path: root/doc/README.fsl-ddr
2011-10-09powerpc/8xxx: Add support for interactive DDR programming interfaceYork Sun
Interactive DDR debugging provides a user interface to view and modify SPD, DIMM parameters, board options and DDR controller registers before DDR is initialized. With this feature, developers can fine-tune DDR for board bringup and other debugging without frequently having to reprogram the flash. To enable this feature, define CONFIG_FSL_DDR_INTERACTIVE in board header file and set an environment variable to activate it. Syntax: setenv ddr_interactive on After reset, U-boot prompts before initializing DDR controllers FSL DDR> The available commands are print print SPD and intermediate computed data reset reboot machine recompute reload SPD and options to default and recompute regs edit modify spd, parameter, or option compute recompute registers from current next_step to end next_step shows current next_step help this message go program the memory controller and continue with u-boot The first command should be "compute", which reads data from DIMM SPDs and board options, performs the calculation then stops before setting DDR controller. A user can use "print" and "edit" commands to view and modify anything. "Go" picks up from current step with any modification and compltes the calculation then enables the DDR controller to continue u-boot. "Recompute" does it over from fresh reading. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-29powerpc/mpc8xxx: Add DDR2 to unified DDR driverYork Sun
DDR2 has different ODT table and values. Adding table according to Samsung application note. Fix additive latency calculation to avoid interger underflow. Also converted typedef dynamic_odt_t to struct dynamic_odt. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-02-02Minor Coding Style Cleanup.Wolfgang Denk
2011-01-19mpc85xx: Enable unique mode registers and dynamic ODT for DDR3York Sun
Added fsl_ddr_get_version() function to for DDR3 to poll DDRC IP version (major, minor, errata) to determine if unique mode registers are available. If true, always use unique mode registers. Dynamic ODT is enabled if needed. The table is documented in doc/README.fsl-ddr. This function may also need to be extend for future other platforms if such a feature exists. Enable address parity and RCW by default for RDIMMs. Change default output driver impedance from 34 ohm to 40ohm. Make it 34ohm for quad-rank RDIMMs. Use a formula to calculate rodt_on for timing_cfg_5. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-19mpc8xxx: Enable ECC on/off control in hwconfigYork Sun
Add fsl_ddr:ecc=on in hwconfig. If ECC is enabled in board configuration file, ECC can be turned on/off by this switch. If this switch is omitted, it is ON by default. Updated hwconfig calls to use local buffer. Syntax is hwconfig=fsl_ddr:ecc=on Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-20Add memory test feature for mpc85xx POST.York Sun
The memory test is performed after DDR initialization when U-boot stills runs in flash and cache. On recent mpc85xx platforms, the total memory can be more than 2GB. To cover whole memory, it needs be mapped 2GB at a time using a sliding TLB window. After the testing, DDR is remapped with up to 2GB memory from the lowest address as normal. If memory test fails, DDR DIMM SPD and DDR controller registers are dumped for further debugging. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-26powerpc/8xxx: Enabled address hashing for 85xxyork
For 85xx silicon which supports address hashing, it can be activated by hwconfig. Signed-off-by: York Sun <yorksun@freescale.com>
2010-07-26powerpc/8xxx: Fix bug in memctrl interleaving & bank interleaving on cs0~cs4york
Verified on MPC8641HPCN with four DDR2 dimms. Each dimm has dual rank with 512MB each rank. Also check dimm size and rank size for memory controller interleaving Signed-off-by: York Sun <yorksun@freescale.com>
2010-07-26powerpc/8xxx: Enabled hwconfig for memory interleavingKumar Gala
Replace environmental variables memctl_intlv_ctl and ba_intlv_ctl with hwconfig parameters. The syntax is setenv hwconfig "fsl_ddr:ctlr_intlv=<mode>,bank_intlv=<mode>" The mode values for memory controller interleaving are cacheline page bank superbank The mode values for bank interleaving are cs0_cs1 cs2_cs3 cs0_cs1_and_cs2_cs3 cs0_cs1_cs2_cs3 Signed-off-by: York Sun <yorksun@freescale.com>
2008-10-18Check DDR interleaving modeHaiying Wang
* Check DDR interleaving mode from environment by reading memctl_intlv_ctl and ba_intlv_ctl. * Print DDR interleaving mode information * Add doc/README.fsl-ddr to describe the interleaving setting Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
