path: root/disk/part_amiga.c
2005-02-24Cleanup USB and partition defineswdenk
2003-06-29Fix some missing commands, cleanup header filesU-Boot-0_4_1wdenk
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
