Fix a build error when part.c is built in iram u-boot building.
part.c:94: error: redefinition of 'get_dev'
/home/r65388/uboot-imx-v2009.08/uboot-imx/include/part.h:117: error:
previous definition of 'get_dev' was here
make[1]: *** [part.o] Error 1
make[1]: Leaving directory
`/home/r65388/uboot-imx-v2009.08/uboot-imx/disk'
make: *** [disk/libdisk.a] Error 2
Signed-off-by: Terry Lv <r65388@freescale.com>
Move the CONFIG_XXX out of the part_XXX.c file and into Makefile to
avoid pointless compiles.
The GUID (Globally Unique Identifier) Partition Table (GPT) is a part
of EFI. See http://en.wikipedia.org/wiki/GUID_Partition_Table
Based on linux/fs/partitions/efi.[ch]
Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com>
This change is in preparation for condtitionial compile support in the
build system. By spliting them all into seperate lines now, subsequent
patches that change 'COBJS-y += ' into 'COBJS-$(CONFIG_<blah>) += ' will
be less invasive and easier to review
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
Add code for AmigaOne board
(preliminary merge to U-Boot, still WIP)
* Patch by Jon Diekema, 12 Nov 2002:
- Adding URL for IEEE OUI lookup
- Making the autoboot #defines dependent on CONFIG_AUTOBOOT_KEYED
being defined.
- In the CONFIG_EXTRA_ENV_SETTINGS #define, the root-on-initrd and
root-on-nfs macros are designed to switch how the default boot
method gets defined.
