path: root/doc/README.scrapyard
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-11ppc: Remove PCIPPC2 and PCIPPC6 boardsStefan Roese
These boards seem to be unmaintained for quite some time. So lets remove support for them completely. This also cleans up some common drivers/files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Guillaume Alexandre <guillaume.alexandre@gespac.ch> Acked-by: Wolfgang Denk <wd@denx.de>
2013-02-28ARM: ns9750dev: remove remainders of dead boardWolfgang Denk
Commit 8b710b1 started removing code for the unmaintained "ns9750dev" board; the board support is still broken, and not included anywhere in the Makefile or boards.cfg. Remove the remaining dead code. Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-02-28README.scrapyard: add missing commit IDsWolfgang Denk
Now that the patches have made it into mainline, we can also add the commit IDs. Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-10-28PPC: remove dead boards (AMX860, c2mon, ETX094, IAD210, LANTEC, SCM)Wolfgang Denk
These boards have long reached EOL, and there has been no indication of any active users of such hardware for years. Get rid of the dead weight. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Wolfgang Grandegger <wg@denx.de>
2012-10-26arm: arm925t: remove SX1 boardAlbert ARIBAUD
SX1 does not build properly by itself, is not built as part of MAKEALL arm or MAKEALL -a arm, and is only present in Makefile, not boards.cfg. As it also has no entry in MAINTAINERS, it is orphan and non-functional. Remove it. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-05MPC85xx: remove support for TQM85xx boardsWolfgang Denk
Due to grown code sizes the TQM85xx boards don't build any more with some older tool chains (like ELDK 4.2). As these boards have long reached EOL it seems a waste of effort trying to fix them. The vendor has agreed to drop support for them, too. So let's get rid of them. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> cc: Kim Phillips <kim.phillips@freescale.com> Acked-by: Stefan Roese <sr@denx.de>
2012-09-18ARM: Remove apollon boardMarek Vasut
This board is the only board that still sticks to OneNAND IPL. Remove this board, since we have SPL around for a while and OneNAND is well supported in the SPL framework. The board can be revived if necessary. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Tom Rini <trini@ti.com>
2011-12-12MIPS: remove broken "tb0229" boardWolfgang Denk
The "tb0229" board has long been unmaintained, and is broken. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-08MPC850: remove obsolete "rmu" BoardWolfgang Denk
The "rmu" board has long been unmaintained, and is broken. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-08MPC8240: remove obsolete "OXC" boardWolfgang Denk
The OXC board has long been unmaintained, and is broken. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-08MPC7xx: remove obsolete "BAB7xx" boardWolfgang Denk
The BAB7xx boards are almost deceased. They cause build warnings, an it's not worth the effort to fix these. Remove the dead body. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Frank Gottschling <fgottschling@eltec.de>
2011-12-06PXA: Drop XM250 boardMarek Vasut
The board is unmaintained and maintainer doesn't respond. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2011-12-06PXA: Drop PLEB2 boardMarek Vasut
2011-12-06PXA: Drop CRADLE boardMarek Vasut
2011-12-06PXA: Drop CERF250 boardMarek Vasut
2011-11-29Fix Stelian's email addressStelian Pop
Change my old email address which is no longer valid. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-10-23MPC85xx: remove broken "mpq101" boardWolfgang Denk
The board stopped building some time ago, and the board maintainer agrtees to drop it - see http://article.gmane.org/gmane.comp.boot-loaders.u-boot/112674 Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Alex Dubov <oakad@yahoo.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Kumar Gala <galak@kernel.crashing.org>
2011-09-28doc/README.scrapyard: Update board removal commit IDsWolfgang Denk
2011-09-27ARM: remove broken "ixdp425" and "ixpdg425" boardsAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Stefan Roese <sr@denx.de>
2011-09-07ARM: PXA: remove broken "zylonite" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Marek Vasut <marek.vasut@gmail.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-09-07ARM: remove broken "shannon" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Rolf Offermanns <rof@sysgo.de>
2011-09-07ARM: remove broken "modnet50" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Thomas Elste <info@elste.org>
2011-09-07ARM: remove broken "lpc2292sodimm" board.Wolfgang Denk
2011-09-07ARM: remove broken "lart" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Alex Züpke <azu@sysgo.de>
2011-09-07ARM: remove broken "impa7" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Marius Gröger <mag@sysgo.de>
2011-09-07ARM: remove broken "gcplus" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: George G. Davis <gdavis@mvista.com>
2011-09-07ARM: remove broken "evb4510" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Curt Brune <curt@cucy.com>
2011-09-07ARM: remove broken "ep7312" board.Wolfgang Denk
2011-09-07ARM: remove broken "dnp1110" board.Wolfgang Denk
2011-09-07ARM: remove broken "SMN42" board.Wolfgang Denk
2011-09-07doc/README.scrapyard: Update commit IDs or board removalsWolfgang Denk
2011-09-04ARM: remove broken "at91rm9200dk" boardWolfgang Denk
2011-09-04ARM: remove broken "m501sk" boardWolfgang Denk
2011-09-04ARM: remove broken "kb9202" boardWolfgang Denk
2011-09-04ARM: remove broken "csb637" boardWolfgang Denk
2011-09-04ARM: remove broken "cmc_pu2" boardWolfgang Denk
2011-09-04ARM: remove broken "at91cap9adk" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stelian Pop <stelian.pop@leadtechdesign.com>
2011-09-04ARM: remove broken "voiceblue" boardWolfgang Denk
2011-09-04ARM: remove broken "smdk2400" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Gary Jennejohn <garyj@denx.de>
2011-09-04ARM: remove broken "sbc2410x" boardWolfgang Denk
2011-09-04ARM: remove broken "netstar" boardWolfgang Denk
2011-09-04ARM: remove broken "mx1fs2" boardWolfgang Denk
2011-09-04ARM: remove broken "lpd7a40x" boardsWolfgang Denk
Remove lpd7a400 and lpd7a404 boards. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-04ARM: remove broken "edb93xx" boardsWolfgang Denk
Remove edb9301, edb9302, edb9302a, edb9307, edb9307a, edb9312, edb9315 and edb9315a boards. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-04ARM: remove broken "B2" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andrea Scian <andrea.scian@dave-tech.it>
2011-09-04ARM: remove broken "armadillo" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Rowel Atienza <rowel@diwalabs.com>
2011-09-04ARM: remove broken "assabet" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: George G. Davis <gdavis@mvista.com>
2011-06-22ARM: drop unsupported 'trab' boardWolfgang Denk
The 'trab' board configuration is broken, and there is nobody who is interested and willing to fix it. Drop it. This includes support for VFD displays which have always been used by this board only. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-06-01Move wepep250,delta,xsengine to scrapyardMarek Vasut
Drop wepep250 board from MAINTAINERS and add all these three boards to doc/README.scrapyard Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
