path: root/doc/README.imx6
2018-03-11doc: mxc_hab: Move HAB related info to the appropriate docBreno Lima
Currently the High Assurance Boot procedure is documented in two places: - doc/README.imx6 - doc/README.mxc_hab It is better to consolidate all HAB related information into README.mxc_hab file, so move the content from README.imx6 to README.mxc_hab. Signed-off-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-10-12README.imx6: Prefer loading SPL via the new SDP mechanismFabio Estevam
Now that it is possible to load SPL and u-boot.img via imx_usb_loader tool, mention this method instead of the old one that relied on ymodem. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-01-02Makefile: preserve output for images that can contain HAB BlocksSven Ebenfeld
To being able to sign created binaries, we need to know the HAB Blocks for that image. Especially for the imximage type the HAB Blocks are only available during creation of the image. We want to preserve the information until we get to sign the files. In the verbose case we still get them printed out instead of writing to log files. Cc: sbabic@denx.de v2-Changes: - No usage of MKIMAGEOUTPUT_$(@F) macro. - Predefine default value /dev/null in every involved Makefile. Signed-off-by: Sven Ebenfeld <sven.ebenfeld@gmail.com> Reviewed-by: George McCollister <george.mccollister@gmail.com> Tested-by: George McCollister <george.mccollister@gmail.com>
2017-01-02doc: imx6: add section for secure boot with SPLSven Ebenfeld
Cc: sbabic@denx.de Signed-off-by: Sven Ebenfeld <sven.ebenfeld@gmail.com> Reviewed-by: George McCollister <george.mccollister@gmail.com>
2016-10-04README.imx6: Fix Boundary Devices nameFabio Estevam
Correct name is "Boundary Devices". Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-02-02mx6: soc: Add ENET2 mac address supportYe Li
The i.MX6SX and i.MX6UL has two ENET controllers, add support for reading MAC address from fuse for ENET2. Signed-off-by: Ye Li <ye.li@nxp.com>
2016-01-03imx_common: check for Serial Downloader in spl_boot_deviceStefano Babic
Check for bmode before reading the boot device to check if a serial downloader is started, and returns UART if the serial downloader is set, letting SPL to wait for an image if CONFIG_SPL_YMODEM_SUPPORT is set. This allows to load again a SPL based board with imx_usb_loader together with a tool such as kermit. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tim Harvey <tharvey@gateworks.com> CC: Fabio Estevam <Fabio.Estevam@freescale.com> CC: Eric Nelson <eric.nelson@boundarydevices.com> Reviewed-by: Eric Nelson <eric@nelint.com> Tested-by: Eric Nelson <eric@nelint.com>
2014-01-02doc: README.fuse: Add an example on how to use the fuse API on mx6qFabio Estevam
When using the fuse API in U-boot user must calculate the 'bank' and 'word' values. Provide a real example on how to calculate such values for the mx6q. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-28imx: Document fuse assignments for MAC addressesBenoît Thébaudeau
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
