This issue covered by this doc appears to be fixed, so let's remove the
README.
Reviewed-by: York Sun <york.sun@nxp.com>
Acked-by: Andreas Bießmann <andreas@biessmann.org>
I'll switch my mails to my own server, so drop all gmail references.
Since all currently supported at91rm9200 boards are migrated to at91
support the joining notice can be removed.
* prepare joining at91 and at91rm9200
* add modified copy of soc files to cpu/arm920t/at91 to make
possible to compile at91rm9200 boards in at91 tree instead
of at91rm9200
* add header files with c structure defs for AT91 MC, ST and TC
* the new cpu files are using at91 c structure soc access
* please read README.soc-at91 for details
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
* add's the new temporary CONFIG_AT91_LEGACY to all board configs
This will need for backward compatiblity, while change the SoC access
to c structures. If CONFIG_AT91_LEGACY is defined, the deprecated
SoC is used.
