path: root/disk/part_efi.c
2019-12-02crc32: Use the crc.h header for crc functionsSimon Glass
Drop inclusion of crc.h in common.h and use the correct header directly instead. With this we can drop the conflicting definition in fw_env.h and rely on the crc.h header, which is already included. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-08-23disk: efi: ignore 'IGNOREME' GPT header found on cros eMMCsUrja Rannikko
Some ChromeOS devices (atleast veyron speedy) have the first 8MiB of the eMMC write protected and equipped with a dummy 'IGNOREME' GPT header - instead of spewing error messages about it, just silently try the backup GPT. Note: this does not touch the gpt cmd writing/verifying functions, those will still complain. Signed-off-by: Urja Rannikko <urjaman@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-08-23disk: efi: unify code for finding a valid gptUrja Rannikko
There were 3 copies of the same sequence, make it into a function. Signed-off-by: Urja Rannikko <urjaman@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-16disk: efi: avoid unaligned pointer errorHeinrich Schuchardt
When building with GCC 9.1 an error occurs: disk/part_efi.c: In function ‘gpt_verify_partitions’: disk/part_efi.c:737:49: error: taking address of packed member of ‘struct _gpt_entry’ may result in an unaligned pointer value [-Werror=address-of-packed-member] 737 | gpt_convert_efi_name_to_char(efi_str, gpt_e[i].partition_name, | ~~~~~~~~^~~~~~~~~~~~~~~ cc1: all warnings being treated as errors make[1]: *** [scripts/Makefile.build:279: disk/part_efi.o] Error 1 make: *** [Makefile:1594: disk] Error 2 Adjust gpt_convert_efi_name_to_char() to accept unaligned strings. Reported-by: Ramon Fried <rfried.dev@gmail.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-07-06disk: efi: buffer overflow in part_get_info_efi()Heinrich Schuchardt
In part_get_info_efi() we use the output of print_efiname() to set info->name[]. The size of info->name is PART_NAME_LEN = 32 but print_efiname() returns a string with a maximum length of PARTNAME_SZ + 1 = 37. Use snprintf() instead of sprintf() to avoid buffer overflow. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-02disk: efi: Fix memory leak on 'gpt verify'Eugeniu Rosca
Below is what happens on R-Car H3ULCB-KF using clean U-Boot v2019.04-00810-g6aebc0d11a10 and r8a7795_ulcb_defconfig: => ### interrupt autoboot => gpt verify mmc 1 No partition list provided - only basic check Verify GPT: success! => ### keep calling 'gpt verify mmc 1' => ### on 58th call, we are out of memory: => gpt verify mmc 1 alloc_read_gpt_entries: ERROR: Can't allocate 0X4000 bytes for GPT Entries GPT: Failed to allocate memory for PTE gpt_verify_headers: *** ERROR: Invalid Backup GPT *** Verify GPT: error! This is caused by calling is_gpt_valid() twice (hence allocating pte also twice via alloc_read_gpt_entries()) while freeing pte only _once_ in the caller of gpt_verify_headers(). Fix that by freeing the pte allocated and populated for primary GPT _before_ allocating and populating the pte for backup GPT. The latter will be freed by the caller of gpt_verify_headers(). With the fix applied, the reproduction scenario [1-2] has been run hundreds of times in a loop w/o running into OOM. [1] gpt verify mmc 1 [2] gpt verify mmc 1 $partitions Fixes: cef68bf9042dda ("gpt: part: Definition and declaration of GPT verification functions") Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-02disk: efi: Fix memory leak on 'gpt guid'Eugeniu Rosca
Below is what happens on R-Car H3ULCB-KF using clean U-Boot v2019.04-00810-g6aebc0d11a10 and r8a7795_ulcb_defconfig: => ### interrupt autoboot => gpt guid mmc 1 21200400-0804-0146-9dcc-a8c51255994f success! => ### keep calling 'gpt guid mmc 1' => ### on 59th call, we are out of memory: => gpt guid mmc 1 alloc_read_gpt_entries: ERROR: Can't allocate 0X4000 bytes for GPT Entries GPT: Failed to allocate memory for PTE get_disk_guid: *** ERROR: Invalid GPT *** alloc_read_gpt_entries: ERROR: Can't allocate 0X4000 bytes for GPT Entries GPT: Failed to allocate memory for PTE get_disk_guid: *** ERROR: Invalid Backup GPT *** error! After some inspection, it looks like get_disk_guid(), added via v2017.09 commit 73d6d18b7147c9 ("GPT: add accessor function for disk GUID"), unlike other callers of is_gpt_valid(), doesn't free the memory pointed out by 'gpt_entry *gpt_pte'. The latter is allocated by is_gpt_valid() via alloc_read_gpt_entries(). With the fix applied, the reproduction scenario has been run hundreds of times ('while true; do gpt guid mmc 1; done') w/o running into OOM. Fixes: 73d6d18b7147c9 ("GPT: add accessor function for disk GUID") Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-01-18disk: efi: GUIDs should be constHeinrich Schuchardt
Make system_guid const. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-09Rename GPT_HEADER_SIGNATURE to avoid conflictSimon Glass
The current name conflicts with the Chrome OS verified boot library, which prevents it being built. That library uses a string whereas U-Boot uses a 64-bit hex value. Rename this in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-10Remove <inttypes.h> includes and PRI* usages in printf() entirelyMasahiro Yamada
In int-ll64.h, we always use the following typedefs: typedef unsigned int u32; typedef unsigned long uintptr_t; typedef unsigned long long u64; This does not need to match to the compiler's <inttypes.h>. Do not include it. The use of PRI* makes the code super-ugly. You can simply use "l" for printing uintptr_t, "ll" for u64, and no modifier for u32. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-06-14efi_loader: avoid initializer element is not constantHeinrich Schuchardt
When building with -pedantic the current definition of EFI_GUID() causes an error 'initializer element is not constant'. Currently EFI_GUID() is used both as an anonymous constant and as an intializer. A conversion to efi_guid_t is not allowable when using EFI_GUID() as an initializer. But it is needed when using it as an anonymous constant. We should not use EFI_GUID() for anything but an initializer. So let's introduce a variable where needed and remove the conversion. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-06-05disk: efi: Correct backing up the MBR boot codeSam Protsenko
In commit e163a931af34 ("cmd: gpt: backup boot code before writing MBR") there was added the procedure for storing old boot code when doing "gpt write". But instead of storing just backup code, the whole MBR was stored, and only specific fields were replaced further, keeping everything else intact. That's obviously not what we want. Fix the code to actually store only old boot code and zero out everything else. This fixes next testing case: => mmc write $loadaddr 0x0 0x7b => gpt write mmc 1 $partitions In case when $loadaddr address and further memory contains 0xff, the board was bricked (ROM-code probably didn't like partition entries that were clobbered with 0xff). With this patch applied, commands above don't brick the board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Cc: Alejandro Hernandez <ajhernandez@ti.com> Tested-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2018-02-08Move most CONFIG_HAVE_BLOCK_DEVICE to KconfigAdam Ford
config_fallbacks.h has some logic that sets HAVE_BLOCK_DEVICE based on a list of enabled options. Moving HAVE_BLOCK_DEVICE to Kconfig allows us to drastically shrink the logic in config_fallbacks.h Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rename HAVE_BLOCK_DEVICE to CONFIG_BLOCK_DEVICE] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-11-29disk: efi: correct the allocation size for mbr header in stackPatrick Delaunay
use ALLOC_CACHE_ALIGN_BUFFER_PAD for mbr header allocation in stack to fix alloc issue in is_gpt_valid() this patch fix also issue for GPT partition handling with blocksize != 512 in set_protective_mbr() Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-11-06gpt: Use cache aligned buffers for gpt_h and gpt_eLukasz Majewski
Before this patch one could receive following errors when executing "gpt write" command on machine with cache enabled: display5 factory > gpt write mmc ${mmcdev} ${partitions} Writing GPT: CACHE: Misaligned operation at range [4ef8f7f0, 4ef8f9f0] CACHE: Misaligned operation at range [4ef8f9f8, 4ef939f8] CACHE: Misaligned operation at range [4ef8f9f8, 4ef939f8] CACHE: Misaligned operation at range [4ef8f7f0, 4ef8f9f0] success! To alleviate this problem - the calloc()s have been replaced with malloc_cache_aligned() and memset(). After those changes the buffers are properly aligned (with both start address and size) to SoC cache line. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2017-10-23disk: efi: correct the overlap check on GPT header and PTEPatrick Delaunay
the partition starting at 0x4400 is refused with overlap error: $> gpt write mmc 0 "name=test,start=0x4400,size=0" Writing GPT: Partition overlap error! even if the 0x4400 is the first available offset for LBA35 with default value: - MBR=LBA1 - GPT header=LBA2 - PTE= 32 LBAs (128 entry), 3 to 34 And the command to have one partition for all the disk failed also : $> gpt write mmc 0 "name=test,size=0" After the patch : $> gpt write mmc 0 "name=test,size=0" Writing GPT: success! $> part list mmc 0 Partition Map for MMC device 0 -- Partition Type: EFI Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00000022 0x01ce9fde "test" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 type: data guid: b4b84b8a-04e3-4000-0036-aff5c9c495b1 And 0x22 = 34 LBA => offset = 0x4400 is accepted as expected Reviewed-by: Łukasz Majewski <lukma@denx.de> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-10-16part_efi: In is_gpt_valid() check argument validity before allocationTom Rini
While this goes somewhat against normal coding style we should ensure that dev_desc is not NULL before we dereference it in allocation of legacy_mbr. Reported-by: Coverity (CID: 167292) Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-20part: extract MBR signature from partitionsPeter Jones
EFI client programs need the signature information from the partition table to determine the disk a partition is on, so we need to fill that in here. Signed-off-by: Peter Jones <pjones@redhat.com> [separated from efi_loader part, and fixed build-errors for non- CONFIG_EFI_PARTITION case] Signed-off-by: Rob Clark <robdclark@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-09-03part: efi: Disable overlap checkMaxime Ripard
The current code checks that no partitions overlap with the GPT partition table using the offset of the first LBA usable for that partition. This works fine, unless you have a partition entry that is further away than it usually is and you want to create partitions in the gap between the GPT header and the GPT partition entries, for example to reflash a bootloader that needs to be set there. Rework the test to something a bit smarter that checks whether a partition would overlap with either the GPT header or the partition entries, no matter where it is on the disk. Partitions that do not have a start LBA specified will still start at the first LBA usable set in the GPT header, to avoid weird behaviours. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03part: efi: make gpt_fill_pte take the device descriptorMaxime Ripard
The gpt_fill_pte will need to access the device block size. Let's pass the device descriptor as an argument. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03part: efi: rework the partition start and size in gpt_fill_pteMaxime Ripard
The start variable is only used inside a loop, and is never affected inside it, so it's a purely local variable. In the same way the partition size is accessed several times, so we can store it in a variable. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03part: efi: Fix offsetMaxime Ripard
Both the config option and the DT options specify the offset to set the GPT at in bytes, yet the code treats those values as block numbers. Fix that. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-04GPT: add accessor function for disk GUIDAlison Chaiken
In order to read the GPT, modify the partition name strings, and then write out a new GPT, the disk GUID is needed. While there is an existing accessor for the partition UUIDs, there is none yet for the disk GUID. Changes since v6: none. Signed-off-by: Alison Chaiken <alison@peloton-tech.com>
2017-08-04EFI: replace number with UUID_STR_LEN macroAlison Chaiken
2017-03-20part_efi: support padding between the GPT header and partition entriesPhilipp Tomsich
Some architectures require their SPL loader at a fixed address within the first 16KB of the disk. To avoid an overlap with the partition entries of the EFI partition table, the first safe offset (in bytes, from the start of the device) for the entries can be set through CONFIG_EFI_PARTITION_ENTRIES_OFF (via Kconfig) When formatting a device with an EFI partition table, we may need to leave a gap between the GPT header (always in LBA 1) and the partition entries. The GPT header already contains a field to specify the on-disk location, which has so far always been set to LBA 2. With this change, a configurable offset will be translated into a LBA address indicating where to put the entries. Now also allows an override via device-tree using a config-node (see doc/device-tree-bindings/config.txt for documentation). Tested (exporting an internal MMC formatted with this) against Linux, MacOS X and Windows. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: __maybe_unused on config_offset to avoid warning] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-17gpt: Fix uuid string formatVincent Tinelli
Change GPT UUID string format from UUID to GUID per specification. Signed-off-by: Vincent Tinelli <vincent.tinelli@intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-08cmd: gpt: backup boot code before writing MBRVincent Tinelli
On some cases the first 440 bytes of MBR are used to keep an additional information for ROM boot loader. 'gpt write' command doesn't preserve that area and makes boot code gone. Preserve boot code area when run 'gpt write' command. Signed-off-by: Vincent Tinelli <vincent.tinelli@intel.com> Signed-off-by: Brennan Ashton <brn@deako.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-01disk: part: implement generic function part_get_info_by_name()Petr Kulhavy
So far partition search by name has been supported only on the EFI partition table. This patch extends the search to all partition tables. Rename part_get_info_efi_by_name() to part_get_info_by_name(), move it from part_efi.c into part.c and make it a generic function which traverses all part drivers and searches all partitions (in the order given by the linked list). For this a new variable struct part_driver.max_entries is added, which limits the number of partitions searched. For EFI this was GPT_ENTRY_NUMBERS. Similarly the limit is defined for DOS, ISO, MAC and AMIGA partition tables. Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com>
2016-08-05cmd: gpt: fix the wrong size parse for the last partitionKever Yang
The calculation of "dev_desc->lba - 34 - 1 - offset" is not correct for size '-', because both fist_usable_lba and last_usable_lba will remain 34 sectors. We can simply use 0 for size '-' because the part_efi module will decode the size and auto extend the size to maximum available size. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2016-07-25part_efi: Fix compiler warning on 32-bit sandboxSimon Glass
This fixes a mismatch between the %zu format and the type used on sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-27disk: part_efi: fix check of the max partition sizePatrick Delaunay
the last value acceptable value for offset is last_usable_lba + 1 and not last_usable_lba - 1 issue found with SDCARD partition commands on u-boot 2015.10 but this part of code don't change 1- create GPT partion on all the card > gpt write mmc 0 name=test,start=0,size=0 > part list mmc 0 Partition Map for MMC device 0 -- Partition Type: EFI Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00000022 0x003a9fde "test" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 type: data guid: b710eb04-45b9-e94a-8d0b-21458d596f54 => Start = 0x22*512 = 0x4400 => Size = (0x003a9fde-0x22+1) * 512 = 0x753F7A00 2- try to recreate the same partition with the next command (block size:512 bytes = 0x200) > gpt write mmc 0 name=test,start=0x4400,size=0x753F7A00 Writing GPT: Partitions layout exceds disk size > gpt write mmc 0 name=test,start=0x4400,size=0x753F7800 Writing GPT: Partitions layout exceds disk size > gpt write mmc 0 name=test,start=0x4400,size=0x753F7600 Writing GPT: success! Partition Map for MMC device 0 -- Partition Type: EFI Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00000022 0x003a9fdc "test" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 type: data guid: 36ec30ef-7ca4-cd48-97cd-ea9fb95185d0 the max LBA when the size is indicated (0x003a9fdc) is lower than when u-boot compute the max allowed value with size=0 (0x003a9fde) in the code : /* partition ending lba */ if ((i == parts - 1) && (partitions[i].size == 0)) /* extend the last partition to maximuim */ gpt_e[i].ending_lba = gpt_h->last_usable_lba; else gpt_e[i].ending_lba = cpu_to_le64(offset - 1); so offset = gpt_h->last_usable_lba + 1 is acceptable ! but the test (offset >= last_usable_lba) cause the error END Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>disk: part_efi: fix check of the max partition size the last value acceptable value for offset is (last_usable_lba + 1) and not (last_usable_lba - 1) issue found with SDCARD partition commands on u-boot 2015.10 but this part of code don't change 1- I create GPT partion on all the card (start and size undefined) > gpt write mmc 0 name=test,start=0,size=0 > part list mmc 0 Partition Map for MMC device 0 -- Partition Type: EFI Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00000022 0x003a9fde "test" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 type: data guid: b710eb04-45b9-e94a-8d0b-21458d596f54 => Start = 0x22*512 = 0x4400 => Size = (0x003a9fde-0x22+1) * 512 = 0x753F7A00 2- I try to recreate the same partition with the command gpt write and with start and size values (block size:512 bytes = 0x200) > gpt write mmc 0 name=test,start=0x4400,size=0x753F7A00 Writing GPT: Partitions layout exceds disk size > gpt write mmc 0 name=test,start=0x4400,size=0x753F7800 Writing GPT: Partitions layout exceds disk size > gpt write mmc 0 name=test,start=0x4400,size=0x753F7600 Writing GPT: success! I check the partition created : > part list mmc 0 Partition Map for MMC device 0 -- Partition Type: EFI Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00000022 0x003a9fdc "test" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 type: data guid: 36ec30ef-7ca4-cd48-97cd-ea9fb95185d0 => but the max LBA when the size is indicated (0x003a9fdc) is lower than when u-boot compute the max allowed value with size=0 (0x003a9fde) 3- in the code, just after my patch, line 446 /* partition ending lba */ if ((i == parts - 1) && (partitions[i].size == 0)) /* extend the last partition to maximuim */ gpt_e[i].ending_lba = gpt_h->last_usable_lba; else gpt_e[i].ending_lba = cpu_to_le64(offset - 1); so offset = gpt_h->last_usable_lba + 1 is acceptable ! (it the value used when size is 0) but today the test (offset >= last_usable_lba) cause the error my patch only solve this issue END Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
2016-03-22part_efi: Drop NULL check in part_get_info_efi()Simon Glass
This cannot be NULL since part_get_info() calls this function and requires it to be non-NULL. Reported-by: Coverity (CID: 138497) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-22part_efi: Drop the NULL check on dev_desc in part_print_efi()Simon Glass
This cannot be NULL since part_print() calls this function and requires it to be non-NULL. Reported-by: Coverity (CID: 138498) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14part: Rename test_part_xx() and print_part_xx()Simon Glass
Rename these functions so that part_ is at the start. This more clearly identifies these functions as partition functions. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14dm: block: Adjust device calls to go through helpers functionSimon Glass
To ease conversion to driver model, add helper functions which deal with calling each block device method. With driver model we can reimplement these functions with the same arguments. Use inline functions to avoid increasing code size on some boards. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: block: Rename device number member dev to devnumSimon Glass
This is a device number, and we want to use 'dev' to mean a driver model device. Rename the member. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: part: Rename some partition functionsSimon Glass
Rename three partition functions so that they start with part_. This makes it clear what they relate to. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: part: Convert partition API use to linker listsSimon Glass
We can use linker lists instead of explicitly declaring each function. This makes the code shorter by avoiding switch() statements and lots of header file declarations. While this does clean up the code it introduces a few code issues with SPL. SPL never needs to print partition information since this all happens from commands. SPL mostly doesn't need to obtain information about a partition either, except in a few cases. Add these cases so that the code will be dropped from each partition driver when not needed. This avoids code bloat. I think this is still a win, since it is not a bad thing to be explicit about which features are used in SPL. But others may like to weigh in. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: part: Correct a sandbox build warningSimon Glass
Adjust the cast to avoid a warning when stdint.h is used. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-14Fix GCC format-security errors and convert sprintfs.Ben Whitten
With format-security errors turned on, GCC picks up the use of sprintf with a format parameter not being a string literal. Simple uses of sprintf are also converted to use strcpy. Signed-off-by: Ben Whitten <ben.whitten@gmail.com> Acked-by: Wolfgang Denk <wd@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-13block: pass block dev not num to read/write/erase()Stephen Warren
This will allow the implementation to make use of data in the block_dev structure beyond the base device number. This will be useful so that eMMC block devices can encompass the HW partition ID rather than treating this out-of-band. Equally, the existence of the priv field is crying out for this patch to exist. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-23part:efi: add bootable parameter in gpt commandPatrick Delaunay
The optional parameter bootable is added in gpt command to set the partition attribute flag "Legacy BIOS bootable" This flag is used in extlinux and so in with distro to select the boot partition where is located the configuration file (please check out doc/README.distro for details). With this parameter, U-Boot can be used to create the boot partition needed for device using distro. example of use: setenv partitions "name=u-boot,size=60MiB;name=boot,size=60Mib,bootable;\ name=rootfs,size=0" > gpt write mmc 0 $partitions > part list mmc 0 Partition Map for MMC device 0 -- Partition Type: EFI Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00000022 0x0001e021 "u-boot" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 guid: cceb0b18-39cb-d547-9db7-03b405fa77d4 2 0x0001e022 0x0003c021 "boot" attrs: 0x0000000000000004 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 guid: d4981a2b-0478-544e-9607-7fd3c651068d 3 0x0003c022 0x003a9fde "rootfs" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 guid: 6d6c9a36-e919-264d-a9ee-bd00379686c7 > part list mmc 0 -bootable devplist > printenv devplist devplist=2 Then the distro scripts will search extlinux in partition 2 and not in the first partition. Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
2015-11-23gpt: part: Definition and declaration of GPT verification functionsLukasz Majewski
This commit provides definition and declaration of GPT verification functions - namely gpt_verify_headers() and gpt_verify_partitions(). The former is used to only check CRC32 of GPT's header and PTEs. The latter examines each partition entry and compare attributes such as: name, start offset and size with ones provided at '$partitions' env variable. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-11-12uuid: add selection by string for known partition type GUIDPatrick Delaunay
short strings can be used in type parameter of gpt command to replace the guid string for the types known by u-boot partitions = name=boot,size=0x6bc00,type=data; \ name=root,size=0x7538ba00,type=linux; gpt write mmc 0 $partitions and they are also used to display the type of partition in "part list" command Partition Map for MMC device 0 -- Partition Type: EFI Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00000022 0x0000037f "boot" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 type: data guid: d117f98e-6f2c-d04b-a5b2-331a19f91cb2 2 0x00000380 0x003a9fdc "root" attrs: 0x0000000000000000 type: 0fc63daf-8483-4772-8e79-3d69d8477de4 type: linux guid: 25718777-d0ad-7443-9e60-02cb591c9737 Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
2015-11-12gpt: add optional parameter type in gpt commandPatrick Delaunay
code under flag CONFIG_PARTITION_TYPE_GUID add parameter "type" to select partition type guid example of use with gpt command : partitions = uuid_disk=${uuid_gpt_disk}; \ name=boot,size=0x6bc00,uuid=${uuid_gpt_boot}; \ name=root,size=0x7538ba00,uuid=${uuid_gpt_root}, \ type=0fc63daf-8483-4772-8e79-3d69d8477de4; gpt write mmc 0 $partitions Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
