path: root/doc/DocBook
2014-04-18kbuild: docbook: sync with Linux Kernel v3.15-rc1Masahiro Yamada
This commit imports DocBook-related updates from v3.14 to v3.15-rc1. - commit ec3fadd64b9940baa2a369bf978e8561837db3f5 kbuild: docbook: use $(obj) and $(src) rather than specific path - commit 100da4c0150c97ce34d4d3b38bf2f5449b05ae4f kbuild: docbook: specify KERNELDOC dependency correctly - commit 6f89b9c1d6b29eaa600ac4a8ac1314b0d06f15e3 kbuild: docbook: include cmd files more simply - commit ac6d662a95a6989d83b259ccf8ec01dd7903af73 doc: Add "*.svg" to DocBook/.gitignore - commit 832919bfcf0cfd75767c68b0c61f7cf48be860a8 DocBook: Make mandocs parallel-safe - commit c4d79a4799719f2b0cd354ee498aad605730c97e work around xmlto bug in htmldocs Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-25kbuild: consolidate version and timestamp headers generationMasahiro Yamada
- Generate include/generated/{timestamp.h, version.h} more simply by using filechk rule. - Add $(UBOOTRELEASE) variable and re-write u-boot.imx rule more simply. - Rename U_BOOT_VERSION in Makefile to UBOOTVERSION Before this commit, the same variable name, "U_BOOT_VERSION" was used for two different strings. One of them was defined in Makefile. It takes the form like "2014.01-rc1" and used in makefiles and script files. The other is defined in include/generated/version.h It takes the form like "U-Boot 2014.01-rc1-00010-gbe6d426-dirty" and used in C and Aseembler. It is confusing when grepping the source tree. So, this commit renames the former to UBOOTVERSION. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kernel-doc: fix some errorsMasahiro Yamada
- Delete fs.xml from DOCBOOKS to fix an error. Commit e3ff797c added fs.xml to DOCBOOKS but missed to add doc/DocBook/fs.tmpl. - Fix the location of include guard in include/linker_lists.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Abraham Varricatt <abraham.varricatt@vvdntech.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19kernel-doc: update kernel-doc related files to Linux v3.13Masahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19kernel-doc: move kernel-doc tools to scripts/Masahiro Yamada
tools/kernel-doc/docproc.c and tools/kernel-doc/kernel-doc are files imported from Linux Kernel. They originally resided under scripts/ directory in Linux Kernel. This commit moves them to the original location. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2012-12-06cbfs: Add docbook templateSimon Glass
This adds a docbook template for fs, and makes CBFS use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-22kerneldoc: tmpl: Implement template for LG-arraysMarek Vasut
Implement kerneldoc template for linker-generated arrays. This is the first template in U-Boot that is used to generate kerneldoc style documentation. This template is very basic. Signed-off-by: Marek Vasut <marex@denx.de>
2012-10-17kerneldoc: stdio: tmpl: Add stdio templateMarek Vasut
Add STDIO documentation template. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> [trini: Fix DOCBOOKS line as we don't have linker_lists yet] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15kerneldoc: Add nicer CSS stylesheet for HTML docsMarek Vasut
Import basic CSS stylesheet for the HTML documentation. The base for the stylesheet is taken from: http://ds9a.nl/docbook/minimal-page.html I customized the CSS a bit further, for example to add curvy corners to example section and change the tint of gray. The HTML documentation does not look that crude anymore. Signed-off-by: Marek Vasut <marex@denx.de>
2012-10-15kerneldoc: Implant DocBook from Linux kernelMarek Vasut
Pull slightly modified version of Documentation/DocBook, the related perl script scripts/kernel-doc and the scripts/docproc.c from Linux kernel and implant it into U-Boot. This will allow smooth generation of kerneldoc style documentation. It was necessary to modify the DocBook/Makefile to work with U-Boot build system. The changes were only minor though and involved replacing the kbuild specific parts. It was also necessary to replace use of variables like KERNEL_VERSION with U_BOOT_VERSION, strings like Linux kernel with U-Boot Bootloader etc. so the generated result actually matches. Finally, it was necessary to adjust docproc.c, since the documentation in U-Boot is located in doc/DocBook instead of Documentation/DocBook as is in case of the Linux kernel. Some parts of the DocBook Makefile are unused, but to allow easier sync with Linux kernel, these parts are still left in. The targets enabled now are "htmldocs" "pdfdocs" "psdocs" "xmldocs" and "cleandocs" to remove the results of documentation build. Linux scripts/docproc.c: commit f0f3ca8d967462dafb815412b14ca3339b9817a6 Date: Wed Jun 15 11:53:13 2011 +0200 Linux scripts/kernel-doc: commit 1b40c1944db445c1de1c47ffd8cd426167f488e8 Date: Sun Aug 12 10:46:15 2012 +0200 Linux Documentation/DocBook: commit bb8187d35f820671d6dd76700d77a6b55f95e2c5 Date: Thu May 17 19:06:13 2012 -0400 Signed-off-by: Marek Vasut <marex@denx.de>
