PopMetal is a rockchip rk3288 based board made by ChipSpark, which has
many interface such as HDMI, VGA, USB, micro-SD card, WiFi, Audio and
Gigabit Ethernet.
Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com>
Fennec is a RK3288-based development board with 2 USB ports, HDMI,
micro-SD card, audio and WiFi and Gigabit Ethernet. It also includes
on-board 8GB eMMC and 2GB of SDRAM. Expansion connectors provides access
to display pins, I2C, SPI, UART and GPIOs.
Introduce how to use fastboot feature on rk3288.
evb-3288 board RK3288-based development board with 2 USB ports, HDMI,
VGA, micro-SD card, audio, WiFi and Gigabit Ethernet. It also includes
on-board 8G eMMC and 2GB of SDRAM. Expansion connector provide access to
display pins, I2C, SPI, UART and GPIOs. This add some basic files
required to allow the board to output serial messaged and can run
command(mmc info etc).
evb-rk3288 also supports booting from eMMC or SD card, the default is eMMC.
If we would like to boot from SD card, we have to implement mmc driver
in SPL stage, and get a slightly large SPL binary. Rockchip SoC's
bootrom code has the ability to load spl and u-boot, then boot.
If CONFIG_ROCKCHIP_SPL_BACK_TO_BROM is enabled, the spl will return to
bootrom in board_init_f(), then bootrom loads u-boot binary.
Loading sequence after rework:
bootrom ==> spl ==> bootrom ==> u-boot
Fixed up spelling of U-Boot, boorom, opinion->option, Rochchip:
GPIO, I2C, LCD and HDMI are now implemented. We have more than one PMIC.
There is an implementation to run the CPU at full speed although it does
not seem to make much difference.
Update the README to cover recent developments.
This board includes an RK3288 SoC on a SOM. It can be mounted on a
base-board which provides a wide range of peripherals.
So far this is verified to boot to a prompt from a microSD card. The serial
console works as well as HDMI.
Thanks to Tom Cubie for sending me a board.
This script has proved useful for parsing datasheets and creating register
shift/mask values for use in header files. Include it in case it is useful
for others.
Various updates did not make it through to this board. Also the instructions
for building a SPI image are no-longer correct. Fix these so that Jerry can
boot to a prompt again.
We now using imagename to select rockchip's spl hdr & spl size.
Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com>
show how to packet rk3036 uboot image and boot from SD
Signed-off-by: Lin Huang <hl@rock-chips.com>
Series-to: u-boot
Series-version: 8
Series-cc: Lin Huang <hl@rock-chips.com>
It is easier to paste these into the command line if they are a single
common. Use line continuation instead of separate lines.
MMC support works now, so it can be dropped from the todo
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Instead of creating a rockchip SPL SD card image with 32KB of zeros
which can be written to the start of an SD card, create the images with
only the useful data that should be written to an offset of 32KB on the
SD card.
The first 32 kilobytes aren't needed for bootup and only serve as
convenient way of accidentally obliterating your partition table.
The Radxa Rock pro board is rk3188 based and thus won't work with U-Boot
built for RK3288. Change the documentation to refer to the intended
board, the Radxa Rock 2, which is an RK3288-based design very similar to
the firefly
Add a few notes on how to try out the Rockchip support so far.
