path: root/doc/README.log
2018-04-10log: Add units to code-size stats in README.logSimon Glass
Without the units these numbers are confusing. Add a comment about the unit being 'bytes' and mention 'buildman' as the source. Suggested-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2018-02-03log: add category LOGC_EFIHeinrich Schuchardt
The EFI implementation does not fit into any of the existing categories. Provide LOGC_EFI so that EFI related message can be filtered. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-02-03log: Add a way to log error-return valuesSimon Glass
When functions return an error it propagates up the stack to the point where it is reported. Often the error code provides enough information about the root cause of the error that this is obvious what went wrong. However in some cases the error may be hard to trace. For example if a driver uses several devices to perform an operation, it may not be obvious which one failed. Add a log_ret() macro to help with this. This can be used to wrap any error-return value. The logging system will then output a log record when the original error is generated, making it easy to trace the call stack of the error. This macro can significantly impact code size, so its use is controlled by a Kconfig option, which is enabled for sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-02-03log: Add documentation for commands and formattingSimon Glass
Add some notes about recent new features. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-07log: Add documentationSimon Glass
Add documentation for the log system. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
