2003-06-27 | * Code cleanup:LABEL_2003_06_27_2340 | wdenk | |
- remove trailing white space, trailing empty lines, C++ comments, etc. - split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c) * Patches by Kenneth Johansson, 25 Jun 2003: - major rework of command structure (work done mostly by Michal Cendrowski and Joakim Kristiansen) | |||
2002-11-19 | * Patch by Thomas Frieden, 13 Nov 2002: | wdenk | |
Add code for AmigaOne board (preliminary merge to U-Boot, still WIP) * Patch by Jon Diekema, 12 Nov 2002: - Adding URL for IEEE OUI lookup - Making the autoboot #defines dependent on CONFIG_AUTOBOOT_KEYED being defined. - In the CONFIG_EXTRA_ENV_SETTINGS #define, the root-on-initrd and root-on-nfs macros are designed to switch how the default boot method gets defined. | |||
2002-11-03 | Initial revision | wdenk | |
