path: root/doc/README.ext4
2018-01-22fs: Migrate ext4 to KconfigTuomas Tynkkynen
Migrate the following symbols to Kconfig: CONFIG_FS_EXT4 CONFIG_EXT4_WRITE The definitions in config_fallbacks.h can now be expressed in Kconfig. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2016-04-18doc: Updated README.ext4Robert P. J. Day
Clean up the ext4 README file. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-29fs: separate CONFIG_FS_{FAT, EXT4} from CONFIG_CMD_{FAT, EXT*}Stephen Warren
This makes the FAT and ext4 filesystem implementations build if CONFIG_FS_{FAT,EXT4} are defined, rather than basing the build on whether CONFIG_CMD_{FAT,EXT*} are defined. This will allow the filesystems to be built separately from the filesystem-specific commands that use them. This paves the way for the creation of filesystem-generic commands that used the filesystems, without requiring the filesystem- specific commands. Minor documentation changes are made for this change. The new config options are automatically selected by the old config options to retain backwards-compatibility. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2012-08-09ext4fs write supportUma Shankar
Signed-off-by: Uma Shankar <uma.shankar@samsung.com> Signed-off-by: Manjunatha C Achar <a.manjunatha@samsung.com> Signed-off-by: Iqbal Shareef <iqbal.ams@samsung.com> Signed-off-by: Hakgoo Lee <goodguy.lee@samsung.com>
