When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
[trini: Fixup common/cmd_io.c]
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
Add code for AmigaOne board
(preliminary merge to U-Boot, still WIP)
* Patch by Jon Diekema, 12 Nov 2002:
- Adding URL for IEEE OUI lookup
- Making the autoboot #defines dependent on CONFIG_AUTOBOOT_KEYED
being defined.
- In the CONFIG_EXTRA_ENV_SETTINGS #define, the root-on-initrd and
root-on-nfs macros are designed to switch how the default boot
method gets defined.
