path: root/doc/README.x86
2015-03-24x86: Add queensbay fsp patch information in README.x86Bin Meng
The FSP release version 001 for Intel Queensbay has a bug which could cause random endless loop during the FspInit call. This bug was published by Intel although Intel did not describe any details. Describe this information in the x86 doc so that U-Boot Queensbay support is invulnerable. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-06x86: Add Intel Galileo instructions in README.x86Bin Meng
Add some instructions about building U-Boot for Intel Galileo board. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-06x86: Add support for Intel Minnowboard MaxSimon Glass
This is a relatively low-cost x86 board in a small form factor. The main peripherals are uSD, USB, HDMI, Ethernet and SATA. It uses an Atom 3800 series CPU. So far only the dual core 2GB variant is supported. This uses the existing FSP support. Binary blobs are required to make this board work. The microcode update is included as a patch (all 3000 lines of it). Change-Id: I0088c47fe87cf08ae635b343d32c332269062156 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-02-06x86: Add some documentation on how to port U-Boot on x86Simon Glass
Some information has been gleaned on tools and procedures for porting U-Boot to different x86 platforms. Add a few notes to start things off. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-02-05x86: Add an option to enabling building a ROM fileSimon Glass
Rather than requiring the Makefile to be modified, provide a build option to enable the ROM to be built. We cannot do this by default since it requires binary blobs. Without these the build will fail. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-01-13x86: Update README.x86 for coreboot supportBin Meng
Update README.x86 to include new build instructions for U-Boot as the coreboot payload and testing considerations with coreboot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Add an 'mtrr' command to list and adjust MTRRsSimon Glass
It is useful to be able to see the MTRR setup in U-Boot. Add a command to list the state of the variable MTRR registers and allow them to be changed. Update the documentation to list some of the available commands. This does not support fixed MTRRs as yet. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2014-12-18x86: Add a README.x86 for U-Boot on x86 supportBin Meng
Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (Use 'Link' as the name for the Chromebook Pixel consistently) Change-Id: I158c88653978ff212334f6d4ffeaf49fa81baefe
