path: root/doc/README.omap3
2015-09-11arm: Remove omap3_mvblx boardSimon Glass
This board has not been converted to generic board by the deadline. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-11-21mtd: nand: omap: add CONFIG_NAND_OMAP_ECCSCHEME for selection of ecc-schemepekon gupta
This patch adds new CONFIG_NAND_OMAP_ECCSCHEME, replacing other distributed CONFIG_xx used for selecting NAND ecc-schemes. This patch aims at solving following issues. 1) Currently ecc-scheme is tied to SoC platform, which prevents user to select other ecc-schemes also supported in hardware. like; - most of OMAP3 SoC platforms use only 1-bit Hamming ecc-scheme, inspite the fact that they can use higher ecc-schemes like 8-bit ecc-schemes with software based error detection (OMAP_ECC_BCH4_CODE_HW_DETECTION_SW). - most of AM33xx SoC plaforms use 8-bit BCH ecc-scheme for now, but hardware supports BCH16 ecc-scheme also. 2) Different platforms use different CONFIG_xx to select ecc-schemes, which adds confusion for user while migrating platforms. - *CONFIG_NAND_OMAP_ELM* which enables ELM hardware engine, selects only 8-bit BCH ecc-scheme with h/w based error-correction (OMAP_ECC_BCH8_CODE_HW) whereas ELM hardware engine supports other ecc-schemes also like; BCH4, and BCH16 (in future). - *CONFIG_NAND_OMAP_BCH8* selects 8-bit BCH ecc-scheme with s/w based error correction (OMAP_ECC_BCH8_CODE_HW_DETECTION_SW). - *CONFIG_SPL_NAND_SOFTECC* selects 1-bit Hamming ecc-scheme using s/w library Thus adding new *CONFIG_NAND_OMAP_ECCSCHEME* de-couples ecc-scheme dependency on SoC platform and NAND driver. And user can select ecc-scheme independently foreach board. However, selection some hardware based ecc-schemes (OMAP_ECC_BCHx_CODE_HW) still depends on presence of ELM hardware engine on SoC. (Refer doc/README.nand) Signed-off-by: Pekon Gupta <pekon@ti.com>
2013-04-08omap_gpmc: add support for hw assisted BCH8Andreas Bießmann
The kernel states: ---8<--- The OMAP3 GPMC hardware BCH engine computes remainder polynomials, it does not provide automatic error location and correction: this step is implemented using the BCH library. --->8--- And we do so in u-boot. This implementation uses the same layout for BCH8 but it is fix. The current provided layout does only work with 64 Byte OOB. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Tom Rini <trini@ti.com> Cc: Ilya Yanok <ilya.yanok@cogentembedded.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Mansoor Ahamed <mansoor.ahamed@ti.com> Cc: Thomas Weber <thomas.weber.linux@googlemail.com>
2011-11-04OMAP3: mvblx: Initial support for mvBlueLYNX-XMichael Jones
Add support for the MATRIX VISION mvBlueLYNX-X, an OMAP3-based intelligent camera. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27omap3: Add interface for omap3 DMASimon Schwarz
Adds an interface to use the OMAP3 DMA. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13omap: gpio: generic changes after changing APISanjeev Premi
This patch contains the generic changes required after change to generic API in the previous patch. Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-02-02OMAP3: add CM-T35 boardMike Rapoport
This patch adds support for CM-T35 board Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-07-07Coding style cleanup; update CHANGELOGWolfgang Denk
2009-06-12Fix a typo in the instructions on using omap3's gpio interface.Tom Rix
Using the example for reading a gpio, shows the problem. NULL should be the gpio number. Signed-off-by: Tom Rix <Tom.Rix@windriver.com> Acked-by: Dirk Behme <dirk.behme@googlemail.com>
2009-06-12OMAP3 Port kernel omap gpio interface.Tom Rix
Port version 2.6.27 of the linux kernel's omap gpio interface to u-boot. The orignal source is in linux/arch/arm/plat-omap/gpio.c See doc/README.omap3 for instructions on use. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-06-12ZOOM2 Add initial support for Zoom2Tom Rix
Zoom2 is a new board from Texas Instruments and LogicPD The logicpd web site is a good source for general information on this board. Please start looking here if the below links are broken. http://www.logicpd.com This is a pdf of the product http://www.logicpd.com/sites/default/files/1012659A_Zoom_OMAP34x-II_MDP_Brief.pdf This is the product description web page http://www.logicpd.com/products/development-kits/texas-instruments-zoom%E2%84%A2-omap34x-ii-mdp This patch provides a zoom2 base target by copying zoom1 and by making some obvious changes. To configure, run make omap3_zoom2_config Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-01-28OMAP3: Add Zoom1 board supportDirk Behme
Support for Zoom MDK with OMAP3430. Details of Zoom MDK available here: http://www.logicpd.com/products/devkit/ti/zoom_mobile_development_kit Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2009-01-28OMAP3: Add Pandora supportDirk Behme
Add Pandora support. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2009-01-28OMAP3: Add EVM boardDirk Behme
Add EVM board support. Signed-off-by: Manikandan Pillai <mani.pillai@ti.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2009-01-28OMAP3: Add Overo boardDirk Behme
Add Overo board support. Signed-off-by: Steve Sakoman <sakoman@gmail.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2009-01-28OMAP3: Add common power code, README, and BeagleBoardDirk Behme
Add BeagleBoard support, common power code and README. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
