path: root/doc/README.mpc85xxads
2016-11-23powerpc: MPC8560ADS: Remove macro CONFIG_MPC8560ADSYork Sun
This macro is no longer used. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8540ADS: Remove macro CONFIG_MPC8540ADSYork Sun
2016-11-23powerpc: mpc8540: Remove macro CONFIG_MPC8540York Sun
Replace CONFIG_MPC8540 with ARCH_MPC8540 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2012-03-27doc: Fix some typos in different filesThomas Weber
adresses/addresses alernate/alternate asssuming/assuming calcualted/calculated enviroment/environment evalutation/evaluation falsh/flash labled/labeled paramaters/parameters Signed-off-by: Thomas Weber <thomas@tomweber.eu> Acked-by: Anatolij Gustschin <agust@denx.de>
2011-01-1485xx boards: Rename CONFIG_DDR_DLL to CONFIG_SYS_FSL_ERRATUM_DDR_MSYNC_INBecky Bruce
This config option is for an erratum workaround; rename it to be more clear. Also, drop it from config files don't need it and were undefining it. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-06-28* Switched default PCI speed for 8540 ADS back to 33MHzMatthew McClintock
* Added comments and a printf to warn that PCI-X won't work at 33MHz Patch by Andy Fleming 17-Mar-2006 Signed-off-by: Andy Fleming <afleming@freescale.com>
2005-07-25* Patch by Jon Loeliger, 2005-05-05Jon Loeliger
Implemented support for MPC8548CDS board. Added DDR II support based on SPD values for MPC85xx boards. This roll-up patch also includes bugfies for the previously published patches: DDRII CPO, pre eTSEC, 8548 LBIU, Andy's TSEC, eTSEC 3&4 I/O
2005-07-23* Patch by Jon Loeliger, Kumar Gala 2005-02-08Jon Loeliger
- Convert the CPM2 based functionality to use new CONFIG_CPM2 option rather than a myriad of CONFIG_MPC8560-like variants. Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560. Eliminates the CONFIG_MPC8560 option entirely. Distributes the new CONFIG_CPM2 option to each 8260 board.
2004-10-10Patches by Jon Loeliger, 24 Aug 2004:wdenk
- Add support for the MPC8541 and MPC8555 CDS boards - Cleanup eth?addr handling: make dependent on CONFIG_ETH?ADDR
2004-08-01Patch by Jon Loeliger, 16 Jul 2004:wdenk
- support larger DDR memories up to 2G on the PC8540/8560ADS and STXGP3 boards - Made MPC8540/8560ADS be 33Mhz PCI by default. - Removed moldy CONFIG_RAM_AS_FLASH, CFG_FLASH_PORT_WIDTH_16 and CONFIG_L2_INIT_RAM options. - Refactor Local Bus initialization out of SDRAM setup. - Re-implement new version of LBC11/DDR11 errata workarounds. - Moved board specific PCI init parts out of CPU directory. - Added TLB entry for PCI-1 IO Memory - Updated README.mpc85xxads
2004-07-09Patch by Jon Loeliger, 17 June 2004:wdenk
Completion of the 8540ADS/8560ADS updates: Fix some PCI and Rapid I/O memory maps, Initialize both TSEC 1 and 2, Initialize SDRAM Update MAINTAINER for 85xx boards and README.mpc85xxads
2004-06-09Patch by Robert Schwebel, 13 May 2004:wdenk
Add 'imgextract' command: extract one part of a multi file image.
2004-06-09Patches by Jon Loeliger, 11 May 2004:wdenk
(partially, as they contained a lot of crap)
2003-10-22Fix PCI problems on PPChameleon boardwdenk
