path: root/doc/README.mpc8313erdb
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2008-10-29mpc8313erdb: Document NAND boot.Scott Wood
Previously, the documentation claimed that NAND boot is not supported. This is no longer true. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-04-25mpc83xx: clean up the readme for 83xx boardsDave Liu
1. correct the typo 2. correct the memory map for 837xerdb board Signed-off-by: Dave Liu <daveliu@freescale.com>
2007-04-23mpc83xx: Add MPC8313ERDB support.Scott Wood
