path: root/disk
2020-09-22disk: typo Terra BytesHeinrich Schuchardt
512 * 2^32 bytes equals 2 tebibytes. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-08-14xen: pvblock: Add initial support for para-virtualized block driverAnastasiia Lukianenko
Add initial infrastructure for Xen para-virtualized block device. This includes compile-time configuration and the skeleton for the future driver implementation. Add new class UCLASS_PVBLOCK which is going to be a parent for virtual block devices. Add new interface type IF_TYPE_PVBLOCK. Implement basic driver setup by reading XenStore configuration. Signed-off-by: Andrii Anisov <andrii_anisov@epam.com> Signed-off-by: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com> Signed-off-by: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop part.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18part: Drop disk_partition_t typedefSimon Glass
We should not be using typedefs and these make it harder to use forward declarations (to reduce header file inclusions). Drop the typedef. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop uuid.h from common headerSimon Glass
2020-05-15rename symbol: CONFIG_TEGRA -> CONFIG_ARCH_TEGRATrevor Woerner
Have this symbol follow the pattern of all other such symbols. Signed-off-by: Trevor Woerner <twoerner@gmail.com>
2020-04-30part: detect EFI system partitionHeinrich Schuchardt
Up to now for MBR and GPT partitions the info field 'bootable' was set to 1 if either the partition was an EFI system partition or the bootable flag was set. Turn info field 'bootable' into a bit mask with separate bits for bootable and EFI system partition. This will allow us to identify the EFI system partition in the UEFI sub-system. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-03-18sunxi: Move common defconfig options to KconfigAndre Przywara
Some config symbols are found in *almost* every _defconfig file for Allwinner boards, because those options are actually a platform choice, and not a per-board decision. Some of these options are older, some have recently been added. Move those options to be set for all Allwinner boards in their respective Kconfig files. The rationales are as follows: - NR_DRAM_BANKS: All Allwinner SoC map DRAM at one contiguous region of address space only, starting at 1 GB. So it's always one bank. - SPL_{DOS,EFI}_PARTITION: The Allwinner SPL does only support raw MMC accesses, we don't care about filesystems or partitions in there, so there is no need to define those symbols at all. - USE_PREBOOT: We start USB early when a keyboard is configured, using the preboot env variable, so we need to set this variable. - SYS_RELOC_GD_ENV_ADDR: We don't specify any ENV_ADDR, so need this symbol to be set (according to 8d8ee47e03e). - SYS_USB_EVENT_POLL_VIA_INT_QUEUE: According to commit eab9433aa55428, specifying this reduces the latency of the USB keyboard handling, so this was formerly enabled in config headers for all Allwinner boards. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <mripard@kernel.org> Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2020-01-23disk: part: rename parameter of lba512_muldiv()Heinrich Schuchardt
div_by is a misleading parameter name, when we are doing >> div_by. Rename it to right_shift. Reported-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-12-02crc32: Use the crc.h header for crc functionsSimon Glass
Drop inclusion of crc.h in common.h and use the correct header directly instead. With this we can drop the conflicting definition in fw_env.h and rely on the crc.h header, which is already included. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-10-31disk: part_dos: correctly detect DOS PBRHeinrich Schuchardt
The signature 0x55 0xAA in bytes 510 and 511 of the first sector can either indicate a DOS partition table of the first sector of a FAT file system. The current code tries to check if the partition table is valid by looking at the boot indicator of the partition entries. But first of all it does not count from 0 to 3 but only from 0 to 2. And second it misses to increment the pointer for the partition entry. If it is a FAT file system can be discovered by looking for the text 'FAT' at offset 0x36 or 'FAT32' at offset 0x52. In a DOS PBR there are no partition entries, so those bytes are undefined. Don't require the byte at offset 0x1BE to differ from 0x00 and 0x80. With the patch the logic is changed as follows: If the partition table has either an invalid boot flag for any partition or has no partition at all, check if the first sector is a DOS PBR by looking at the FAT* signature. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-09-19disk: part_dos: Allocate at least one block size for mbrFaiz Abbas
The blk_dread() following the mbr allocation reads one block from the device. This will lead to overflow if block size is greater than the size of legacy_mbr. Fix this by allocating at least one block size. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
2019-08-23disk: efi: ignore 'IGNOREME' GPT header found on cros eMMCsUrja Rannikko
Some ChromeOS devices (atleast veyron speedy) have the first 8MiB of the eMMC write protected and equipped with a dummy 'IGNOREME' GPT header - instead of spewing error messages about it, just silently try the backup GPT. Note: this does not touch the gpt cmd writing/verifying functions, those will still complain. Signed-off-by: Urja Rannikko <urjaman@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-08-23disk: efi: unify code for finding a valid gptUrja Rannikko
There were 3 copies of the same sequence, make it into a function. Signed-off-by: Urja Rannikko <urjaman@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-08-11env: Move env_get() to env.hSimon Glass
Move env_get() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-07-24disk: part: Extend API to get partition infoRuslan Trofymenko
This patch adds part_get_info_by_dev_and_name_or_num() function which allows us to get partition info from its number or name. Partition of interest is specified by string like "device_num:partition_number" or "device_num#partition_name". The patch was extracted from [1]. [1] https://android-review.googlesource.com/c/platform/external/u-boot/+/729880/2 Signed-off-by: Ruslan Trofymenko <ruslan.trofymenko@linaro.org> Signed-off-by: Igor Opaniuk <igor.opaniuk@gmail.com> Reviewed-by: Alistair Strachan <astrachan@google.com> Reviewed-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-07-23Merge tag 'efi-2019-10-rc1-2' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-efi Pull request for UEFI sub-system for v2019.10-rc1 (2) * Implement the EVT_SIGNAL_VIRTUAL_ADDRESS_CHANGE event. * Address errors of type -Werror=address-of-packed-member when building with GCC9.1 * Fix an error when adding memory add addres 0x00000000. * Rework some code comments for Sphinx compliance.
2019-07-18CVE-2019-13103: disk: stop infinite recursion in DOS PartitionsPaul Emge
part_get_info_extended and print_partition_extended can recurse infinitely while parsing a self-referential filesystem or one with a silly number of extended partitions. This patch adds a limit to the number of recursive partitions. Signed-off-by: Paul Emge <paulemge@forallsecure.com>
2019-07-16disk: efi: avoid unaligned pointer errorHeinrich Schuchardt
When building with GCC 9.1 an error occurs: disk/part_efi.c: In function ‘gpt_verify_partitions’: disk/part_efi.c:737:49: error: taking address of packed member of ‘struct _gpt_entry’ may result in an unaligned pointer value [-Werror=address-of-packed-member] 737 | gpt_convert_efi_name_to_char(efi_str, gpt_e[i].partition_name, | ~~~~~~~~^~~~~~~~~~~~~~~ cc1: all warnings being treated as errors make[1]: *** [scripts/Makefile.build:279: disk/part_efi.o] Error 1 make: *** [Makefile:1594: disk] Error 2 Adjust gpt_convert_efi_name_to_char() to accept unaligned strings. Reported-by: Ramon Fried <rfried.dev@gmail.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-07-06disk: efi: buffer overflow in part_get_info_efi()Heinrich Schuchardt
In part_get_info_efi() we use the output of print_efiname() to set info->name[]. The size of info->name is PART_NAME_LEN = 32 but print_efiname() returns a string with a maximum length of PARTNAME_SZ + 1 = 37. Use snprintf() instead of sprintf() to avoid buffer overflow. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-06-21disk: part: Don't skip partition initRobert Hancock
blk_get_device_by_str was skipping part_init when hw partition 0 was selected because it is the default. However, this caused issues when switching to a non-zero partition and then back to partition zero, as stale data from the wrong partition was returned. Remove this optimization and call part_init regardless of the selected partition. Signed-off-by: Robert Hancock <hancock@sedsystems.ca>
2019-06-14disk: part: avoid undefined reference to `__udivmoddi4'Heinrich Schuchardt
When compiling with FTRACE=1 an error ld.bfd: disk/built-in.o: in function `lba512_muldiv': disk/part.c:114: undefined reference to `__udivmoddi4 occurred. Use '>> 11' instead of '/ 2048' to avoid the division. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-02disk: efi: Fix memory leak on 'gpt verify'Eugeniu Rosca
Below is what happens on R-Car H3ULCB-KF using clean U-Boot v2019.04-00810-g6aebc0d11a10 and r8a7795_ulcb_defconfig: => ### interrupt autoboot => gpt verify mmc 1 No partition list provided - only basic check Verify GPT: success! => ### keep calling 'gpt verify mmc 1' => ### on 58th call, we are out of memory: => gpt verify mmc 1 alloc_read_gpt_entries: ERROR: Can't allocate 0X4000 bytes for GPT Entries GPT: Failed to allocate memory for PTE gpt_verify_headers: *** ERROR: Invalid Backup GPT *** Verify GPT: error! This is caused by calling is_gpt_valid() twice (hence allocating pte also twice via alloc_read_gpt_entries()) while freeing pte only _once_ in the caller of gpt_verify_headers(). Fix that by freeing the pte allocated and populated for primary GPT _before_ allocating and populating the pte for backup GPT. The latter will be freed by the caller of gpt_verify_headers(). With the fix applied, the reproduction scenario [1-2] has been run hundreds of times in a loop w/o running into OOM. [1] gpt verify mmc 1 [2] gpt verify mmc 1 $partitions Fixes: cef68bf9042dda ("gpt: part: Definition and declaration of GPT verification functions") Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-02disk: efi: Fix memory leak on 'gpt guid'Eugeniu Rosca
Below is what happens on R-Car H3ULCB-KF using clean U-Boot v2019.04-00810-g6aebc0d11a10 and r8a7795_ulcb_defconfig: => ### interrupt autoboot => gpt guid mmc 1 21200400-0804-0146-9dcc-a8c51255994f success! => ### keep calling 'gpt guid mmc 1' => ### on 59th call, we are out of memory: => gpt guid mmc 1 alloc_read_gpt_entries: ERROR: Can't allocate 0X4000 bytes for GPT Entries GPT: Failed to allocate memory for PTE get_disk_guid: *** ERROR: Invalid GPT *** alloc_read_gpt_entries: ERROR: Can't allocate 0X4000 bytes for GPT Entries GPT: Failed to allocate memory for PTE get_disk_guid: *** ERROR: Invalid Backup GPT *** error! After some inspection, it looks like get_disk_guid(), added via v2017.09 commit 73d6d18b7147c9 ("GPT: add accessor function for disk GUID"), unlike other callers of is_gpt_valid(), doesn't free the memory pointed out by 'gpt_entry *gpt_pte'. The latter is allocated by is_gpt_valid() via alloc_read_gpt_entries(). With the fix applied, the reproduction scenario has been run hundreds of times ('while true; do gpt guid mmc 1; done') w/o running into OOM. Fixes: 73d6d18b7147c9 ("GPT: add accessor function for disk GUID") Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-04-26disk: part: fix typoHeinrich Schuchardt
%g/rathen then/rather than/ Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-01-18disk: efi: GUIDs should be constHeinrich Schuchardt
Make system_guid const. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14blk: Introduce IF_TYPE_VIRTIOTuomas Tynkkynen
This adds a new block interface type for VirtIO block devices. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-09Rename GPT_HEADER_SIGNATURE to avoid conflictSimon Glass
The current name conflicts with the Chrome OS verified boot library, which prevents it being built. That library uses a string whereas U-Boot uses a 64-bit hex value. Rename this in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-10Remove <inttypes.h> includes and PRI* usages in printf() entirelyMasahiro Yamada
In int-ll64.h, we always use the following typedefs: typedef unsigned int u32; typedef unsigned long uintptr_t; typedef unsigned long long u64; This does not need to match to the compiler's <inttypes.h>. Do not include it. The use of PRI* makes the code super-ugly. You can simply use "l" for printing uintptr_t, "ll" for u64, and no modifier for u32. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-08-10disk: part: Don't show redundant error messageSam Protsenko
Underlying API should already print some meaningful error message, so this one is just brings more noise. E.g. we can see log like this: MMC: no card present ** Bad device mmc 0 ** Obviously, second error message is unwanted. Let's only print it in case when DEBUG is defined to keep log short and clear. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2018-06-14efi_loader: avoid initializer element is not constantHeinrich Schuchardt
When building with -pedantic the current definition of EFI_GUID() causes an error 'initializer element is not constant'. Currently EFI_GUID() is used both as an anonymous constant and as an intializer. A conversion to efi_guid_t is not allowable when using EFI_GUID() as an initializer. But it is needed when using it as an anonymous constant. We should not use EFI_GUID() for anything but an initializer. So let's introduce a variable where needed and remove the conversion. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-06-05disk: efi: Correct backing up the MBR boot codeSam Protsenko
In commit e163a931af34 ("cmd: gpt: backup boot code before writing MBR") there was added the procedure for storing old boot code when doing "gpt write". But instead of storing just backup code, the whole MBR was stored, and only specific fields were replaced further, keeping everything else intact. That's obviously not what we want. Fix the code to actually store only old boot code and zero out everything else. This fixes next testing case: => mmc write $loadaddr 0x0 0x7b => gpt write mmc 1 $partitions In case when $loadaddr address and further memory contains 0xff, the board was bricked (ROM-code probably didn't like partition entries that were clobbered with 0xff). With this patch applied, commands above don't brick the board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Cc: Alejandro Hernandez <ajhernandez@ti.com> Tested-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2018-04-28spl: disk: usb: Add dependencies to sprintf/strto*Alex Kiernan
If SPL serial support is disabled nothing brings in sprintf, snprintf or simple_strtoul: env/built-in.o: In function `regex_callback': env/attr.c:128: undefined reference to `sprintf' disk/built-in.o: In function `blk_get_device_by_str': disk/part.c:386: undefined reference to `simple_strtoul' disk/part.c:395: undefined reference to `simple_strtoul' disk/built-in.o: In function `blk_get_device_part_str': disk/part.c:522: undefined reference to `simple_strtoul' disk/built-in.o: In function `part_set_generic_name': disk/part.c:704: undefined reference to `sprintf' drivers/built-in.o: In function `init_peripheral_ep': drivers/usb/musb-new/musb_gadget.c:1826: undefined reference to `sprintf' drivers/built-in.o: In function `musb_core_init': drivers/usb/musb-new/musb_core.c:1451: undefined reference to `snprintf' Add those dependencies here. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-16part: Disable CONFIG_SPL_ISO_PARTITION by defaultAlexander Graf
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot could load distro images that usually get shipped as iso images. These images usually come with a board agnostic boot environment. However, there is very little point in having ISO support enabled (for anyone really) in SPL, as the whole idea of SPL is to load U-Boot proper which again is board specific. So the fact that we enable ISO support in U-Boot proper does not mean at all that we want ISO support in U-Boot SPL. Hence, let's remove the Kconfig dependency. Along the way, let's also clean up all those default configs that disabled SPL ISO support. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-03-13disk: part: use common api to lookup part driverKever Yang
Do not need to scan disk every time when we get part info by name. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> [trini: Fix build in !CONFIG_HAVE_BLOCK_DEVICE case] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-13disk: part: scan the disk if the part_type is unknownKever Yang
If a DUT do not have partition table, and we write one with 'gpt write' cmd, we should able to list the partition with 'part list' cmd. It's reasonable to scan the disk again if the initial part_type is unknown in case we just write a new one into disk. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2018-02-08Move most CONFIG_HAVE_BLOCK_DEVICE to KconfigAdam Ford
config_fallbacks.h has some logic that sets HAVE_BLOCK_DEVICE based on a list of enabled options. Moving HAVE_BLOCK_DEVICE to Kconfig allows us to drastically shrink the logic in config_fallbacks.h Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rename HAVE_BLOCK_DEVICE to CONFIG_BLOCK_DEVICE] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-08Convert LIB_UUID to KconfigAdam Ford
config_fallback.h has some logic that checks a variety of options and selects LIB_UUID if it hasn't already been selected. This will all LIB_UUID in Kconfig and select this option for the list of options to allow us to remove the logic from fallbacks Signed-off-by: Adam Ford <aford173@gmail.com>
2018-02-07part: Allocate only one legacy_mbr bufferAlexey Brodkin
Commit ff98cb90514d ("part: extract MBR signature from partitions") blindly switched allocated by ALLOC_CACHE_ALIGN_BUFFER buffer type from "unsigned char" to "legacy_mbr" which caused allocation of size = (typeof(legacy_mbr) * dev_desc->blksize) instead of just space enough for "legacy_mbr" structure. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Rob Clark <robdclark@gmail.com> Cc: Peter Jones <pjones@redhat.com> Cc: Alexander Graf <agraf@suse.de> Cc: Tom Rini <trini@konsulko.com>
2017-12-19Merge git://git.denx.de/u-boot-sunxiTom Rini
2017-12-07part: efi: Add default number of partition entries for sunxiMaxime Ripard
The SPL must be located at 8kB (16 sectors) offset. That's right in the middle of the GPT, so we need to define a smaller amount of partitions to accomodate for that location. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-12-07part: efi: Add a Kconfig option for the number of partition entriesMaxime Ripard
On some SoCs, the SPL needs to be located right in the middle of the GPT partition entries. One way to work around that is to create partition entries for a smaller number of partitions to accomodate with where the SPL will be. Create a Kconfig option to allow to do that. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-11-29disk: efi: correct the allocation size for mbr header in stackPatrick Delaunay
use ALLOC_CACHE_ALIGN_BUFFER_PAD for mbr header allocation in stack to fix alloc issue in is_gpt_valid() this patch fix also issue for GPT partition handling with blocksize != 512 in set_protective_mbr() Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-11-06disk: part_dos: fix part_get_info_extended() functionShawn Guo
The check in part_get_info_extended() for a successful partition searching misses a condition for extended partition. In case of (ext_part_sector == 0), we should anyway mark the partition as found, even if it's an extended partition, i.e. (is_extended(pt->sys_ind) == 0). Otherwise, the extended partition (type 0x0f) will never be identified, and the following recursive call to part_get_info_extended() will get a wrong 'part_num' and 'which_part' parameter. In the end, all those partitions in extended table will not be identified. Let's add the missing OR condition of (ext_part_sector == 0) for is_extended() check to fix the problem. The issue is discovered by running fastboot flash to an extended partition on eMMC. $ fastboot flash mmcsda5 cache.img target reported max download size of 536870912 bytes sending 'mmcsda5' (18796 KB)... OKAY [ 2.144s] writing 'mmcsda5'... FAILED (remote: cannot find partition) finished. total time: 2.261s Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2017-11-06gpt: Use cache aligned buffers for gpt_h and gpt_eLukasz Majewski
Before this patch one could receive following errors when executing "gpt write" command on machine with cache enabled: display5 factory > gpt write mmc ${mmcdev} ${partitions} Writing GPT: CACHE: Misaligned operation at range [4ef8f7f0, 4ef8f9f0] CACHE: Misaligned operation at range [4ef8f9f8, 4ef939f8] CACHE: Misaligned operation at range [4ef8f9f8, 4ef939f8] CACHE: Misaligned operation at range [4ef8f7f0, 4ef8f9f0] success! To alleviate this problem - the calloc()s have been replaced with malloc_cache_aligned() and memset(). After those changes the buffers are properly aligned (with both start address and size) to SoC cache line. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2017-10-23disk: efi: correct the overlap check on GPT header and PTEPatrick Delaunay
the partition starting at 0x4400 is refused with overlap error: $> gpt write mmc 0 "name=test,start=0x4400,size=0" Writing GPT: Partition overlap error! even if the 0x4400 is the first available offset for LBA35 with default value: - MBR=LBA1 - GPT header=LBA2 - PTE= 32 LBAs (128 entry), 3 to 34 And the command to have one partition for all the disk failed also : $> gpt write mmc 0 "name=test,size=0" After the patch : $> gpt write mmc 0 "name=test,size=0" Writing GPT: success! $> part list mmc 0 Partition Map for MMC device 0 -- Partition Type: EFI Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00000022 0x01ce9fde "test" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 type: data guid: b4b84b8a-04e3-4000-0036-aff5c9c495b1 And 0x22 = 34 LBA => offset = 0x4400 is accepted as expected Reviewed-by: Łukasz Majewski <lukma@denx.de> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
