path: root/doc/README.adnpesc1_base32
2010-05-28nios: remove nios-32 archThomas Chou
The nios-32 arch is obsolete and broken. So it is removed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2004-03-14* Patch by Stephan Linz, 09 Mar 2004wdenk
- Add support for the SSV ADNP/ESC1 (Nios Softcore) * Patch by George G. Davis, 9 Mar 2004: fix recent build failure for SA1100 target * Patch by Travis Sawyer, 09 Mar 2004: Support native interrupt mode for the IBM440GX. Previously it was running in 440GP compatibility mode.
