When using ISO partitions with a DMA enabled block device driver
reading the ISO partition leads to unaligned DMA operations:
CACHE: Misaligned operation at range [bffb7da8, bffb85a8]
Align the buffer to make sure we pass a buffer which works for
DMA operations.
In both DOS and ISO partition tables the same code to create partition name
like "hda1" was repeated.
Code moved to into a new function part_set_generic_name() in part.c and optimized.
Added recognition of MMC and SD types, name is like "mmcsda1".
Signed-off-by: Petr Kulhavy <brain@jikos.cz>
Acked-by: Steve Rae <steve.rae@raedomain.com>
Add special target "mbr" (otherwise configurable via CONFIG_FASTBOOT_MBR_NAME)
to write MBR partition table.
Partitions are now searched using the generic function which finds any
partiiton by name. For MBR the partition names hda1, sda1, etc. are used.
So far partition search by name has been supported only on the EFI partition
table. This patch extends the search to all partition tables.
Rename part_get_info_efi_by_name() to part_get_info_by_name(), move it from
part_efi.c into part.c and make it a generic function which traverses all part
drivers and searches all partitions (in the order given by the linked list).
For this a new variable struct part_driver.max_entries is added, which limits
the number of partitions searched. For EFI this was GPT_ENTRY_NUMBERS.
Similarly the limit is defined for DOS, ISO, MAC and AMIGA partition tables.
The calculation of "dev_desc->lba - 34 - 1 - offset" is not correct for
size '-', because both fist_usable_lba and last_usable_lba will remain
34 sectors.
We can simply use 0 for size '-' because the part_efi module will decode
the size and auto extend the size to maximum available size.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
This fixes a mismatch between the %zu format and the type used on sandbox.
Partitions on the iso el torito partition table interpreter
only start from partition 1. So when printing out the tables,
let's also start counting at 1.
the last value acceptable value for offset is last_usable_lba + 1
and not last_usable_lba - 1
issue found with SDCARD partition commands on u-boot 2015.10
but this part of code don't change
1- create GPT partion on all the card
> gpt write mmc 0 name=test,start=0,size=0
> part list mmc 0
Partition Map for MMC device 0 -- Partition Type: EFI
Part Start LBA End LBA Name
Attributes
Type GUID
Partition GUID
1 0x00000022 0x003a9fde "test"
attrs: 0x0000000000000000
type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
type: data
guid: b710eb04-45b9-e94a-8d0b-21458d596f54
=> Start = 0x22*512 = 0x4400
=> Size = (0x003a9fde-0x22+1) * 512 = 0x753F7A00
2- try to recreate the same partition with the next command
(block size:512 bytes = 0x200)
> gpt write mmc 0 name=test,start=0x4400,size=0x753F7A00
Writing GPT: Partitions layout exceds disk size
> gpt write mmc 0 name=test,start=0x4400,size=0x753F7800
> gpt write mmc 0 name=test,start=0x4400,size=0x753F7600
Writing GPT: success!
Attributes
Type GUID
Partition GUID
1 0x00000022 0x003a9fdc "test"
type: data
guid: 36ec30ef-7ca4-cd48-97cd-ea9fb95185d0
the max LBA when the size is indicated (0x003a9fdc) is lower than
when u-boot compute the max allowed value with size=0 (0x003a9fde)
in the code :
/* partition ending lba */
if ((i == parts - 1) && (partitions[i].size == 0))
/* extend the last partition to maximuim */
gpt_e[i].ending_lba = gpt_h->last_usable_lba;
else
gpt_e[i].ending_lba = cpu_to_le64(offset - 1);
so offset = gpt_h->last_usable_lba + 1 is acceptable !
but the test (offset >= last_usable_lba) cause the error
END
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>disk: part_efi: fix check of the max partition size
the last value acceptable value for offset is (last_usable_lba + 1)
and not (last_usable_lba - 1)
1- I create GPT partion on all the card (start and size undefined)
> part list mmc 0
Attributes
Type GUID
Partition GUID
type: data
2- I try to recreate the same partition with the command gpt write
and with start and size values (block size:512 bytes = 0x200)
I check the partition created :
> part list mmc 0
Attributes
Type GUID
Partition GUID
type: data
=> but the max LBA when the size is indicated (0x003a9fdc) is lower than
3- in the code, just after my patch, line 446
else
(it the value used when size is 0)
but today the test (offset >= last_usable_lba) cause the error
my patch only solve this issue
END
Return -EINVAL instead of -1 in this function, to provide a more meaningful
error.
This is not needed since we can use the functions provided by the legacy
block device support.
Drop use of the table in part.c for this feature.
This function is implemented by the legacy block functions now. Drop it.
We cannot yet make sata_dev_desc[] private to common/sata.c as it is used by
the SATA drivers. This will require the SATA interface to be reworked.
Instead of calling xx_get_dev() functions for each interface type, use the
new legacy block driver which can provide the device through its interface.
This option currently enables both the command and the SCSI functionality.
Rename the existing option to CONFIG_SCSI since most of the code relates
to the feature.
Real CD-ROMs are pretty obsolete these days. Usually people still keep
iso files around, but just put them on USB sticks or SD cards and expect
them to "just work".
To support this use case with El Torito images, add support for 512 byte
sector size to the iso parsing code.
The generic partition code treats partition 0 as "whole disk". So
we should start with partition 1 as the first partition in the iso
partition table.
The iso partition table implementation has a few endian and 64bit
problems. Clean it up a bit to become endian and bitness safe.
Fixes the following warning with PART_DEBUG enabled:
disk/part.c: In function ‘get_partition_info’:
disk/part.c:372:3: warning: format ‘%s’ expects a matching ‘char *’ argument [-Wformat]
Signed-off-by: Nishanth Menon <nm@ti.com>
Add a block device cache to speed up repeated reads of block devices by
various filesystems.
This small amount of cache can dramatically speed up filesystem
operations by skipping repeated reads of common areas of a block
device (typically directory structures).
This has shown to have some benefit on FAT filesystem operations of
loading a kernel and RAM disk, but more dramatic benefits on ext4
filesystems when the kernel and/or RAM disk are spread across
multiple extent header structures as described in commit fc0fc50.
The cache is implemented through a minimal list (block_cache) maintained
in most-recently-used order and count of the current number of entries
(cache_count). It uses a maximum block count setting to prevent copies
of large block reads and an upper bound on the number of cached areas.
The maximum number of entries in the cache defaults to 32 and the maximum
number of blocks per cache entry has a default of 2, which has shown to
produce the best results on testing of ext4 and FAT filesystems.
The 'blkcache' command (enabled through CONFIG_CMD_BLOCK_CACHE) allows
changing these values and can be used to tune for a particular filesystem
layout.
Signed-off-by: Eric Nelson <eric@nelint.com>
This cannot be NULL since part_get_info() calls this function and requires
it to be non-NULL.
Reported-by: Coverity (CID: 138497)
This cannot be NULL since part_print() calls this function and requires it
to be non-NULL.
Reported-by: Coverity (CID: 138498)
One of these is causing a coverity warning. Drop these functions and use the
standard U-Boot ones instead.
Reported-by: Coverity (CID: 138499)
We have a pretty nice and generic interface to ask for a specific block
device. However, that one is still based around the magic notion that
we know the driver name.
In order to be able to write fully generic disk access code, expose the
currently internal list to other source files so that they can scan through
all available block drivers.
Rename these functions so that part_ is at the start. This more clearly
identifies these functions as partition functions.
To ease conversion to driver model, add helper functions which deal with
calling each block device method. With driver model we can reimplement these
functions with the same arguments.
Use inline functions to avoid increasing code size on some boards.
This is a device number, and we want to use 'dev' to mean a driver model
device. Rename the member.
Rename three partition functions so that they start with part_. This makes
it clear what they relate to.
We can use linker lists instead of explicitly declaring each function.
This makes the code shorter by avoiding switch() statements and lots of
header file declarations.
While this does clean up the code it introduces a few code issues with SPL.
SPL never needs to print partition information since this all happens from
commands. SPL mostly doesn't need to obtain information about a partition
either, except in a few cases. Add these cases so that the code will be
dropped from each partition driver when not needed. This avoids code bloat.
I think this is still a win, since it is not a bad thing to be explicit
about which features are used in SPL. But others may like to weigh in.
In part_amiga.c the name is unsigned but bcpl_strcpy() requires a signed
pointer. Add a cast to fix the warning.
Rename this function to blk_get_device_part_str(). This is a better name
because it makes it clear that the function returns a block device and
parses a string.
The current name is too generic. The function returns a block device based
on a provided string. Rename it to aid searching and make its purpose
clearer. Also add a few comments.
The current name is too generic. Add a 'blk_' prefix to aid searching and
make its purpose clearer.
Adjust the cast to avoid a warning when stdint.h is used.
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long
and causes 80-column violations, rename it to struct blk_desc.
On bootup the emmc's hw partition is always set to 0 and the partition
table is read from it. When switching to another hw partition the
partition table's id is not updated but instead the old one from
hw partition 0 is used. If there is no partition table on hw partition 0
then the code will terminate and return error even if the desired hw
partition contains a perfectly fine partition table. This fix updates
the partition table struct to correspond to the specified hw partition
before testing if the partition table is valid or not.
Signed-off-by: Erik Tideman <erik.tideman@faltcom.se>
[trini: Squash the patch that corrected whitespace in the original into
this one, wrap with HAVE_BLOCK_DEVICE test]
With format-security errors turned on, GCC picks up the use of sprintf with
a format parameter not being a string literal.
Simple uses of sprintf are also converted to use strcpy.
Signed-off-by: Ben Whitten <ben.whitten@gmail.com>
Acked-by: Wolfgang Denk <wd@denx.de>
This will allow the implementation to make use of data in the block_dev
structure beyond the base device number. This will be useful so that eMMC
block devices can encompass the HW partition ID rather than treating this
out-of-band. Equally, the existence of the priv field is crying out for
this patch to exist.
In order to support large IDE disks we need to make certain types be
lbaint_t now.
Signed-off-by: Stefan Monnier <monnier@iro.umontreal.ca>
The optional parameter bootable is added in gpt command to set the
partition attribute flag "Legacy BIOS bootable"
This flag is used in extlinux and so in with distro to select
the boot partition where is located the configuration file
(please check out doc/README.distro for details).
With this parameter, U-Boot can be used to create the boot partition
needed for device using distro.
example of use:
setenv partitions "name=u-boot,size=60MiB;name=boot,size=60Mib,bootable;\
name=rootfs,size=0"
> gpt write mmc 0 $partitions
> part list mmc 0
Attributes
Type GUID
Partition GUID
1 0x00000022 0x0001e021 "u-boot"
guid: cceb0b18-39cb-d547-9db7-03b405fa77d4
2 0x0001e022 0x0003c021 "boot"
attrs: 0x0000000000000004
guid: d4981a2b-0478-544e-9607-7fd3c651068d
3 0x0003c022 0x003a9fde "rootfs"
guid: 6d6c9a36-e919-264d-a9ee-bd00379686c7
> part list mmc 0 -bootable devplist
> printenv devplist
devplist=2
Then the distro scripts will search extlinux in partition 2
and not in the first partition.
This commit provides definition and declaration of GPT verification
functions - namely gpt_verify_headers() and gpt_verify_partitions().
The former is used to only check CRC32 of GPT's header and PTEs.
The latter examines each partition entry and compare attributes such as:
name, start offset and size with ones provided at '$partitions' env
variable.
Signed-off-by: Lukasz Majewski <l.majewski@majess.pl>
Reviewed-by: Przemyslaw Marczak <p.marczak@samsung.com>
short strings can be used in type parameter of gpt command
to replace the guid string for the types known by u-boot
partitions = name=boot,size=0x6bc00,type=data; \
name=root,size=0x7538ba00,type=linux;
and they are also used to display the type of partition
in "part list" command
Attributes
Type GUID
Partition GUID
1 0x00000022 0x0000037f "boot"
type: data
guid: d117f98e-6f2c-d04b-a5b2-331a19f91cb2
2 0x00000380 0x003a9fdc "root"
type: 0fc63daf-8483-4772-8e79-3d69d8477de4
type: linux
guid: 25718777-d0ad-7443-9e60-02cb591c9737
code under flag CONFIG_PARTITION_TYPE_GUID
add parameter "type" to select partition type guid
example of use with gpt command :
partitions = uuid_disk=${uuid_gpt_disk}; \
name=boot,size=0x6bc00,uuid=${uuid_gpt_boot}; \
name=root,size=0x7538ba00,uuid=${uuid_gpt_root}, \
type=0fc63daf-8483-4772-8e79-3d69d8477de4;
Add generic fs support, so that commands like ls, load and test -e can be
used on ubifs.
This is not necessary / useful when not building with CONFIG_SANDBOX and
with the addition of ubifs support to the generic fs commands it actually
gets in the way, since both operate on a fake / NULL blkdev.
