* Add MPC8220 boards to MAKEALL script
* Add EEPROM and RTC support for HMI1001 board
* Patch by Detlev Zundel, 20 Jun 2005:
Fix initialization of low active GPIO pins on inka4x0 board
Initialize allocated dev and private hw structures
after their respective allocation in 440gx_enet.c
* Patch by Steven Scholz, 10 Jun 2005:
Fix byteorder problems with second argument of "bootm" with
standalone images;
* Disable "date" and "sntp" commands on TQM866M which has no RTC
Add support for Funkwerk VoVPN gateway module.
add support for the KS8695P (ARM 922 based) CPU
* Patch by Steven Scholz, 19 May 2005:
Add support for CONFIG_SERIAL_TAG on ARM boards
Code cleanup (especially Sorcery / Alaska / Yukon serial driver).
genereated HRESET pulse is too short to reset the external circuitry.
PM520 boards.
Fix PHY address for canmb board.
Make PCI target address spaces on PMC405 and CPCI405 boards
configurable via environment variables
- fix clock rates
- remove debug messages
- fix flash sector protection
* Patch by Steven Scholz, 07 Apr 2005:
Fix warning in cpu/arm920t/at91rm9200/i2c.c
Add i2c_reg_write() and i2c_reg_write() for at91rm9200 I2C
Fix compiler warning in altera.c
* Patch by Ladislav Michl, 06 Apr 2005:
Fix voiceblue configuration.
- Change timer frequency for ppc 440 from 10 ms to 1 ms.
Problem found by Andrew Wozniak.
- creating SoC subdir for Atmel AT91RM9200 cpu/arm920t/at91rm9200
- moving code out of cpu/at91rm9200 into cpu/arm920t/at91rm9200
- update the pxa-regs.h file for PXA27x chips
- add PXA27x based ADSVIX board
- add support for MMC on PXA27x processors
* Patch by Andrew E. Mileski, 28 Nov 2004:
Fix PPC4xx SPD SDRAM detection bug
* Patch by Hiroshi Ito, 26 Nov 2004:
Fix logic of "test -z" and "test -n" commands
Add support for VoiceBlue board.
* Patch by Ladislav Michl, 05 Apr 2005:
Fix netboot_common() prototypes.
* Cleanup.
- Use i.MX watchdog timer for reset_cpu()
- Move reset_cpu() out of cpu/arm920t/start.S into the SoC specific
subdirectories cpu/arm920t/imx/ and cpu/arm920t/s3c24x0/
(now in interupts.c)
Interfaces are named as follows: "ENET1" - TSEC2, "ENET2" - FEC
* Patch by Martin Krause, 04 Apr 2005:
Update default configuration for CMC_PU2 board.
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards
- introduce two new configuration options instead:
CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
Make sure that MDIO clock does not exceed 2.5 MHz on AT91
reset timers so it's save to use udelay() in timeout code.
- Add low-boot option for MPC8260ADS board (if lowboot is selected,
the jumper for the HRCW source should select flash. If lowboot is
not selected, the jumper for the HRCW source should select the
BCSR.
- change default load base address to 0x00400000
Add support for Analogue & Micro Rattler boards.
Tested on Rattler8248.
* Patch by Andre Renaud, 08 Nov 2004:
Fix watchdog support in common/lcd.c
* Patch by Marc Leeman, 05 Nov 2003:
Enable all 4 PCMBRW buffers for the MPC8245 processor since the CPU
bug only affects the XPC8245 processors
- Add support for MicroSys CPU87 board
- Add support for MicroSys PM854 board
Add missing 440GX SDRAM Controller reset
Declare reset_cpu() in include/common.h instead locally
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL
- rename memsetup into lowlevel_init (function name and source files)
fix cache enabling for AT91RM9200
add SNTP support and expand time server and time offset fields of
DHCP support. See doc/README.SNTP
* Patch by Steven Scholz, 13 Dec 2004:
Fix bug in at91rm920 ethernet driver
Remove duplicated code by merging memsetup.S files for
at91rm9200 boards into one cpu/at91rm9200/lowlevel.S
Add support for Nios-II EPCS Controller core.
* Patch by Scott McNutt, 20 Oct 2004:
Nios-II cleanups:
- Add sysid command (Nios-II only).
- Locate default exception trampoline at proper offset.
- Implement I/O routines (readb, writeb, etc)
- Implement do_bootm_linux
- use TQM5200_auto as MAKEALL target for TQM5200 systems
- add support for SM501 graphics controller
- add support for graphic console on TQM5200
- add support for TQM5200 Rev 200
- cleanup, fix typo in include/configs/TQM5200.h
- Change the name of the Ethernet driver: MOTO ENET -> ENET
- Reformat boot messages
- Enable redundant environment
- Replace the -O2 optimization flag with -mno-string
Restore copyright statements in OHCI drivers.
* Add support for TQM8540 board
* Add reset code for Coral-P on INKA4x0 board
* Patch by Martin Krause, 28 Jun 2004:
Update for TRAB board.
* Fix some missing "volatile"s in MPC5xxx FEC driver
* Patch by Richard Woodruff, 10 Jan 2005:
Update support for OMAP2420 (ARM11) and H4 board:
o clean up and add new types to H4 memory probe code.
o fix to work with internal boot.
o added PRCM config III operation.
o fix marginal flash timings.
o add revison ATAG usage.
o enable voltage scaling at power chip.
o fix compile error for i2c.
* Fix network problem (error when receiving multiple ARP packets)
add support for the TI OMAP2420 processor and its H4 reference
board
* Patch by Christian Pellegrin, 24 Sep 2004:
Added support for NE2000 compatible (DP8390, DP83902) NICs.
add support for the AMD db1550 board
* Patch by Travis Sawyer, 15 Sep 2004:
Add CONFIG_SERIAL_MULTI support for ppc4xx,
update README.serial_multi
- add u-boot.hex target in the top level Makefile
- add support for the UNSW/NICTA PLEB 2 board (pleb2)
- use -mtune=xscale and -march=armv5 options for PXA
mpc824x: set PCI latency timer to a sane value
(is 0 after reset).
* Patch by Kurt Stremerch, 03 Sep 2004:
Add bitstream configuration option for fpga command (Xilinx only).
Reset monitor size back to 256 so environment can be written
to flash on MPC85xx ADS and CDS releases.
* Patch by Paolo Broggini, 02 Sep 2004:
Make BSS clearing on ARM systems more robust
* Patch by Yue Hu and Joe, 01 Sep 2004:
- add PCI support for ixp425;
- add EEPRO100 suppor tfor ixdp425 board.
* Fix problem with protected sector detection in driver/cfi_flash.c
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to
pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for
additional ethernet addresses.
* Cleanup drivers/i82365.c - avoid duplication of code
* Fix bogus "cannot span across banks" flash error message
* Add support for CompactFlash for the CPC45 Board.
