path: root/doc/README.standalone
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-01-12riscv: doc: Add relative doc to describe RISC-VRick Chen
Add documents to describe NX25 and AE250. Also update other documents for RISC-V. Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Signed-off-by: Greentime Hu <green.hu@gmail.com>
2015-01-29Export redesignMartin Dorwig
this is an atempt to make the export of functions typesafe. I replaced the jumptable void ** by a struct (jt_funcs) with function pointers. The EXPORT_FUNC macro now has 3 fixed parameters and one variadic parameter The first is the name of the exported function, the rest of the parameters are used to format a functionpointer in the jumptable, the EXPORT_FUNC macros are expanded three times, 1. to declare the members of the struct 2. to initialize the structmember pointers 3. to call the functions in stubs.c Signed-off-by: Martin Dorwig <dorwig@tetronik.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (resending to the list since my tweaks are not quite trivial)
2014-10-27doc: fix README.standaloneMasahiro Yamada
Since commit fe1378a961e5 (ARM: use r9 for gd), r9 register is used on ARM to hold global_data. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2011-10-22doc/README: documents and readme for NDS32 archMacpaul Lin
Documents and READMEs for NDS32 architecture. It patch also provides usage of SoC AG101 and board ADP-AG101. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2010-05-28nios2: fix r15 issue for gcc4Thomas Chou
The "-ffixed-r15" option doesn't work well for gcc4. Since we don't use gp for small data with option "-G0", we can use gp as global data pointer. This allows compiler to use r15. It is necessary for gcc4 to work properly. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2009-09-02Blackfin: change global data register from P5 to P3Robin Getz
Since the Blackfin ABI favors higher scratch registers by default, use the last scratch register (P3) for global data rather than the first (P5). This allows the compiler's register allocator to use higher number scratch P registers, which in turn better matches the Blackfin instruction set, which reduces the size of U-Boot by more than 1024 bytes... Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-15Merge branch 'master' of git://www.denx.de/git/u-boot-blackfinWolfgang Denk
Conflicts: Makefile doc/README.standalone Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-02-14PPC: Use r2 instead of r29 as global data pointerWolfgang Denk
R29 was an unlucky choice as with recent toolchains (gcc-4.2.x) gcc will refuse to use load/store multiple insns; instead, it issues a list of simple load/store instructions upon function entry and exit, resulting in bigger code size, which in turn makes the build for a few boards fail. Use r2 instead. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-02-04add some more Blackfin docsMike Frysinger
2003-07-26* Allow crc32 to be used at address 0x000wdenk
* Provide consistent interface to standalone applications to access the 'global_data' structure Provide a doc/README.standalone more useful to users/developers. * Make IceCube MGT5100 FEC driver work
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
