path: root/doc/README.mpc8544ds
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2012-03-27doc: Fix some typos in different filesThomas Weber
adresses/addresses alernate/alternate asssuming/assuming calcualted/calculated enviroment/environment evalutation/evaluation falsh/flash labled/labeled paramaters/parameters Signed-off-by: Thomas Weber <thomas@tomweber.eu> Acked-by: Anatolij Gustschin <agust@denx.de>
2007-08-14Coding style cleanup, update CHANGELOGWolfgang Denk
2007-08-14Add MPC8544DS READMEAndy Fleming
Signed-off-by: Andy Fleming <afleming@freescale.com>
