path: root/doc/README.m5373evb
2010-04-13m68k: Move cpu/$CPU to arch/m68k/cpu/$CPUPeter Tyser
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-22Remove deprecated 'autoscr' command/variablesPeter Tyser
The more standard 'source' command provides identical functionality to the autoscr command. Environment variable names/values on the MVBC_P, MVBML7, kmeter1, mgcoge, and km8xx boards are updated to no longer refernce 'autoscr'. The 'autoscript' and 'autoscript_uname' environment variables are also removed. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Heiko Schocher <hs@denx.de>
2009-06-12i2c: Update references to individual i2c commandsPeter Tyser
The individual i2c commands imd, imm, inm, imw, icrc32, iprobe, iloop, and isdram are no longer available so all references to them have been updated to the new form of "i2c <cmd>". Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-01-23Coding Style Cleanup; update CHANGELOGWolfgang Denk
2008-01-17ColdFire: Add M5373EVB platform support - 2TsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
