path: root/doc/README.sha1
2016-07-31Drop references to MAKEALL in the documentationSimon Glass
It is confusing to mention MAKEALL when it is not the normal way of building U-Boot anymore. Update the documentation to suit. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2007-07-12Update CHANGELOG, minor coding style cleanup.Wolfgang Denk
2007-07-11[PCS440EP] - Show on the DIAG LEDs, if the SHA1 check failedHeiko Schocher
- now the Flash ST M29W040B is supported (not tested) - fix the "led" command - fix compile error, if BUILD_DIR is used Signed-off-by: Heiko Schocher <hs@denx.de>
