path: root/cpu
2008-08-14ColdFire: Multiple fixes for M5282EVBTsiChung Liew
Incorrect CFG_HZ value, change 1000000 to 1000. Rename #waring to #warning. RAMBAR1 uses twice in start.S, rename the later to FLASHBAR. Insert nop for DRAM setup. And, env_offset in linker file. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-08-14ColdFire: Implement SBF feature for M5445EVBTsiChung Liew
2008-08-14ColdFire: Add SSPI feature for MCF5445xTsiChung Liew
2008-08-14Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2008-08-13s3c24x0: Update NAND driver to new API.Scott Wood
2008-08-13Merge branch 'Makefile' of git://git.denx.de/u-boot-armWolfgang Denk
2008-08-13Merge branch 'master' of /home/stefan/git/u-boot/u-bootStefan Roese
2008-08-13drivers/mtd/nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-12Merge branch 'master' of git://www.denx.de/git/u-boot-at91Wolfgang Denk
2008-08-12Merge branch 'master' of /home/stefan/git/u-boot/u-boot into nextStefan Roese
2008-08-12at91: move arch-at91sam9 to arch-at91Jean-Christophe PLAGNIOL-VILLARD
2008-08-12NAND boot: MPC8313ERDB supportScott Wood
Note that with older board revisions, NAND boot may only work after a power-on reset, and not after a warm reset. I don't have a newer board to test on; if you have a board with a 33MHz crystal, please let me know if it works after a warm reset. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12NAND: Davinci driver updatesSergey Kubushyn
Here comes a trivial patch to cpu/arm926ejs/davinci/nand.c. Unfortunately I don't have hardware handy so I can not test it at the moment but changes are rather trivial so it should work. It would be nice if somebody with a hardware checked it anyways. Signed-off-by: Sergey Kubushyn <ksi@koi8.net>
2008-08-12NAND: Update 4xx NDFC driver to match updated nand subsystemStefan Roese
This patch changes the 4xx NAND driver ndfc.c to match the new infrastructure from the updated NAND subsystem. This NAND subsystem was recently synced again with the Linux 2.6.22 MTD/NAND subsystem. Tested successfully on AMCC Sequoia and Bamboo. Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-12Fixing coding style issuesWilliam Juul
- Fixing leading white spaces - Fixing indentation where 4 spaces are used instead of tab - Removing C++ comments (//), wherever I introduced them Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Remove white space at end.William Juul
2008-08-12Update MTD to that of Linux 2.6.22.1William Juul
A lot changed in the Linux MTD code, since it was last ported from Linux to U-Boot. This patch takes U-Boot NAND support to the level of Linux 2.6.22.1 and will enable support for very large NAND devices (4KB pages) and ease the compatibility between U-Boot and Linux filesystems. This patch is tested on two custom boards with PPC and ARM processors running YAFFS in U-Boot and Linux using gcc-4.1.2 cross compilers. MAKEALL ppc/arm has some issues: * DOC/OneNand/nand_spl is not building (I have not tried porting these parts, and since I do not have any HW and I am not familiar with this code/HW I think its best left to someone else.) Except for the issues mentioned above, I have ported all drivers necessary to run MAKEALL ppc/arm without errors and warnings. Many drivers were trivial to port, but some were not so trivial. The following drivers must be examined carefully and maybe rewritten to some degree: cpu/ppc4xx/ndfc.c cpu/arm926ejs/davinci/nand.c board/delta/nand.c board/zylonite/nand.c Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12MPC8272ADS: fix build error: 'bd_t' has no member named 'pci_clk'Wolfgang Denk
2008-08-12Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2008-08-12Merge branch 'master' of git://www.denx.de/git/u-boot-armWolfgang Denk
2008-08-12ads5121: fix compiler warnings (unused variables)Wolfgang Denk
2008-08-1285xx: Rename CONFIG_NR_CPUS to CONFIG_NUM_CPUSKumar Gala
Use CONFIG_NUM_CPUS to match existing define used by 86xx. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-08-11POWERPC 86xx: Move BAT setup code to CBecky Bruce
This is needed because we will be possibly be locating devices at physical addresses above 32bits, and the asm preprocessing does not appear to deal with ULL constants properly. We now call write_bat in lib_ppc/bat_rw.c. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-08-11i.MX31: Fix mx31_gpio_mux() function and MUX_-macros.Magnus Lilja
Correct the mx31_gpio_mux() function to allow changing all i.MX31 IOMUX contacts instead of only the first 256 ones as is the case prior to this patch. Add missing MUX_* macros and update board files to use the new macros. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2008-08-06Fix merge problemsStefan Roese
2008-08-05mpc5121: Move iopin features from board specific to common files.Kenneth Johansson
And in the process eliminate some duplicate register defines. Signed-off-by: Kenneth Johansson <kenneth@southpole.se>
2008-08-05mpc5121: squash some fdt fixup errorsJohn Rigby
On ADS5121 when booting linux the following errors are seen: Unable to update property /soc5121@80000000:bus-frequency, err=FDT_ERR_NOTFOUND Unable to update property /soc5121@80000000/ethernet@2800:local-mac-address, err=FDT_ERR_NOTFOUND Unable to update property /soc5121@80000000/ethernet@2800:address, err=FDT_ERR_NOTFOUND This is caused by ft_cpu_setup trying to deal with both old and new soc node naming. This patch fixes this by being smarter about what to fixup. Also do soc node fixups by compatible instead of by path. A new board config called OF_SOC_COMPAT defined to be "fsl,mpc5121-immr" replaces the old OF_SOC node path that was defined to be "soc@80000000". Old device trees still work, but the compatiblity is conditional on CONFIG_OF_SUPPORT_OLD_DEVICE_TREES which is on by default in include/configs/ads5121.h. Signed-off-by: John Rigby <jrigby@freescale.com>
2008-08-03nios2/sysid: fix printf warningJean-Christophe PLAGNIOL-VILLARD
2008-08-03nios2: fix phys_addr_t and phys_size_t supportJean-Christophe PLAGNIOL-VILLARD
2008-07-318260: Making the use of gd->pci_clk dependant on the CONFIG_PCIMatvejchikov Ilya
Signed-off-by: Matvejchikov Ilya <matvejchikov@gmail.com>
2008-07-30Merge branch 'master' of git://git.denx.de/u-boot-mipsWolfgang Denk
2008-07-30Removed support for the adsvix board.Adrian Filipi
Support for the adsvix was originally provided by Applied Data Systems (ADS), inc., now EuroTech, Inc. The board never shipped aside from some sample boards. Signed-off-by: Adrian Filipi <adrian.filipi@eurotech.com>
2008-07-30mips: Fix baudrate divisor computation on alchemy cpusWolfgang Ocker
Use CFG_MIPS_TIMER_FREQ when computing the baudrate divisor on alchemy cpus. Signed-off-by: Wolfgang Ocker <weo@reccoware.de> Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-07-20microblaze: Fix printf() format issuesMichal Simek
2008-07-18ppc4xx: Fix incorrect MODTx setup for some DIMM configurationsStefan Roese
This patch fixes a problem with incorrect MODTx (On Die Termination) setup for a configuration with multiple DIMM's and multiple ranks. Without this change Katmai was unable to boot Linux with DDR2 frequency >= 533MHz and mem>=3GB. With this patch Katmai successfully boots Linux with DDR2 frequency = 640MHz and mem=4GB. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-18ppc4xx: Minor coding style cleanup of Xilinx Virtex5 ml507 supportStefan Roese
2008-07-18ppc4xx: CPU PPC440x5 on Virtex5 FXRicardo Ribalda Delgado
-This patchs gives support for the embbedded ppc440 on the Virtex5 FPGAs -interrupts.c divided in uic.c and interrupts.c -xilinx_irq.c for xilinx interrupt controller -Include modifications propossed by Stefan Roese Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Acked-by: Stefan Roese <sr@denx.de>
2008-07-17Merge branch 'master' of /home/stefan/git/u-boot/u-boot into nextStefan Roese
2008-07-15Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2008-07-1485xx: Cleanup L2 cache size detectionKumar Gala
The L2 size detection code was a bit confusing and we kept having to add code to it to handle new processors. Change the sense of detection so we look for the older processors that aren't changing. Also added support for 1M cache size on 8572. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-148xxx-fdt: set ns16550 clock from CFG_NS16550_CLK, not bi_busfreqPaul Gortmaker
Some boards that have external 16550 UARTs don't have a direct tie between bi_busfreq and the clock used for the UARTs. Boards that do have such a tie should set CFG_NS16550_CLK to be get_bus_freq(0) -- which most of them do already. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2008-07-14Change the temp map to ROM to align addresses to page size.Andrew Klossner
With a page size of BOOKE_PAGESZ_16M, both the real and effective addresses must be multiples of 16MB. The hardware silently truncates them so the code happens to work. This patch clarifies the situation by establishing addresses that the hardware doesn't need to truncate. Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-07-14mpc85xx: use IS_E_PROCESSOR macroKim Phillips
2008-07-14fdt: add crypto node handling for MPC8{3, 5}xxE processorsKim Phillips
Delete the crypto node if not on an E-processor. If on 8360 or 834x family, check rev and up-rev crypto node (to SEC rev. 2.4 property values) if on an 'EA' processor, e.g. MPC8349EA. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-07-14ARM DaVinci: Remove extern phy_t declaration by moving code to proper placeHugo Villeneuve
ARM DaVinci: Remove extern phy_t declaration by moving code to proper place. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-07-14Fix some more printf() format problems.Kumar Gala
2008-07-14cpu/i386/serial.c: Fix syntax errorsWolfgang Denk
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2008-07-14Fix printf() format issues with sizeof_t types by using %zuWolfgang Denk
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-07-14Merge branch 'master' of /home/stefan/git/u-boot/u-boot into nextStefan Roese
