path: root/doc/README.marubun-pcmcia
2016-05-05Fix various typos, scattered over the code.Robert P. J. Day
Spelling corrections for (among other things): * environment * override * variable * ftd (should be "fdt", for flattened device tree) * embedded * FTDI * emulation * controller
2007-12-27Fix coding style issues; update CHANGELOG.Wolfgang Denk
2007-11-29sh: Add marubun's pcmcia driverNobuhiro Iwamatsu
Marubun pcmcia is a chip for PCMCIA used with SuperH. Of course, this can be used even by other architectures. When use this driver, came to be able to use CompactFlash and Ethernet. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
