path: root/disk/Makefile
2017-01-28disk: convert CONFIG_AMIGA_PARTITION to KconfigPatrick Delaunay
2017-01-28disk: convert CONFIG_MAC_PARTITION to KconfigPatrick Delaunay
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2013-10-31disk: convert a makefile to Kbuild styleMasahiro Yamada
2011-07-26disk/part.c: Make features optionalMatthew McClintock
If we don't want to build support for any partition types we can now add #undef CONFIG_PARTITIONS in a board config file to keep this from being compiled in. Otherwise boards assume this is compiled in by default Signed-off-by: Matthew McClintock <msm@freescale.com>
2009-02-18disk: convert part_* files to COBJ-$(CONFIG_XXX) styleMike Frysinger
Move the CONFIG_XXX out of the part_XXX.c file and into Makefile to avoid pointless compiles. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-18Add support for CONFIG_EFI_PARTITION (GUID Partition Table)richardretanubun
The GUID (Globally Unique Identifier) Partition Table (GPT) is a part of EFI. See http://en.wikipedia.org/wiki/GUID_Partition_Table Based on linux/fs/partitions/efi.[ch] Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com>
2007-11-15Build: split COBJS value into multiple linesGrant Likely
This change is in preparation for condtitionial compile support in the build system. By spliting them all into seperate lines now, subsequent patches that change 'COBJS-y += ' into 'COBJS-$(CONFIG_<blah>) += ' will be less invasive and easier to review Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2001-07-05Initial revisionwdenk
