path: root/doc/README.mxc_hab
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-08-31tools: add support for setting the CSF into imximageStefano Babic
Add support for setting the CSF (Command Sequence File) pointer which is used for HAB (High Assurance Boot) in the imximage by adding e.g. CSF 0x2000 in the imximage.cfg file. This will set the CSF pointer accordingly just after the padded data image area. The boot_data.length is adjusted with the value from the imximage.cfg config file. The resulting u-boot.imx can be signed with the FSL HAB tooling. The generated CSF block needs to be appended to the u-boot.imx. Signed-off-by: Stefano Babic <sbabic@denx.de>
