path: root/doc/README.coccinelle
2017-11-20Makefile: add coccicheck targetHeinrich Schuchardt
Coccinelle is a program for static code analysis. For details on Coccinelle see http://coccinelle.lip6.fr/ Add scripts/coccicheck copied from Linux kernel v4.14. The coccicheck script executes the tests *.cocci in directory scripts/coccinelle by calling spatch. In Makefile add a coccicheck target. You can use it with make coccicheck MODE=<mode> where mode in patch, report, context, org. Add a copy of Linux v4.14 file Documentation/dev-tools/coccinelle.rst as doc/README.coccinelle. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
