path: root/doc/README.fsl-esdhc
2020-07-27Move eSDHC adapter card identification to board filesYangbo Lu
The eSDHC adapter card identification and multiplexing configuration through FPGA had been implemented in both common mmc driver and fsl_esdhc driver. However it is proper to move these code to board files and do it during board initialization. The FPGA registers are also board specific. This patch is to move eSDHC adapter card identification and multiplexing configuration from mmc driver to specific board files. And the option CONFIG_FSL_ESDHC_ADAPTER_IDENT is no longer needed. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> [Rebased, Removed T1040QDS change as board does not exist] Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2017-07-12mmc: fsl_esdhc: drop CONFIG_SYS_FSL_ESDHC_FORCE_VSELECTPeng Fan
CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT is not the correct method to set I/O to 1.8. To boards that does not support vqmmc-supply, use vs18_enable in fsl_esdhc_cfg. If regulator is supported, use fixed 1.8V regulator for vqmmc-supply. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: York Sun <york.sun@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2015-05-04mmc: fsl_esdhc: Add adapter card type identification supportYangbo Lu
Add adapter card type identification support by reading FPGA STAT_PRES1 register SDHC Card ID[0:2] bits. To use this function, define CONFIG_FSL_ESDHC_ADAPTER_IDENT. Signed-off-by: Yangbo Lu <yangbo.lu@freescale.com> Cc: York Sun <yorksun@freescale.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> [York Sun: resolve conflicts in README.fsl-esdhc] Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-23mmc: fsl_esdhc: Add support to force VSELECT setOtavio Salvador
Some boards cannot do voltage negotiation but need to set the VSELECT bit forcely to ensure it to work at 1.8V. This commit adds CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT flag for this use. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2014-09-08esdhc: Add CONFIG_SYS_FSL_ESDHC_LE and CONFIG_SYS_FSL_ESDHC_BE macrosWang Huan
For LS102xA, the processor is in little-endian mode, while esdhc IP is in big-endian mode. CONFIG_SYS_FSL_ESDHC_LE and CONFIG_SYS_FSL_ESDHC_BE are added. So accessing ESDHC registers can be determined by ESDHC IP's endian mode. Signed-off-by: Alison Wang <alison.wang@freescale.com>
