path: root/doc/README.scrapyard
2017-07-06avr32: Retire AVR32 for goodAndy Shevchenko
AVR32 is gone. It's already more than two years for no support in Buildroot, even longer there is no support in GCC (last version is heavily patched 4.2.4). Linux kernel v4.12 got rid of it (and v4.11 didn't build successfully). There is no good point to keep this support in U-Boot either. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2016-07-16Various, unrelated tree-wide typo fixes.Robert P. J. Day
Fix a number of typos, including: * "compatble" -> "compatible" * "eanbeld" -> "enabled" * "envrionment" -> "environment" * "FTD" -> "FDT" (for "flattened device tree") * "ommitted" -> "omitted" * "overriden" -> "overridden" * "partiton" -> "partition" * "propogate" -> "propagate" * "resourse" -> "resource" * "rest in piece" -> "rest in peace" * "suport" -> "support" * "varible" -> "variable" Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2015-11-10Revive OpenRD targetsAlbert ARIBAUD
Revert commit 7a2c1b13 which dropped OpenRD boards. Assume maintainership of OpenRD. Remove OpenRD from scrapyard. Switch OpenRD to generic board. Switch to Thumb build. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-10-30README.scrapyard: Populate recent ppc4xx removalsTom Rini
2015-10-27ocotea: DropTom Rini
This board has not compiled for me for quite some time due to size constraints, remove. Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2015-10-27taishan: DropTom Rini
2015-10-27ebony: DropTom Rini
2015-10-27taihu: RemoveTom Rini
This board has not compiled for me for quite some time due to size constraints, remove. Cc: John Otken <jotken@softadvances.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2015-10-19doc/README.scrapyard: Add more entriesTom Rini
- Add deletions from August 30 2015. - A few from Sept 12, one from Oct 2nd. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-19doc/README.scrapyard: Populate recent removalsTom Rini
Add in the commit IDs / dates for boards removed on Sept 2nd. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-11Revert "powerpc: ppc4xx: remove lwmon5 support"Stefan Roese
This reverts commit 8fe11b8901a31d11990488c82bc23612589d57be. I'll add support to lwmon5 in the next patch and will remove support for the broken lcd4_lwmon5 as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-02powerpc: mpc85xx: remove stxgp3, stxssa supportMasahiro Yamada
These have not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Dan Malek <dan@embeddedalley.com>
2015-09-02powerpc: mpc5xx: remove cmi_mpc5xx supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-02powerpc: ppc4xx: remove zeus supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Stefan Roese <sr@denx.de>
2015-09-02powerpc: ppc4xx: remove sbc405 supportMasahiro Yamada
2015-09-02powerpc: ppc4xx: remove pcs440ep supportMasahiro Yamada
2015-09-02powerpc: ppc4xx: remove p3p440 supportMasahiro Yamada
2015-09-02powerpc: ppc4xx: remove lwmon5 supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Remove CONFIG_LWMON5 references. (Also, remove undefined CONFIG_WD_MAX_RATE while I am here.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Stefan Roese <sr@denx.de>
2015-09-02powerpc: ppc4xx: remove csb272, csb472 supportMasahiro Yamada
These have not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Tolunay Orkun <torkun@nextio.com>
2015-09-02powerpc: ppc4xx: remove alpr supportMasahiro Yamada
2015-08-20ARM: davinci: remove support for cam_enc_4xxMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2015-06-11README.scrapyard: add entries for dead AVR32 boardsMasahiro Yamada
Some AVR32 boards were dropped by the following commits: 9eb45aabe078 (avr32: delete non generic board favr-32-ezkit) e36930764471 (avr32: delete non generic board hammerhead) c62d2f8fc5c6 (avr32: delete non generic board mimc200) e5354b8a9e2a (avr32: delete non generic board's atstk100{3, 4, 6}) Acked-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-20README.scrapyard: add entries for dead board, T4240EMU and sc3Masahiro Yamada
Follow-up commit 7fc63cca611b (mpc85xx/T4240EMU: Remove T4240EMU board), and commit 27e721564591 (ppc4xx: Remove sc3 board), filling the blank fields. Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-13ARM: at91: remove non-generic boardsMasahiro Yamada
Remove board support for afeb9260, tny_a9260, and sbc35_a9g20. They have not been converted into Generic Board yet. See doc/README.generic-board for details. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2015-03-17powerpc: ppc4xx: remove korat board supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Larry Johnson <lrj@acm.org>
2015-03-17powerpc: mpc5xxx: remove galaxy5200 board supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Eric Millbrandt <emillbrandt@dekaresearch.com>
2015-03-17powerpc: ppc4xx: remove W7OLMC/W7OLMG board supportMasahiro Yamada
They have not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Erik Theisen <etheisen@mindspring.com>
2015-03-17powerpc: mpc5xxx: remove aev, TB5200 board supportMasahiro Yamada
2015-03-17powerpc: ppc4xx: remove JSE board supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Stephen Williams <steve@icarus.com>
2015-03-17powerpc: mpc5xxx: remove BC3450 board supportMasahiro Yamada
2015-02-24ARM: davinci: remove hawkboard supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove tnetv107x board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Chan-Taek Park <c-park@ti.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove a320evb board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Po-Yu Chuang <ratbert@faraday-tech.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove cm4008 and cm41xx board supportMasahiro Yamada
These are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Greg Ungerer <greg.ungerer@opengear.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove dkb board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Lei Wen <leiwen@marvell.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove jadecpu board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Matthias Weisser <weisserm@arcor.de> Acked-by: Marek Vasut <marex@denx.de>
2015-01-23powerpc: remove icecube_5200, Lite5200, cpci5200, mecp5200, pf5200Masahiro Yamada
These boards are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2015-01-23powerpc: mpc5xxx: PM520 board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Josef Wagner <Wagner@Microsys.de>
2015-01-23powerpc: mpc5xxx: remove Total5200 board supportMasahiro Yamada
2015-01-23powerpc: ppc4xx: remove PPChameleonEVB, CATcenter boardsMasahiro Yamada
These boards are still non-generic boards. It is a good thing that we can drop board-specific hack code from drivers/mtd/nand/nand_base.c Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Andrea "llandre" Marson <andrea.marson@dave-tech.it>
2015-01-23powerpc: mpc85xx: remove P2020DS board supportMasahiro Yamada
2015-01-23powerpc: mpc85xx: remove P2020COME board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Ira W. Snyder <iws@ovro.caltech.edu>
2015-01-23powerpc: mpc85xx: remove P1_P2_RDB boardsMasahiro Yamada
These boards are still non-generic boards: P1011RDB, P1022RDB, P2010RDB, P2020RDB Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com>
2015-01-23powerpc: mpc83xx: remove MPC8360ERDK, EMPC8360EMDS supportMasahiro Yamada
These boards are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Dave Liu <daveliu@freescale.com> Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
2015-01-16powerpc: 74xx_7xx: remove 74xx_7xx cpu supportMasahiro Yamada
All the 74xx_7xx boards are still non-generic boards: P3G4, ZUMA, ppmc7xx, ELPPC, mpc7448hpc2 Acked-by: Marek Vasut <marex@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: York Sun <yorksun@freescale.com> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Nye Liu <nyet@zumanetworks.com> Cc: Roy Zang <tie-fei.zang@freescale.com>
2015-01-14README.scrapyard: fill commit and date fieldsMasahiro Yamada
This commit was generated by the following command: scripts/fill_scrapyard.py The commit-ID of CPCIISER4 removal has been fixed by hand because the board was removed by commit 370572601027 (ppc4xx: remove CPCIISER4 board), but it was added to README.scrapyard by commit 9a4018e09a2f (ppc4xx: remove DP405 board). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-01-13ppc4xx: remove some CPCI405 variantsMatthias Fuchs
only keep CPCI4052 Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2015-01-13ppc4xx: remove G2000 boardMatthias Fuchs
