path: root/doc/README.trace
2018-11-26sandbox: Drop the deprecated 'sb' commandSimon Glass
The old 'sb' command was deprecated in 2015 and replaced with 'host'. Remove the remaining users and the command, so that the name is available for other purposes. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-06-26Add trace librarySimon Glass
Add a library which supports tracing of execution using built-in gcc features and a microsecond timer. This can be used to record a list of function which are executed, along with a timestamp for each. Later this information can be sent to the host for processing. Signed-off-by: Simon Glass <sjg@chromium.org>
