path: root/cpu
2012-09-12ENGR00218972 MX6 Secure Boot, Change to dynamic HAB data authenticationEric Sun
The original secure boot implementation make a consumption that u-boot.bin will not exceed 0x2F000. With this consumption, the hab data is hard coded in linker script file to relative address 0x2F000 without causing any problem. But when this consumption don't hold, the hard coded way will cause memory region overlap and break build. So we need to change to a dynamic way of allocating hab_data. The new implementation put hab data at the next 0x1000 alignment after u-boot data and text section, instead of hard coded to 0x2F000. Similar changes is made to uImage authentication implementation. Changes in U-Boot includes: - in u-boot.lds file, change "__hab_data" to dynamic align to 0x1000 - change authenticate_image implementation, originally the uImage parameters are hard coded, now they are retrived from the "load_addr" and the image_hdr The new secure image layout: U-Boot +-------------------+ DDR_START | | | U-Boot Image | | | +-------------------+ DDR_START + UBOOT_SIZE | PADDING | +-------------------+ align to 0x1000 | CSF Data | - +-------------------+ +-- CSF + Pad, Size : 0x2000 | PADDING | - +-------------------+ uImage +-------------------+ DDR_START | | | uImage | | | +-------------------+ DDR_START + UIMAGE_SIZE | PADDING | +-------------------+ align to 0x1000 | IVT | ---- Size : 0x20 +-------------------+ | CSF Data | - +-------------------+ +-- CSF + Pad, Size : 0x2000 | PADDING | - +-------------------+ Signed-off-by: Eric Sun <jian.sun@freescale.com>
2012-09-12ENGR00217401 common: fix build warningXinyu Chen
Fix the build warning in uboot build. Fix bug of incorrect dereference to periph2 clock pre divider. Fix incorrect type of maxpackage size assign, even it's not used at all in fastboot. Signed-off-by: Xinyu Chen <xinyu.chen@freescale.com>
2012-09-12ENGR00217114-1 MX6 U-Boot, Secure Boot, one code base for MX6Q/DL/SLEric Sun
Move the secure boot related implementation code from mx6q_arm2.c to mx6/generic.c. In this way the HAB feature can be shared by all MX6 platforms Signed-off-by: Eric Sun <jian.sun@freescale.com>
2012-09-12ENGR00211038 Fix the PAD_LVE implementationMahesh Mahadevan
Fix the PAD_LVE implementation used on MX6SL. Signed-off-by: Mahesh Mahadevan <mahesh.mahadevan@freescale.com>
2012-09-12ENGR00210918-2 cleanup android support, build pass all boardsZhang Jiejing
- move recovery.h to common inlcude place. - move supported_reco_envs to soc related, not board related, - user can change this via configure header, don't needs this in every board file. - pass build for all mx5/mx6 android configs. Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
2012-09-12ENGR00209899-2 MX6Q: cleanup: cleanup fastboot, udc warnning.Zhang Jiejing
cleanup android fastboot and udc build warnnings. Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
2012-09-12ENGR00210014 i.mx6 : i.mx6sl : add PAD_CTL_LVE support for pad configurationEric Sun
Original pad configuration don't provide enough bitfield width to hold all necessary information. For MX6Sololite, a "PAD_CTL_LVE" is needed to be configed for many pins. iomux_v3_cfg_t is re-orgnized to address this issue. PAD_CTRL is extended by 1 bit to hold the "PAD_CTL_LVE". Which is mapped to proper bit location when configure the PAD config register. Signed-off-by: Mahesh Mahadevan <r9aadq@freescale.com>
2012-09-12ENGR00209059 android: refine fastboot and recovery support.Zhang Jiejing
1. add check asrc register to enter recovery mode, rather then check the file. 2. fix the boot.img can not fastboot flash function. 3. consolidate and cleanup fastboot code. 4. clean up many build warnning message. Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
2012-09-12ENGR00181337-1 i.mx6 : add initial support for i.mx6slEric Sun
This patch is to add the initial support for Freescale i.mx6sl chip. i.mx6sl is the SoloLite verison of Freescale i.mx6 family. The patch does: - memory layout support, - iomux support, - clock support, Signed-off-by: Jason Liu <r64343@freescale.com> Signed-off-by: Ryan QIAN <b32804@freescale.com> Signed-off-by: Fugang Duan <B38611@freescale.com>
2012-09-12ENGR00180623 fastboot: add fastboot in MX6Q_SABERSD boardsZhang Jiejing
add fastboot function back in MX6Q_SABERSD board. the MX6DL_SABERSD have usb init related issue which will keep RESET, but left as later developement. Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
2012-09-12ENGR00179762: i.MX6: print the SOC revision correctlyJason Liu
For example: The soc rev on i.mx6dl rev 1.0 not print correctly: CPU: Freescale i.MX 6 family 0.0V at 792 MHz This patch help u-boot print out the SOC revision correctly: CPU: Freescale i.MX6 family TO1.0 at 792 MHz Signed-off-by: Jason Liu <r64343@freescale.com>
2012-09-05ENGR00174625: Remove build warnings for mx6qTerry Lv
Remove build warnings for mx6q. Signed-off-by: Terry Lv <r65388@freescale.com>
2012-09-05ENGR00174104-1: Add conditional CONFIG to fix build breakTerry Lv
Add CONFIG_MXC_FEC macro to fec init code. Add CONFIG_VIDEO_MX5 to ipu init code. Change temperature function as static. For in iram boot, FEC configs is not needed, those FEC init code will cause build errors. These changes can reduce image size. Signed-off-by: Terry Lv <r65388@freescale.com>
2012-09-05ENGR00171771 [MX6]Need to power down PCIe by defaultAnson Huang
PCIe is power on by defaultt, we need to power down it in u-boot, it can save more than 1mW during suspend. Signed-off-by: Anson Huang <b20788@freescale.com>
2012-09-05ENGR00171091 [MX6]Remove workaround for reset issueAnson Huang
The root cause is the L1 I-cache need invalidation, now we don't need this workaround, so remove it. Signed-off-by: Anson Huang <b20788@freescale.com>
2012-09-05ENGR00171008 MX6Q/MFGTOOL : disable the workaround for MFGTOOLHuang Shijie
Disable the uboot workaround. It will crash the MFGTOOL. Signed-off-by: Huang Shijie <b32955@freescale.com>
2012-09-05ENGR00170837 [MX6]Add temperatuer check into ubootAnson Huang
We need to check CPU temperature in uboot, if cpu is too hot, we will let it waiting there until cpu temperature drop to save region, then go on boot up. Signed-off-by: Anson Huang <b20788@freescale.com>
2012-09-05ENGR00162642: Fix bug in setting VDDSOC voltageRanjani Vaidyanathan
Fix incorrect VDDSOC voltage setting in uboot. Signed-off-by: Ranjani Vaidyanathan <ra5478@freescale.com>
2012-09-05ENGR00160621 [MX6]Workaround for reset issueAnson Huang
Add workaround for POR/wdog reset issue, we need to do a CORE LDO reset everytime POR/wdog reset, otherwise kernel will crash or hang when we booting more than 2 cores. Root cause is still under investigation, it is analog/power related issue, may take long time to identify the root cause, we need to add workaround to make function ready first. The flow of workaround is as below: 1. Check CORE LDO reset flag, currently stored in SNVS_LPGPR[0]; 2. If it is there, clear it, go on boot up system; If not, Set the flag, configure wdog to timeout in 0.5 seconds, then disable CORE LDO and wait for wdog timeout; This workaround will bring 0.5~1 seconds delay of booting. Signed-off-by: Anson Huang <b20788@freescale.com>
2012-09-05ENGR00170299-1 Android: add support fastboot functionZhang Jiejing
add support for otg in MX6Q uboot to enable fastboot function. Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
2012-09-05ENGR00163513 MX6Q-UBOOT : Add download_mode cmdEric Sun
Add "download_mode" command to U-Boot. It will force a system reset and let boot running in "boot from serial rom" mode, which can be used by manufacturing tool. The command will triggle a write to SRC_GPR9 and SRC_GPR10, then triggle a watchdog reset. GPR9 and GPR10 can maintain their value during the reset, the value in it make ROM to start in "boot from serial rom" mode. After that GPR9 and GPR10 are written by their original value for normal boot. Signed-off-by: Eric Sun <jian.sun@freescale.com>
2012-09-05ENGR00162938 MX5: Add download_mode command in uboot to enter MFG download mode.Zhang Jiejing
Add download_mode command in uboot to enter MFG dowload mode , you can try download mode command in uboot and enter download mode. it first set srtc register, then before enter linux, it will clear these register to prevent the up comming watchdog reset will enter mfgtool mode. only add mx53 now. Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
2012-09-05ENGR00162874: Add enet clk change support for mx6Terry Lv
Add enet clk change support for mx6. Signed-off-by: Terry Lv <r65388@freescale.com>
2012-09-05ENGR00162570: MX6-Increase VDDSOC_CAP voltage to 1.2VRanjani Vaidyanathan
Set the VDDSOC LDO to increase the VDDSOC cap to 1.2V. This is required for correct functioning of GPU and when the ARM LDO is set to 1.225V (when ARM core is at 1GHz). Signed-off-by: Ranjani Vaidyanathan <ra5478@freescale.com>
2012-09-05ENGR00161373 Move the MAC address read from fuse code to MX6 SoC fileMahesh Mahadevan
Move the code to read the mac address from the fuse to SoC file and out of the board file Signed-off-by: Mahesh Mahadevan <r9aadq@freescale.com>
2012-09-05ENGR00161254 MX6Q: Add NAND support in UbootAllen Xu
Add iomux and clock setting in Uboot code to support NAND, due to the conflict between NAND and SD, NAND function is not enabled in default configuration. Signed-off-by: Allen Xu <allen.xu@freescale.com>
2012-09-05ENGR00139215 iMX61 Uboot support blow fuseRyan QIAN
1. add force option to blow operation 2. add blown value check 3. add simple validation for zeros returned by 'simple_strtoul' call Signed-off-by: Ryan QIAN <b32804@freescale.com>
2012-09-05ENGR00139254: Enable MX6Q Uboot Splash ScreenSandor Yu
Only support LVDS0 splash screen. Enable splash process: 1.define CONFIG_SPLASH_SCREEN in mx6q_sabreauto.h 2.Config U-boot with followed command:() setenv splashimage '0x30000000' #Set splash position as Center setenv splashpos 'm,m' #Set LVDS via LVDS bridge 0 setenv lvds_num 0 Signed-off-by: Sandor Yu <r01008@freescale.com>
2012-09-05ENGR00155283: Set dpgdck0_2_en to 0 when freq is lower than 300MHzTerry Lv
1. Set dpgdck0_2_en to 0 when required freq is lower than 300Mhz. 2. When dpgdck0_2_en is 0, the formula to calculate output freq will be changed to 2 * freq * []. Signed-off-by: Terry Lv <r65388@freescale.com>
2012-09-05ENGR00155156 [MX6]Clean up debug info in ubootAnson Huang
1. ENET don't need to enable ENET pll clock; 2. Enable cpu debug clock in case of using JTAG; 3. Clean up some debug info during bring up. Signed-off-by: Anson Huang <b20788@freescale.com>
2012-09-05ENGR00151310 mx53 smd: force warm reset as cold resetLily Zhang
This patch is used to support watchdog timeout in SMD RevA, RevB board. 1. Revert "ENGR00143469 mx53 smd: pull down GPIO_9 to reset the board". 2. Force warm reset as cold reset. Signed-off-by: Lily Zhang <r58066@freescale.com>
2012-09-05ENGR00144424 MX6: enable uboot for ARM2(SABREAUTO) CPU boardAnson Huang
Use 528M DDR script Disable L2 cache because rom enable L2 cache when use plug-in Fix usdhc pad settings Remove mac address hardcode Signed-off-by: Anson Huang <b20788@freescale.com> Signed-off-by: Richard Zhu <r65037@freescale.com> Signed-off-by: Terry Lv <r65388@freescale.com> Signed-off-by: Anish Trivedi <anish@freescale.com> Signed-off-by: Jason Liu <r64343@freescale.com>
2012-09-05ENGR00143298: Reinit uart after using clk commandTerry Lv
For clk command always make console output mess characters, here we reinitilize it after clock is changed. Signed-off-by: Terry Lv <r65388@freescale.com>
2012-09-05ENGR00143469 mx53 smd: pull down GPIO_9 to reset the boardLily Zhang
In mx53 smd, to type "reset" command in u-boot console can not reset the system. It hangs in ROM with unknown reason. This patch adds one workaround to configure GPIO_9 (WDT_OUTPUT_B) as GPIO and pull down it to reset DA9053 PMIC. Signed-off-by: Lily Zhang <r58066@freescale.com>
2012-09-05ENGR00141885: mx50 and mx53 reboot fail when booting from spi norTerry Lv
mx50 reboot fail when booting from spi nor. Reconfigure eCSPI SS signal as GPIO before reset. Signed-off-by: Terry Lv <r65388@freescale.com>
2012-09-05ENGR00141335-2: get more accurate ipg_per clock frequencyTerry Lv
Add perclk_lp_apm_sel check to function __get_ipg_per_clk. This will get more accute clock frequency. Signed-off-by: Terry Lv <r65388@freescale.com>
2012-09-05ENGR00141556: Fix copyright issueTerry Lv
We're following the following rules: 1. FSL copyright should be added for freescale added and modified files. 2. FSL copyright should go after existing copyrights. 3. For Duplicate FSL copyright, Our copyright will go after that also. 4. FSL copyright should not include personal names as part. 5. For only FSL copyright, "All rights reserved" is not mattered. Signed-off-by: Terry Lv <r65388@freescale.com>
2012-09-05ENGR00140824 Android: Enable fastboot support for mx50 rdpSammy He
Enable fastboot support for mx50 rdp. Signed-off-by: Sammy He <r62914@freescale.com>
2012-09-05ENGR00140767: Improve mx5x DDR clock functionTerry
As now mx51 DDR frequency is derived from PLL1. We need to get DDR frequency from PLL1. Mx53 don't use PLL1 for ddr clock source, so just the precision is adjusted. Mx50 don't support clk command yet. DDR config function is modified according to mx50 spec, but not tested yet. Signed-off-by: Terry <r65388@freescale.com>
2012-09-05ENGR00138468-1 MX5 video:Disable DP/DC/DI/IDMAC before go to kernelLiu Ying
This patch fixes the kernel bootup random hang issue by disabling DP/DC/DI/IDMAC before we go to kernel. This is a workaround. Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
2012-09-05ENGR00137894-2 MX53: Add ipu base addr and ipu clockLiu Ying
This patch adds ipu base address and ipu clock. Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
2012-09-05ENGR00137604: Change PLL4 to 455MHz for mx53Terry Lv
Required by display to set ldb. We need to set PLL4 to 455MHz. Signed-off-by: Terry Lv <r65388@freescale.com>
2012-09-05ENGR00137372 MX53: Switch back to use DCD and update DDR scriptsLily Zhang
1. This patch is used to switch back to use DCD for flash header instead of plug-in. This change request is due to the following reasons: 1) U-boot community doesn't accept current plug-in solution when upstreaming. 2) Plug-in isn't supported by MX53 ROM serial download mode. No effective workaround is found now. To use the same code base to support normal U-Boot and MFG tool better, adopt DCD solution firstly. 3) Current MX53 DDR scripts don't exceed the length limitation of DCD. For MX53 TO2.0 EVK/ARM2 board, raise DDR frequency to 400MHZ after VCC and VDDA voltages are raised as 1.3V. Since ARM2 CPU2 board share the same script with EVK, delete ARM2 CPU2 config files. ARM2 CPU2 board can share the same bootloader with EVK. 2. Update MX53 DDR2 scripts for TO1.0/TO2.0 EVK/ARD/ARM2 boards The script "MX53_TO2_DDR2_EVK_ARD.inc" is located under http://compass.freescale.net/livelink/livelink? func=ll&objId=221058910&objAction=browse&viewType=1 This script is published by ATX and FIL team on Dec 16th, 2010 3. Update MX53 ARM2 CPU3 DDR3 script "MX53_TO2_DDR3_CPU3.inc" under the same compass folder Signed-off-by: Lily Zhang <r58066@freescale.com>
2012-09-05ENGR00134068 MX51 BBG:Support CLAA WVGA splashimageLiu Ying
1) IOMUX/backlight support for CLAA WVGA LCD panel. 2) Add video mode for CLAA WVGA LCD panel. 3) Support IPU di1 interface for framebuffer. 4) Enhance IPU driver. 5) Add freescale 600x400 8BPP BMP logo. Signed-off-by: Terry Lv <R65388@freescale.com> Signed-off-by: Liu Ying <b17645@freescale.com>
2012-09-05ENGR00133727: uart outputs messy code when kernel starts on mx51Terry Lv
uart outputs messy code when kernel starts on mx51. Change uart clock to use pll2 as source clock. Signed-off-by: Terry Lv <r65388@freescale.com>
2012-09-05ENGR00134098-2 MX53: Add fastboot support for android.Sammy He
Add fastboot support for mx53 EVK android. Signed-off-by: Sammy He <r62914@freescale.com>
2012-09-05ENGR00134098-1 MX51: Update fastboot usb init seqSammy He
Update fastboot usb init seq, and use defined macro for coding. Signed-off-by: Sammy He <r62914@freescale.com>
2012-09-05ENGR00133551-1 Add freescale usb udc support for i.mx51 platform.Sammy He
Add imx_udc for usb gadget on i.mx51 platform. Signed-off-by: Hu Hui <b29976@freescale.com> Signed-off-by: Sammy He <r62914@freescale.com>
2012-09-05ENGR00132909 MX53 Uboot: Support for TO2Anish Trivedi
Support new DDR script entitled "Rita_TO2_init_DDR2_CPU2_CMOS_TEST_CAL_v1.inc" for DDR2 boards including MX53 EVK, ARD, and ARM2 CPU2. These new settings did not apply to TO1. Therefore, changed the DCD for these boards to a plugin so that TO1 and TO2 can both be supported using conditional execution of new DDR settings. During bootup on TO2, DDR frequency is required to be below 400 MHz. Therefore, BOOT_CFG2[4] must be set to enable DDR at 333 MHz in ROM on all boards. Uboot determines silicon version and for TO2 boosts the VCC and VDDA voltages to 1.3V, after which the DDR frequency is also increased to 400 MHz. This requirement meant that uboot does not calibrate PLL2 anymore until the voltage is increased. Removed the calibration from lowlevel_init.S and from all mx53 include/configs files. Also required that during config_periph_clk(), only CBCMR register is touched to set source PLL. Other changes to CBCDR were removed. Switching to PLL2 bypass clk during reprogram was also removed. All these changes are required to increase DDR frequency to 400 MHz. DDR2 CPU2 board with TO1 requires the following hw cfgs: JP3 populated, and J8 set to 2-3. For DDR2 CPU2 board with TO2, both these jumpers should be depopulated. ARM2 CPU3 (with DDR3) DDR configurations were not changed. TO1 and TO2 can run well using existing DDR3 script. However, DCD was converted to plugin to align with other boards. Signed-off-by: Anish Trivedi <anish@freescale.com>
2012-09-05ENGR00133049 Support nand flash for MX28Frank Li
Support nand basic read/write in MX28 u-boot. Signed-off-by: Frank Li <frank.li@freescale.com> Signed-off-by: Terry Lv <r65388@freescale.com>
