path: root/doc/README.SPL
2020-04-17doc: spl: update reference to driver-model/README.txtPatrick Delaunay
Update the reference in doc/README.SPL to a no more existing file: "driver-model/README.txt", it is changed to "doc/driver-model/design.rst". Adding the directory path /doc/ allows to check this reference with 'make refcheckdocs'. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-01-15Kconfig: Rename CONFIG_SPL_DMA_SUPPORT to CONFIG_SPL_DMAVignesh Raghavendra
Rename CONFIG_SPL_DMA_SUPPORT to CONFIG_SPL_DMA. This allows to use macros such as CONFIG_IS_ENABLED() that allow conditional compilation of code for SPL and U-Boot. Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-12-03cosmetic: Fix spelling and whitespace errorsThomas Hebb
Signed-off-by: Thomas Hebb <tommyhebb@gmail.com>
2019-07-10dm: doc: add documentation for pre-reloc properties in SPL and TPLPatrick Delaunay
Add documentation for the pre-reloc property in SPL and TPL device-tree: - u-boot,dm-pre-proper - u-boot,dm-pre-reloc - u-boot,dm-spl - u-boot,dm-tpl Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-02-01spl: Kconfig: Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPL_FS_EXT4Tien Fong Chee
Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPLY_FS_EXT4 so both obj-$(CONFIG_$(SPL_)FS_EXT4) and CONFIG_IS_ENABLED(FS_EXT4) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-01spl: Kconfig: Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FATTien Fong Chee
Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FAT so obj-$(CONFIG_$(SPL_)FS_FAT) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-09-20mtd: move NAND files into a raw/ subdirectoryMiquel Raynal
NAND flavors, like serial and parallel, have a lot in common and would benefit to share code. Let's move raw (parallel) NAND specific code in a raw/ subdirectory, to ease the addition of a core file in nand/ and the introduction of a spi/ subdirectory specific to SPI NANDs. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
2014-10-27doc: Update documentation according to the EXT SPL support patch setGuillaume GARDET
Update documentation according to the EXT SPL support patch set. Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@ti.com>
2014-08-06doc: README.SPL: adjust for Kbuild and KconfigMasahiro Yamada
Reflect the latest build system to doc/README.SPL. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-03-12kbuild: rename TOPDIR to stctreeMasahiro Yamada
Prior to Kbuild, $(TOPDIR) or $(SRCTREE) was used for pointing to the top of source directory. (No difference between the two.) In Kbuild style, $(srctree) is used instead. This commit renames TOPDIR to srctree and delete the defition of TOPDIR. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-21powerpc:mpc85xx: Add ifc nand boot support for TPL/SPLPo Liu
Using the TPL method for nand boot by sram was already supported. Here add some code for mpc85xx ifc nand boot. - For ifc, elbc, esdhc, espi, all need the SPL without section .resetvec. - Use a clear function name for nand spl boot. - Add CONFIG_SPL_DRIVERS_MISC_SUPPORT to compile the fsl_ifc.c in spl/Makefile; Signed-off-by: Po Liu <Po.Liu@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2013-08-28arm, spl: add watchdog library to SPLHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com>
2013-07-03cosmetic: README.SPL: fix a typoMasahiro Yamada
2012-09-27SPL: Add support for loading image from ram in SPL.Pavel Machek
Signed-off-by: Pavel Machek <pavel@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-02README.SPL: Move the 'Estimating stack usage' from omap3 to hereTom Rini
The instructions are generic, so move to the generic doc. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-02README.SPL: Add a small Debugging sectionTom Rini
2012-08-09mkconfig: add support for SPL CPUAllen Martin
Add support for specifying a differnt CPU for main u-boot and SPL u-boot builds. This is done by adding an optional SPL CPU after the main CPU in boards.cfg as follows: normal_cpu:spl_cpu This this case CPU will be set to "normal_cpu" during the main u-boot build and "spl_cpu" during the SPL build. Signed-off-by: Allen Martin <amartin@nvidia.com>
2012-02-12doc: fix typosPeter Meerwald
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com>
2011-12-24sf: Add spi_boot() to allow booting from SPI flash in an SPLChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Heiko Schocher <hs@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Scott Wood <scottwood@freescale.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-11-03arm, davinci: add support for new spl frameworkHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03spl: add option for adding post memory test to the SPL frameworkHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Sergei Shtylyov <sshtylyov@mvista.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27SPL: Add DMA librarySimon Schwarz
Adding a DMA library to the SPL. It is used if CONFIG_SPL_DMA_SUPPORT is defined. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30spl: Add POWER library to new splSimon Schwarz
Adds power library to the new spl Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30spl: add NAND Library to new SPLSimon Schwarz
Adds NAND library to SPL. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-11Minor coding style cleanup.Wolfgang Denk
2011-07-26spl: add initial support for a generic SPL frameworkDaniel Schwierzeck
Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
