This patch adds NAND booting support for the AMCC Bamboo eval board.
Since the NAND-SPL boot image is limited to 4kbytes, this version
only supports the onboard 64MBytes of DDR. The DIMM modules can't be
supported, since the setup code for I2C DIMM autodetection and
configuration is too big for this NAND bootloader.
This patch adds hardware ECC support to the NDFC driver. It also
changes the register access from using the "simple" in32/out32
functions to the in_be32/out_be32 functions, which make sure
that the access is correctly synced. This is the only recommended
access to SoC registers in the current Linux kernel.
Add config option for 180 degree advance clock control as needed
for the AMCC Luan eval board.
After being reset in mpc5xxx_fec_init_phy(), PHY goes into FX mode, in which
networking does not function. This commit switches PHY to TX mode by clearing
the FX_SEL bit of Mode Control Register. It also reverses commit
008861a2f3ef2c062744d733787c7e530a1b8761, i.e., a temporary workaround.
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
Acked-by: Bartlomiej Sieka <tur@semihalf.com>
Both CFG_PCISPEED_66 and CFG_IPBSPEED_133 are misnamed, as defining
them does not cause PCI or IPB clocks to run at the specified speed.
Instead, they configure divisors used to calculate said clocks. This
patch renames the defines according to their real function.
This patch adds support for 405 PPC's to the 4xx NAND driver
ndfc.c. This is in preparation for the new AMCC 405EZ.
As spotted by Bruce Adler this patch fixes an initialization problem
for the 405EZ OCM.
include/asm-microblaze/microblaze_intc.h
include/linux/stat.h
current PHY initalization code (tftp timeouts all the time). This commit
temporarily disables PHY initalization sequence to make the networking
operational, until a fix is found.
remove asm code
Some device trees have a mac-address property, some have local-mac-address,
and some have both. To support all of these device trees, ftp_cpu_setup()
should write the MAC address to mac-address and local-mac-address, if they
exist.
MPC5200B systems are incorrectly reported as MPC5200 in U-Boot start-up
message. Use PVR to distinguish between the two variants, and print proper CPU
information.
Signed-off-by: Grzegorz Wianecki <grzegorz.wianecki@gmail.com>
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
* Cleaned up the CDS PCI Config Tables and added NULL entries to
the end
* Fixed PCIe LAWBAR assignemt to use the cpu-relative address
* Fixed 85xx PCI code to assign powar region sizes based on the
config values (rather than hard-coding them)
* Fixed the 8548 CDS PCI2 IO to once again have 0 as the base address
Signed-off-by: Andy Fleming <afleming@freescale.com>
This included some changes to common files:
* Add 8568 processor SVR to various places
* Add support for setting the qe bus-frequency value in the dts
* Add the 8568MDS target to the Makefile
Signed-off-by: James Yang <James.Yang@freescale.com>
Define CFG_DDR_SDRAM_CLK_CNTL for the MPC8349E-mITX and MPC8349E-mITX-GP.
This allows ddr->sdram_clk_cntl to be properly initialized. This is necessary
on some ITX boards, notably those with a revision 3.1 CPU.
Also change spd_sdram() in cpu/mpc83xx/spd_sdram.c to not write anything into
ddr->sdram_clk_cntl if CFG_DDR_SDRAM_CLK_CNTL is not defined.
Acked-by: Michael Benedict <MBenedict@twacs.com>
and fix CPU: to align with Board: display text.
Clarified that conversion is to DRAM clocks rather than platform clocks.
Made function static to spd_sdram.c.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Changed the code to read the registers and calculate the clock
rates, rather than using a "switch" statement.
Idea from Andrew Klossner <andrew@cesa.opbu.xerox.com>
e500v2 and newer cores support 1G page sizes.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Enable single-bit error counter when memory was cleared by ddr controller.
exist.
* Cleaned up the TSR[WIS] clearing
* Cleaned up DMA initialization
Acked-by: Andy Fleming <afleming@freescale.com>
Recognize new SVR values, and add a few register definitions
The following patch fixes the e500 v2 core reset bug.
For e500 v2 core, a new reset control register is added to reset the
processor.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Remove the fixed TLB and LAW entry nubmer. Use actually TLB and LAW
entry number to control the loop. This can reduce the potential risk
for the 85xx processor increasing its TLB adn LAW entry number.
Signed-off-by: Swarthout Edward <swarthout@freescale.com>
Board code can now request the generic setup code rather than having to
copy-and-paste it for themselves. Boards should be converted to use this
once they're tested with it.
Rather than misleadingly define PVR_83xx as the specific type of 83xx
being built for, the PVR of each core revision is defined. checkcpu() now
prints the core that it detects, rather than aborting if it doesn't find
what it thinks it wants.
