path: root/doc/README.console
2014-04-18powerpc: remove genietv board supportMasahiro Yamada
Enough time has passed since this board was moved to Orphan. Remove. - Remove board/genietv/* - Remove include/configs/GENIETV.h - Clean-up if defined(CONFIG_GENIETV) - Move the entry from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-17powerpc: mpc8xx: delete an unused source fileMasahiro Yamada
References to the wireless keyboard should also be removed from README.console. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2011-09-23doc: provide a correct board_init_r definition pathVladimir Zapolskiy
This is a trivial fix in the documentation, which corrects board_init_r() source reference. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
