path: root/doc/SPI/README.ftssp010_spi_test
2014-01-11spi: Add Faraday SPI controller supportKuo-Jung Su
The Faraday FTSSP010 is a multi-function controller which supports I2S/SPI/SSP/AC97/SPDIF. However This patch implements only the SPI mode. NOTE: The DMA and CS/Clock control logic has been altered since hardware revision 1.19.0. So this patch would first detects the revision id of the underlying chip, and then switch to the corresponding software control routines. Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com> Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> CC: Tom Rini <trini@ti.com>
