path: root/doc/README.NetConsole
2009-04-04tools/Makefile: Compile ncb when CONFIG_NETCONSOLEPeter Tyser
Also conditionally add ncb.o to OBJ_FILES list Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-10tools/netconsole: new script for working with netconsole over UDPMike Frysinger
While the doc/README.NetConsole does have a snippet for people to create their own netcat script, it's a lot easier to make a simple dedicated script and tell people to use it. Also spruce it up a bit to make it user friendly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2007-04-04Update usage of 'nc' in README.NetConsoleIgor Marnat
Added information about usage of NetConsole on systems where the -l and -p switches are mutually exclusive. Signed-off-by: Igor Marnat <marny@rambler.ru> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2005-04-03* Patch by Richard Klingler, 03 Apr 2005:wdenk
Add call to eth_halt() in net/net.c when called functions fail after eth_init() has been called. * Patch by Sam Song, 3 April 2005: - Update README.Netconsole - Update README
2004-12-10* Clean up CMC PU2 flash driverwdenk
* Update MAINTAINERS file * Fix bug in MPC823 LCD driver
2004-09-08* Patch by Detlev Zundel, 08 Sep 2004:LABEL_2004_09_09_0000wdenk
Update etags build target * Improve NetConsole support: add support for broadcast destination address and buffered input. * Cleanup compiler warnings for GCC 3.3.x and later * Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
2004-08-02Add support for console over UDP (compatible to Ingo Molnar'swdenk
netconsole patch under Linux)
