path: root/doc/README.usb
2017-09-08usb: doc: update README.usb for new config optionsChris Packham
A number of the config options for USB networking have been migrated to Kconfig. Update README.usb to reflect this. Signed-off-by: Chris Packham <judge.packham@gmail.com>
2017-07-03powerpc: remove 4xx supportHeiko Schocher
There was for long time no activity in the 4xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 4xx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2014-03-12usb: net: update README.usb to list all USB ethernet optionsGerhard Sittig
- extend the discussion of USB network related config options such that all available adapter drivers are listed, and that the 'usb' command for the interactive prompt and scripting becomes available - suggest to *not* put individual IP configuration parameters into the exectuable, but instead to put them into external environment or fetch them from network Signed-off-by: Gerhard Sittig <gsi@denx.de> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2012-12-17usb documentation: fix typoRichard Genoud
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-11Minor coding style cleanup.Wolfgang Denk
2011-08-08Add documentation for USB Host NetworkingSimon Glass
This describes what it is for, devices supported, how to enable for your board in U-Boot, setting up the server, and notes about MAC addresses. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Eric BĂ©nard <eric@eukrea.com>
2011-02-19Add USB host ethernet adapter supportSimon Glass
This adds support for using USB Ethernet dongles in host mode. This is just the framework - drivers will come later. A new config option called CONFIG_USB_HOST_ETHER can be defined in board config files to switch this on. The was originally written by NVIDIA and was cleaned up for release by the Chromium authors. Signed-off-by: Simon Glass <sjg@chromium.org>
2007-07-10disk/ doc/ lib_*/ and tools/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
