSD slot
U-boot is chain loaded by ABL in 64-bit mode as part of boot.img.
For detailed build and boot instructions, refer to
doc/board/qualcomm/qcs404.rst.
Signed-off-by: Sumit Garg <sumit.garg@linaro.org>
Add support for 96Boards Dragonboard 845C aka Robotics RB3 development
platform. This board complies with 96Boards Open Platform Specifications.
Features:
- Qualcomm Snapdragon SDA845 SoC
- 4GiB RAM
- 64GiB UFS drive
doc/board/qualcomm/sdm845.rst, board: dragonboard845c.
Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
Add instructions to build and boot from QSPI Flash
Signed-off-by: Mamta Shukla <mamta.shukla@leica-geosystems.com>
Signed-off-by: Thomas Haemmerle <thomas.haemmerle@leica-geosystems.com>
Tested-by: Adam Ford <aford173@gmail.com>
Add support for hardware watchdog timer for Amlogic SoCs.
This driver has been heavily inspired by his Linux equivalent
(meson_gxbb_wdt.c).
Reviewed-by: Jerome Brunet <jbrunet@baylibre.com>
Reviewed-by: Neil Armstrong <narmstrong@baylibre.com>
Signed-off-by: Philippe Boos <pboos@baylibre.com>
The MT7621 requires external binary blob being executed during u-boot's
boot-up flow. It's necessary to provide a guide here for users to correctly
build the u-boot.
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
Add a "secure" version of STM32 boards based on SCMI when RCC_TZCR.TZEN=1.
Only boards provided by STMicroelectronics are concerned:
-STM32MP157A-DK1
-STM32MP157C-DK2
-STM32MP157C-ED1
-STM32MP157C-EV1
The resources secured by RCC_TZCR.TZEN=1 are managed by OP-TEE
and the associated SCMI services, reset and clock.
These device trees are only supported with stm32mp15_defconfig,
with OP-TEE, SCMI and without SPL support.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
This is a preliminary documentation introducing different
boot sequences, and notably the recovery mode.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Reviewed-by: Mattijs Korpershoek <mkorpershoek@baylibre.com>
Link: https://lore.kernel.org/r/20220706093649.3261229-1-narmstrong@baylibre.com
Add in U-Boot documentation the quick instruction to
setup the STMicroelectronics STM32MP13x boards.
Add info of boot flow and build steps for AM62x SK.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
Reviewed-by: Bryan Brattlof <bb@ti.com>
Update author email address with the one dedicated to
upstream activities.
Set kernel_comp_addr_r and kernel_comp_size for compressed kernel.
Adjust existing addresses for ramdisk, so that kernel_comp_addr_r
comes before the ramdisk image, since the decompressed kernel size
is known to us. This way we can allow big ramdisk image to be loaded.
Update unleashed.rst to remove the manual environment configuration
for compressed kernel boot.
Reviewed-by: Leo Yu-Chi Liang <ycliang@andestech.com>
Add documentation for STM32 MCUs (F4, F7 and H7 series).
Signed-off-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
- Add AXG support for SARADC, including minimal ao-clk driver
- Update Amlogic documentation for Matrix & Jethub D1
Signed-off-by: Vyacheslav Bocharov <adeep@lexina.in>
[narmstrong: removed trailing whitespaces and fixed sphinx build error]
Link: https://lore.kernel.org/r/20220426052633.3027932-2-adeep@lexina.in
Link: https://lore.kernel.org/r/20220426052633.3027932-1-adeep@lexina.in
U-Boot now supports the M1 Ultra SoC as found in the new Mac Studio.
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
The imx8mn_evk target have been converted to use binman.
With the binman approach the ATF load address is described via
devicetree, so remove the now unneeded instruction of exporting
ATF_LOAD_ADDR.
Signed-off-by: Fabio Estevam <festevam@denx.de>
Drop Apalis iMX8X platform as it never left sample state and is no
longer supported.
Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
Add rk3066 Rikomagic MK808 to the list of
mainline supported Rockchip boards.
Include instructions for creating and programming
images to NAND and SD card.
Signed-off-by: Johan Jonker <jbx6244@gmail.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
There are several PX30/RK3326 boards in use without
mentioning in rockchip.rst. Add boards and examples.
With more text coming to the rockchip.rst document,
give it a restyle first.
Changed:
sort build examples alphabetically
add git clone example
fix bash examples
fix phrases (grammer)
fix typos
Introduce BSH SystemMaster (SMM) S2 board family, which consists of:
iMX8MN SMM S2 and iMX8MN SMM S2 PRO boards.
Add support for iMX8MN BSH SMM S2 board:
- 256 MiB DDR3 RAM
- 512MiB Nand
- USBOTG1 peripheral - fastboot.
- 100Mbit Ethernet
Add support for iMX8MN BSH SMM S2 PRO board:
- 512 MiB DDR3 RAM
- 8 GiB eMMC
- 100Mbit Ethernet
Signed-off-by: Ariel D'Alessandro <ariel.dalessandro@collabora.com>
Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com>
Provide settings for enabling the debug UART of the virt machine on
RISC-V QEMU.
U-boot is intended to replace linux kernel in android boot image(ABL), and
it's FIT payload to replace initramfs file. The boot process is similar to
boot image with linux:
- android bootloader (ABL) unpacks android boot image
- ABL sets `linux,initrd-start property` in chosen node in unpacked FDT
- ABL sets x0 register to FDT address, and passes control to u-boot
- u-boot reads x0 register, and stores it in `prevbl_fdt_addr` env variable
- u-boot reads `linux,initrd-start` property,
and stores it in `prevbl_initrd_start_addr`
In this way, u-boot bootcmd relies on `prevbl_initrd_start_addr` env
variable, and boils down to `bootm $prevbl_initrd_start_addr`.
If more control on boot process is desired, pack a boot script in
FIT image, and put it to default configuration
What done:
- Rearrange defconfig option order
- Add CONFIG_SAVE_PREV_BL_* options
- Doc updates:
- remove wrong SBOOT memory corruption note, because
memory is changed during u-boot bringup process,
not by SBOOT
- put payload on ramdisk place in abl boot image
creation step
Signed-off-by: Dzmitry Sankouski <dsankouski@gmail.com>
What done:
- strip unneeded config options
- add FIT image support
- add framebuffer node, u-boot logo and video console
- increase LMB_MAX_REGIONS, to store all linux dtb reserved memory regions
- add linux kernel image header
Uart driver causes hang, when u-boot is used in android boot image instead
of linux. Temporary disable console driver, until investigated and fixed.
Cc: Ramon Fried <rfried.dev@gmail.com>
This adds support for booting entirely from JTAG while using a
hard-coded RCW. With these steps, it is not necessary to program a
"good" RCW using CodeWarrior. The method here can be performed with any
JTAG adapter supported by OpenOCD, including the on-board CMSIS-DAP
(albeit very slowly).
These steps require LS1046A support in OpenOCD, which was added in [1].
[1] https://sourceforge.net/p/openocd/code/ci/5b70c1f679755677c925b4e6dd2c3d8be4715717/
Signed-off-by: Sean Anderson <sean.anderson@seco.com>
[trini: Add reference to doc/board/nxp/ls1046ardb.rst]
This adds some instructions for enabling the debug uart, including the
correct address and clock rate.
This adds some additional info about booting from different sources,
including the correct switch positions.
This converts the readme for this board to rST. I have tried not to
change any semantics from the original (though I did convert MB to M).
The ARMv8-R64 architecture introduces optional VMSA (paging based MMU)
support in the EL1/0 translation regime, which makes that part mostly
compatible to ARMv8-A.
Add a new board variant to describe the "BASE-R64" FVP model, which
inherits a lot from the existing v8-A FVP support. One major difference
is that the memory map in "inverted": DRAM starts at 0x0, MMIO is at
2GB [1].
* Create new TARGET_VEXPRESS64_BASER_FVP target, sharing most of the
exising configuration.
* Implement inverted memory map in vexpress_aemv8.h
* Create vexpress_aemv8r defconfig
* Provide an MMU memory map for the BASER_FVP
* Update vexpress64 documentation
At the moment the boot-wrapper is the only supported secure firmware. As
there is no official DT for the board yet, we rely on it being supplied
by the boot-wrapper into U-Boot, so use OF_HAS_PRIOR_STAGE, and go with
a dummy DT for now.
[1] https://developer.arm.com/documentation/100964/1114/Base-Platform/Base---memory/BaseR-Platform-memory-map
Signed-off-by: Peter Hoyes <Peter.Hoyes@arm.com>
[Andre: rebase and add Linux kernel header]
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
[trini: Add MAINTAINERS entry for Peter]
Add documentation about the different configuration files for the
RaspberryPi board family.
Signed-off-by: Matthias Brugger <mbrugger@suse.com>
Reviewed-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Add section how to run U-Boot in n900 qemu machine.
It add documentation on licencing & provides links to the amlogic-boot-fip
pre-built files collections.
The doc used GXL instructions, which couldn't work on GXBB SoCs.
Add support for Kevin, an RK3399-based convertible chromebook that is
very similar to Bob. This patch is mostly based on existing support for
Bob, with only minor changes for Kevin-specific things.
Unlike other Gru boards, coreboot sets Kevin's center logic to 925 mV,
so adjust it here in the dts as well. The rk3399-gru-kevin devicetree
has an unknown event code reference which has to be defined, set it
to the Linux counterpart. The new defconfig is copied from Bob with the
diffconfig:
DEFAULT_DEVICE_TREE "rk3399-gru-bob" -> "rk3399-gru-kevin"
DEFAULT_FDT_FILE "rockchip/rk3399-gru-bob.dtb" -> "rockchip/rk3399-gru-kevin.dtb"
VIDEO_ROCKCHIP_MAX_XRES 1280 -> 2400
VIDEO_ROCKCHIP_MAX_YRES 800 -> 1600
+TARGET_CHROMEBOOK_KEVIN y
With this Kevin can boot from SPI flash to a usable U-Boot prompt on the
display with the keyboard working, but cannot boot into Linux for
unknown reasons.
eMMC starts in a working state but fails to re-init, microSD card works
but at a lower-than-expected speed, USB works but causes a hang on
de-init. There are known workarounds to solve eMMC and USB issues.
Cc: Marty E. Plummer <hanetzer@startmail.com>
[Alper: commit message, resync config with Bob, update MAINTAINERS,
add to Rockchip doc, add Kconfig help message, set regulator]
Co-developed-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
"kendryte" is the marketing name for the K210 RISC-V SoC produced by
Canaan Inc. Rather than "kendryte,k210", use the usual "canaan,k210"
vendor,SoC compatibility string format in the device tree files and
use the SoC name for file names.
With these changes, the device tree files are more in sync with the
Linux kernel DTS and drivers, making uboot device tree usable by the
kernel.
Signed-off-by: Damien Le Moal <damien.lemoal@opensource.wdc.com>
Signed-off-by: Niklas Cassel <niklas.cassel@wdc.com>
u-boot-spl.bin is built in spl/.
They are no longer needed, because we now have proper driver support for
the sl28cpld management controller.
Signed-off-by: Michael Walle <michael@walle.cc>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
