Also drop a few files referring to no longer / not yet supported
boards.
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: Andy Fleming <afleming@gmail.com>
Cc: Jason Jin <jason.jin@freescale.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
adresses/addresses
alernate/alternate
asssuming/assuming
calcualted/calculated
enviroment/environment
evalutation/evaluation
falsh/flash
labled/labeled
paramaters/parameters
Signed-off-by: Thomas Weber <thomas@tomweber.eu>
Acked-by: Anatolij Gustschin <agust@denx.de>
The new MPC8360EMDS board changes the oscillator to 33.33MHz
in order to support QE 500MHz since 2008.
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Use the standard lowercase "xx" capitalization that other Freescale
architectures use for CPU defines to prevent confusion and errors
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
When the rev2.x silicon mount on the MPC8360EMDS baord,
and if you are using the u-boot version after the commit
3fc0bd159103b536e1c54c6f4457a09b3aba66ca.
to make the ethernet interface usable, we have to setup
the jumpers correctly.
Signed-off-by: Dave Liu <daveliu@freescale.com>
add doc/README.mpc8360emds to accompany the new board support
