path: root/cpu
2008-01-1685xx: Move LAW init code into CKumar Gala
Move the initialization of the LAWs into C code and provide an API to allow modification of LAWs after init. Board code is responsible to provide a law_table and num_law_entries. We should be able to use the same code on 86xx as well. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-16mpc83xx: add support for more system clock performance controlsKim Phillips
System registers that are modified are the Arbiter Configuration Register (ACR), the System Priority Control Register (SPCR), and the System Clock Configuration Register (SCCR). Signed-off by: Michael F. Reiss <Michael.F.Reiss@freescale.com> Signed-off by: Joe D'Abbraccio <ljd015@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-16mpc83xx: Add config of eTSEC emergency priority in SPCRDave Liu
The TSEC emergency priority definition of 831x/837x is different than the definition of 834x in SPCR register. Add the other config of TSEC emergency priority into cpu_init.c Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-13MPC8xx FEC driver: fix compiler warning.Wolfgang Denk
2008-01-12MPC5200: don't use hardcoded MBAR address in Bestcomm firmwareOliver Weber
Signed-off-by: Oliver Weber <almoeli@gmx.de>
2008-01-12MPC512X: Cleanup bus clock names.Grzegorz Bernacki
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2008-01-12ads5121: Added support for FDT.Grzegorz Bernacki
2008-01-12Fixed syntax error in function init_e300_core() of mpc83xx/start.S ifHeiko Schocher
Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Heiko Schocher <hs@denx.de>
2008-01-12added basic support for the MUNICes board.Heiko Schocher
2008-01-12Added support for the mgcoge board from keymile.Heiko Schocher
2008-01-12Enable SMC microcode relocation patch for SMC1.Heiko Schocher
2008-01-12Added support for the mgsuvd board from keymile.Heiko Schocher
2008-01-12Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-01-12Merge branch 'master' of git://www.denx.de/git/u-boot-mpc83xxWolfgang Denk
2008-01-10mpc83xx: Fix the bug of 266MHz data rate DDRDave Liu
The DDR doesn't work on the 266MHz data rate, the patch fix the bug. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-10mpc83xx: add "fsl, qe" compatible fixupsAnton Vorontsov
New device trees will use "fsl,qe" compatible properties. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-10Merge commit 'wd/master'Jon Loeliger
2008-01-1086xx: Support 2GB DIMMsBecky Bruce
Configure the number of bits used to address the banks inside the SDRAM device. The default register value of 0 means 2 bits to address 4 banks. Higher capacity devices like a 2GB DIMM require 3 bits to address 8 banks. Signed-off-by: Becky Bruce <bgill@freescale.com>
2008-01-10ppc4xx: Fix dflush() to restore DVLIM registerLarry Johnson
Signed-off-by: Larry Johnson <lrj@acm.org>
2008-01-10Fix Ethernet init() return codesBen Warren
Change return values of init() functions in all Ethernet drivers to conform to the following: >=0: Success <0: Failure All drivers going forward should return 0 on success. Current drivers that return 1 on success were left as-is to minimize changes. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-By: Timur Tabi <timur@freescale.com>
2008-01-09Add QE brg freq and correct qe bus freq fdt update codeKim Phillips
Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-01-0985xx: add ability to upload QE firmwareTimur Tabi
Define the layout of a binary blob that contains a QE firmware and instructions on how to upload it. Add function qe_upload_firmware() to parse the blob and perform the actual upload. Add command-line command "qe fw" to take a firmware blob in memory and upload it. Update ft_cpu_setup() on 85xx to create the 'firmware' device tree node if U-Boot has uploaded a firmware. Fully define 'struct rsp' in immap_qe.h to include the actual RISC Special Registers. Signed-off-by: Timur Tabi <timur@freescale.com>
2008-01-0985xx: Remove cache config from configs.hKumar Gala
Either use the standard defines in asm/cache.h or grab the information at runtime from the L1CFG SPR. Also, minor cleanup in cache.h to make the code a bit more readable. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-09Reworked FSL Book-E TLB macros to be more readableKumar Gala
The old macros made it difficult to know what WIMGE and perm bits were set for a TLB entry. Actually use the bit masks for these items since they are only a single bit. Also moved the macros into mmu.h out of e500.h since they aren't specific to e500. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-09Merge branch 'master' of git://www.denx.de/git/u-boot-usbWolfgang Denk
2008-01-09fix various commentsMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2008-01-09fix comments with new drivers organizationMarcel Ziswiler
2008-01-09Fix and optimize MII operations on FEC (MPC8xx) controllersGuennadi Liakhovetski
This patch fixes several issues at least on a MPC885 based system with two FEC interfaces used in MII mode. 1. PHY discovery should first read PHY_PHYIDR2 register and only then PHY_PHYIDR1 like cpu/mpc8xx/fec.c::mii_discover_phy() does it, otherwise the values read are wrong. Also notice, that PHY discovery cannot work on MPC88x / MPC87x in setups with both FECs active at all in its present form, because for both interfaces the registers from FEC 1 are used to communicate over MII. 2. Remove code duplication for resetting the FEC by isolating it into a separate function. 3. Initialize MII on FEC 1 when communicating over FEC 2 in fec_init(). 4. Optimize mii_init() to only reset the FEC 1 controller once. 5. Fix a typo in mii_init() using index i instead of j thus potentially leading to unpredictable results. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-01-09Merge git://www.denx.de/git/u-bootMarkus Klotzbuecher
Conflicts: board/tqm5200/tqm5200.c
2008-01-09Coding Style clenaup; update CHANGELOGWolfgang Denk
2008-01-09IXP: Add full baud-rate support for ixp42x, ixp45x and ixp46xJean-Christophe PLAGNIOL-VILLARD
2008-01-09Merge branch 'master' of git://www.denx.de/git/u-boot-mpc83xxWolfgang Denk
2008-01-09Merge branch 'lwmon5-no-ocm'Stefan Roese
2008-01-09ppc4xx: Add CFG_POST_ALT_WORD_ADDR to support non OCM POST WORD storageStefan Roese
The privious 4xx POST implementation only supported storing the POST WORD in OCM. Since we need to reserve the OCM on LWMON5 for the logbuffer we need to store the POST WORD in some other non volatile location. This patch adds CFG_POST_ALT_WORD_ADDR to specify an address for such a location. Signed-off-by: Stefan Roese <sr@denx.de>
2008-01-09ppc4xx: Add 44x cache locking to better support init-ram in d-cacheStefan Roese
This patch adds support for locking the init-ram/stack in d-cache, so that other regions may use d-cache as well Note, that this current implementation locks exactly 4k of d-cache, so please make sure that you don't define a bigger init-ram area. Take a look at the lwmon5 440EPx implementation as a reference. Signed-off-by: Stefan Roese <sr@denx.de>
2008-01-09ppc4xx: Move cpu/ppc4xx/vecnum.h into include pathMatthias Fuchs
This patch allows the use of 4xx interrupt vector number defines in board specific code outside cpu/ppc4xx. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-01-09ppc4xx: Fix UIC2 vector number baseMatthias Fuchs
2008-01-08ppc4xx: Return 0 on success in 4xx ethernet driverStefan Roese
2008-01-08mpc83xx: convert to using do_fixup_*()Kim Phillips
convert to using simpler mpc85xx style fdt update code; streamline by eliminating macros OF_SOC, OF_CPU, etc. which allows us to rm the old school FLAT_TREE code from 83xx (since the sbc8349 was just converted over to using libfdt). Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-08Add support CONFIG_UEC_ETH3 in MPC83xxJoakim Tjernlund
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2008-01-08mpc83xx: Add the support of MPC837xEMDS boardDave Liu
The MPC837xEMDS board support: * DDR2 400MHz hardcoded and SPD init * Local bus NOR Flash * I2C, UART, MII and RTC * eTSEC RGMII * PCI host Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-01-08mpc83xx: Add the support of MPC8315E SoCDave Liu
The MPC8315E SoC including e300c3 core and new IP blocks, such as TDM, PCI Express and SATA controller. Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-01-08mpc83xx: Add the support of MPC837x SoCDave Liu
The MPC837x SoC including e300c4 core and new IP blocks, such as SDHC, PCI Express and SATA controller. Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-01-05ppc4xx: Remove weak binding from common Denali data-eye search codeLarry Johnson
Now that there are no board-specific versions of "denali_core_search_data_eye()", the weak binding on the common version can be removed. Signed-off-by: Larry Johnson <lrj@acm.org>
2008-01-05Merge branch 'katmai-ddr-gda'Stefan Roese
2008-01-05ppc4xx: Remove unused CONFIG_ECC_ERROR_RESET from 44x_spd_ddr2.cStefan Roese
2008-01-05ppc4xx: Update Katmai/44x_spd_ddr2.c code for optimal DDR2 setupStefan Roese
On Katmai the complete auto-calibration somehow doesn't seem to produce the best results, meaning optimal values for RQFD/RFFD. This was discovered by GDA using a high bandwidth scope, analyzing the DDR2 signals. GDA provided a fixed value for RQFD, so now on Katmai "only" RFFD is auto-calibrated. This patch also adds RDCC calibration as mentioned on page 7 of the AMCC PowerPC440SP/SPe DDR2 application note: "DDR1/DDR2 Initialization Sequence and Dynamic Tuning" Signed-off-by: Stefan Roese <sr@denx.de>
2008-01-04ppc4xx: Add functionality to GPIO supportLawrence R. Johnson
This patch makes two additions to GPIO support: First, it adds function gpio_read_in_bit() to read the a bit from the GPIO Input Register (GPIOx_IR) in the same way that function gpio_read_out_bit() reads a bit from the GPIO Output Register (GPIOx_OR). Second, it modifies function gpio_set_chip_configuration() to provide an additional option for configuring the GPIO from the "CFG_4xx_GPIO_TABLE". According to the 440EPx User's Manual, when an alternate output is used, the three-state control is configured in one of two ways, depending on the particular output. The first option is to select the corresponding alternate three-state control in the GPIOx_TRSH/L registers. The second option is to select the GPIO Three-State Control Register (GPIOx_TCR) in the GPIOx_TRSH/L registers, and set the corresponding bit in the GPIOx_TCR register to enable the output. For example, the Manual specifies configuring the GPIO00 Alternate 1 Signal (PreAddr07) to use the alternate three-state control (first option), and specifies configuring the GPIO32 Alternate 1 Signal (USB2OM0) with the output enabled in the GPIOx_TCR register (second option). Currently, gpio_set_chip_configuration() configures all alternate signal outputs to use the first option. This patch allow the second option to be selected by setting the "out_val" element in the table entry to "GPIO_OUT_1". The first option is used when the "out_val" element is set to "GPIO_OUT_0". Because "out_val" is not currently used when an alternate signal is selected, and because all current GPIO tables set "out_val" to "GPIO_OUT_0" for all alternate signals, this patch should not change any existing configurations. Signed-off-by: Larry Johnson <lrj@acm.org>
2008-01-03Merge commit 'wd/master'Jon Loeliger
