path: root/doc/README.drivers.eth
2015-04-18net: cosmetic: Fix var naming net <-> eth driversJoe Hershberger
Update the naming convention used in the network stack functions and variables that Ethernet drivers use to interact with it. This cleans up the temporary hacks that were added to this interface along with the DM support. This patch has a few remaining checkpatch.pl failures that would be out of the scope of this patch to fix (drivers that are in gross violation of checkpatch.pl). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: eth: Add basic driver model support to Ethernet stackJoe Hershberger
First just add support for MAC drivers. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-03-24net: Update README.drivers.eth to mention latest APIsBin Meng
README.drivers.eth still refers to the deprecated miiphy_register(). Update the doc to mention new APIs mdio_alloc() and mdio_register(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2010-05-03Program net device MAC addresses after initializingBen Warren
Add a new function to the eth_device struct for programming a network controller's hardware address. After all network devices have been initialized and the proper MAC address for each has been determined, make a device driver call to program the address into the device. Only device instances with valid unicast addresses will be programmed. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Prafulla Wadaskar <prafulla@marvell.com> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Thomas Chou <thomas@wytron.com.tw>
2009-11-09clarify eth driver halt/recv stepsMike Frysinger
The dev->halt() func can be called at any time, and the dev->recv() func does not need to use NetRxPackets[] when calling NetReceive(). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-28Coding Style cleanup; update CHANGELOG, prepare -rc1v2009.11-rc1Wolfgang Denk
2009-10-05Add information about return values of xxx_eth_register() in documentationBen Warren
As discussed on mailing list, <0 indicates failure, >=0 indicates number of interfaces found. Also added blurb about private data Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-04document network driver frameworkMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
