path: root/disk/part_amiga.c
2018-02-08Move most CONFIG_HAVE_BLOCK_DEVICE to KconfigAdam Ford
config_fallbacks.h has some logic that sets HAVE_BLOCK_DEVICE based on a list of enabled options. Moving HAVE_BLOCK_DEVICE to Kconfig allows us to drastically shrink the logic in config_fallbacks.h Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rename HAVE_BLOCK_DEVICE to CONFIG_BLOCK_DEVICE] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-01disk: part: implement generic function part_get_info_by_name()Petr Kulhavy
So far partition search by name has been supported only on the EFI partition table. This patch extends the search to all partition tables. Rename part_get_info_efi_by_name() to part_get_info_by_name(), move it from part_efi.c into part.c and make it a generic function which traverses all part drivers and searches all partitions (in the order given by the linked list). For this a new variable struct part_driver.max_entries is added, which limits the number of partitions searched. For EFI this was GPT_ENTRY_NUMBERS. Similarly the limit is defined for DOS, ISO, MAC and AMIGA partition tables. Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com>
2016-03-14part: Rename test_part_xx() and print_part_xx()Simon Glass
Rename these functions so that part_ is at the start. This more clearly identifies these functions as partition functions. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14dm: block: Adjust device calls to go through helpers functionSimon Glass
To ease conversion to driver model, add helper functions which deal with calling each block device method. With driver model we can reimplement these functions with the same arguments. Use inline functions to avoid increasing code size on some boards. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: part: Rename some partition functionsSimon Glass
Rename three partition functions so that they start with part_. This makes it clear what they relate to. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: part: Convert partition API use to linker listsSimon Glass
We can use linker lists instead of explicitly declaring each function. This makes the code shorter by avoiding switch() statements and lots of header file declarations. While this does clean up the code it introduces a few code issues with SPL. SPL never needs to print partition information since this all happens from commands. SPL mostly doesn't need to obtain information about a partition either, except in a few cases. Add these cases so that the code will be dropped from each partition driver when not needed. This avoids code bloat. I think this is still a win, since it is not a bad thing to be explicit about which features are used in SPL. But others may like to weigh in. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: part: Add a cast to avoid a compiler warningSimon Glass
In part_amiga.c the name is unsigned but bcpl_strcpy() requires a signed pointer. Add a cast to fix the warning. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-13block: pass block dev not num to read/write/erase()Stephen Warren
This will allow the implementation to make use of data in the block_dev structure beyond the base device number. This will be useful so that eMMC block devices can encompass the HW partition ID rather than treating this out-of-band. Equally, the existence of the priv field is crying out for this patch to exist. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2013-03-14disk: define HAVE_BLOCK_DEVICE in a common placeStephen Warren
This set of ifdefs is used in a number of places. Move its definition somewhere common so it doesn't have to be repeated. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-06-21Block: Remove MG DISK supportMarek Vasut
This driver is unused and obsolete. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: unsik Kim <donari75@gmail.com>
2009-04-03mflash: Initial mflash supportunsik Kim
Mflash is fusion memory device mainly targeted consumer eletronic and mobile phone. Internally, it have nand flash and other hardware logics and supports some different operation (ATA, IO, XIP) modes. IO mode is custom mode for the host that doesn't have IDE interface. (Many mobile targeted SoC doesn't have IDE bus) This driver support mflash IO mode. Followings are brief descriptions about IO mode. 1. IO mode based on ATA protocol and uses some custom command. (read confirm, write confirm) 2. IO mode uses SRAM bus interface. Signed-off-by: unsik Kim <donari75@gmail.com>
2009-02-18disk: convert part_* files to COBJ-$(CONFIG_XXX) styleMike Frysinger
Move the CONFIG_XXX out of the part_XXX.c file and into Makefile to avoid pointless compiles. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2007-07-09disk/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04disk/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2005-02-24Cleanup USB and partition defineswdenk
2003-06-29Fix some missing commands, cleanup header filesU-Boot-0_4_1wdenk
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
