2004-09-28 | * Patch by Yuli Barcohen, 13 Jul 2004: | wdenk | |
Allow clock setting on MPC866/MPC885 series chips according to environment variable `cpuclk' * Patch by Yuli Barcohen, 20 Apr 2004: Remove unnecessary redefine of CPM_DATAONLY_SIZE for MPC826x | |||
2004-01-31 | Fix variable CPU clock for MPC859/866 systems for low CPU clocks | wdenk | |
2004-01-29 | * Implement adaptive SDRAM timing configuration based on actual CPULABEL_2004_01_29_1030 | wdenk | |
clock frequency for INCA-IP; fix problem with board hanging when switching from 150MHz to 100MHz * Add PCMCIA CS support for BMS2003 board |
