path: root/doc/README.dfutftp
2017-08-21doc: license: Add license header to the README.dfutftp fileLukasz Majewski
Signed-off-by: Lukasz Majewski <lukma@denx.de>
2015-09-07doc: dfu: tftp: README entry for TFTP extension of DFULukasz Majewski
Documentation file for DFU extension. With this functionality it is now possible to transfer FIT images with firmware updates via TFTP and use DFU backend for storing them. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
